1 of 11
Wyze Duo Cam Pan
Wyze Duo Cam Pan
Two cams. Two views. Zero blind spots.
Wyze Duo Cam Pan (Quantity)
$79.98CAD
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Wyze Duo Cam Pan delivers two 2K cameras in one device for complete coverage. One stays fixed on your priority view while the other pans and tilts to track motion, with color night vision, spotlights, siren, and indoor/outdoor versatility.
Outdoor use requires Wyze Universal Outdoor Power Adapter.
    Two Cameras. Two Views.
    One fixed + one pan and tilt cam eliminate blind spots.
    2K HD Resolution + Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • An icon for the IP65 page.
    Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
    Two Motion-Activated Spotlights
    Automatically trigger the LED light and voice prompt for extra security.
Wyze Duo Cam Pan Tech Spec
Colors & Materials
  • Colors: White
  • Finish: Textured Matte
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • Lens FOV: DFOV 127.5°, HFOV 106°, VFOV 56.5° (Fixed), DFOV 127.5°, HFOV 106°, VFOV 56.5° (PT)
  • Image Sensor: 1/2.8'' CMOS (Fixed)
  • 1/2.8'' CMOS (PT)
  • LED Indicator: Front. Red + Blue.
Dimensions & Weight
  • 2.36in x 2.16in x 5.26in (64mm x 54.9mm x 133.5mm)
  • 0.66lb (300g)
Mounting
  • Stand, wall mount, ceiling mount.
View Range
  • 360° horizontal, 180° vertical
Power
  • Power Adapter: Input 110-240 V (AC/DC), Output 5V/1.5A
  • Compatible Outdoor Power Adapter (sold separately and coming soon)
  • Cable: 6-Foot Flat Type-C to USB-A
Video
  • Resolution: 2K (2304*1296)+ 2K (2304*1296)
  • Wide Dynamic Range (WDR): Yes
  • IR Lights: 4x850 nm
  • Day/Night Vision: Yes
  • Night Vision: 4 IR LEDs (850 nm) + 4 white spotlight LEDs ( 80 lumens)
  • Color Night Vision: Yes
  • Video Encoding: H.264
  • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Audio
  • Speaker: 100dB, waterproof
  • Simultaneous 2-way Talk: Yes
  • Built-in Siren: Yes
  • Noise & Echo Cancellation: Yes
Connectivity & Compatibility
  • Bluetooth® 5.0
  • Wi-Fi: 2.4 GHz Wi-Fi, Wi-Fi 6
  • Phone Compatibility: Android 10+ and iOS 16+
Storage
  • Local (microSD card required)
  • MicroSD card up to 512 GB
  • Cloud (with subscription plan)
Weather & Temperature
  • IP65 weather-resistant
  • Operating temp: -4ºF - 113ºF (-20ºC - 45ºC)
  • Storage temp: -22°F - 158°F (-30°C - 70°C)
Language
  • English
Warranty
  • 1-Year
  • Wyze Duo Cam Pan x1
  • Quick Start Guide x1
  • Mounting Kit x1
  • USB-C to USB-A Cable (6-foot, flat) x1
  • Indoor Power Adapter (5V, 1.5A.) x1
Two cameras. Two views.
One stays steady while the other one moves. Cover two areas with a single device for maximum coverage.
Keep your head on a swivel with 360° pan and 180° tilt.
Never miss the action with auto motion tracking. Crystal-clear 2K clarity on both cams capture every detail.
A black door with a light switch on it.
Integrated Spotlights + Siren
More safety at night.
ip65 weather resistance
Place it anywhere.
Wyze Duo Cam Pan is IP65 weather-resistant, so it can operate in any weather.
Note: Outdoor use requires Wyze Cam Universal Outdoor Power Adapter (sold separately, learn more).
A Wyze Duo Cam is mounted on a wall.
Enhanced two-way talk
Clearer conversation.
Forget the days of sounding like you’re talking through tin cans. Advanced Audio Coding (AAC) and a revamped mic give our best audio experience yet.
A white and black camera with a sun in the background.
Record every second
24/7 Recording with MicroSD Card.
Don’t miss a thing with continuous local recording to a microSD card up to 512 GB. No subscription required. Sold separately.
See it in action.
And check out the unboxing video to see more magic.
Wyze Duo Cam Pan with WDR
No WDR
A panoramic camera is mounted on a house.
Full coverage
Double the coverage. No blind spots.
It's especially effective when placed near a corner. Keep a fixed watch on the driveway, and at the same time follow the action if it moves to the backyard.
A woman is holding a smartphone with a home monitoring app on the screen.
Connect with bluetooth®
Easy to set up.
No need to scan QR codes. Enjoy hassle-free setup with Bluetooth®. We'll get you up and running within minutes.
Wyze Duo Cam Pan Shopify 07
Plug it in and go
Versatile mounting.
Four unique mounting options gives you the flexibility to secure your space exactly how you need to.
A Wyze Duo Cam Pan is displayed on a table.
Works with smart assistants
Convenience and customization at your fingertips with integrations like Amazon Alexa, Google Assistant, IFTTT, and Wyze Automation.
Patrol your room with Pan Scan.
Set the camera’s patrol route with up to 4 custom waypoints.
A map of a bathroom with a green arrow pointing to the Waypoint.
A garage door with a green circle around it.
Even more features to love.
Look & listen for motion & sound. Wyze Duo Cam Pan sends your phone an alert and begins recording when either is detected.
Receive an alert the moment Wyze Duo Cam Pan hears a Smoke or CO alarm go off. Wyze Cam records a video during this time.
