1 of 6
Wyze Buds
Wyze Buds
Your body-rocking audio partner from home to gym.
Color
Wyze Bud's a bud that's a bud. Some buds only tell you they're your bud to your face. Wyze Buds are true buds. The kind of buds who stay right there with you, providing you with high-quality listening to the very end. Provided the end is 27 hours away because that's their (totally amazing) battery life.
    10.5mm audio driver for stronger bass
    30 dB passive noise reduction
    5 silicone tips for proper sizing
    Up to 27 hours of total battery life
Wyze Buds Details
Earbud dimensions
  • 1.04 in x 0.81 in x 0.89 in
Case dimensions
  • 2.25 in x 1.07 in x 1.75 in
Earbud weight
  • 0.17 oz each
Case weight
  • 1.20 oz
Earbud materials
  • Plastic with silicone ear tips
Case materials
  • Plastic
Sweat and weather resistance
  • IPX5 sweat and weather resistant
Bluetooth Specifications
  • Bluetooth version: Bluetooth 5.0
  • Bluetooth codec: SBC, AAC
  • Device connection: Single device connection
Speaker
  • Driver dimensions: 10.5 mm dynamic driver
  • Frequency range: 20 - 20,000 Hz
  • Total harmonic distortion: <1% 1 mW/1kHz
Battery Life
  • Earbuds: Up to 7 hours of playback time
  • Case: Up to 20 hours of playback time
  • 15-minute quick charge: Up to 2 hours of playback time.
  • Charging: Charge with a USB Type-C cable.
  • Charging Time: Earbuds: ~1 hour of charging time, Case: ~1 hour of charging time
Operating and Storing Environment
  • Operating Temperature: 32°F - 104°F (0ºC - 40ºC) with 85% Relative Humidity
  • Storage Temperature: -13°F - 131°F (-25ºC - 55ºC)
Wyze Buds
  • Wyze Buds x1
  • Charging Case x1
  • USB Type-C Cable x1
  • Silicone Ear Tips x5 (5 Sizes)
  • Quick Start Guide x1
Wyze Buds Limited Edition (SOLD OUT)
  • Wyze Buds Limited Edition x1
  • Charging Case x1
  • Silicone Ear Tips x5 (3 Sizes)
Wyze Buds provide you with your everyday needs, like longer battery life and a more compact case. Wyze Buds Pro is an upgraded model, with premium features like Active Noise Cancellation (ANC) and wireless charging.
Yes, you can use a single earbud for your music and calls. You will need both earbuds to update your Wyze Buds settings in the Wyze app.
Up to 27 hours. The earbuds provide up to 7 hours of playback time on a single charge. The charging case provides up to 20 hours of music playback time.
Yes, Wyze Buds come with 5 sizes of silicone ear tips to fit your ears comfortably.
Yes, you only need a Bluetooth connection to use the earbuds. If you want to use more advanced features, like customizing the EQ, touch controls, and setting up your voice assistant, you'll need the Wyze app.
No, Wyze Buds can only connect to one device at a time. You can switch devices by pressing the Pairing button on the charging case. Wyze Buds can remember up to 8 devices.
Yes, Alexa is built-in to the buds. The feature is optimized for Android, though. If on iOS, you must force close the Wyze app and keep the Amazon Alexa app running in the background to use Alexa.
Download the Wyze app, and click the + plus sign > Add Device > Lifestyle > Wyze Buds. Follow along in the app to set up your new earbuds.
Yes, tune Wyze Buds to your liking by adjusting the equalizer in the Wyze app. Create and save your own custom preferences or choose pre-made selections that optimize for music, movies, voices, gaming, and more.
Yes, customize the touch controls for your Wyze Buds in the Wyze app.
Transparency Mode lets you hear the surrounding environment as if you are not wearing your earbuds. Listen to your family or safely listen to music near traffic.
Wyze Buds produce stereo sound.
Lithium ion battery.
We don’t recommend it. The charging case is molded for Wyze Buds with the original ear tips. Third-party ear tips may not fit into the charging case.
No, Wyze Buds can only be charged with a USB-C cable. If you are looking for earbuds with premium features like wireless charging, check out our Wyze Buds Pro!
Yes, Wyze Buds can connect to Bluetooth-capable devices like gaming consoles and computers. But be sure to check your other device’s compatibility.
WyzeBuds BannerImage
10.5mm audio drivers deliver bone-rocking bass from lace up to cool down.
Wyze buds are engineered to deliver an intensified, bass-driven sound to help propel you toward your fitness goals.
30dB passive noise reduction keeps the noise out and the music in.
A unique ear-gonomic fit provides up to 30 decibels of noise reduction so you hear more of what you want and less of what you don’t.
Illustration of person wearing Wyze buds.
WyzeBuds silicon tips.
Choose the perfect fit so you can keep moving.
Up to 27 hours of charge. Guaranteed to outlast almost any workout.
With up to 7 hours on a single charge plus 20 hours in the case you get battery life so long your play button might get tired.
A black case with a white label that says Wyze.
A woman wearing a purple hoodie is holding a pair of earbuds in her hand.
Keep moving with phone-free touch controls.
Keep the interruptions to a minimum with customized smart touch controls that don't skip a beat. Tap twice to play/pause. Tap three times to activate the voice assistant.
A woman wearing a black tank top and sweating while exercising.
Person holding phone looking at Wyze buds in the Wyze app.
A woman wearing a blue tank top and holding a WyzeBuds Pro in her hand.
A woman wearing a blue jacket and holding a cell phone to her ear.
More smart features. Wear detection for hassle-free stops and starts
An embedded sensor auto-detects when it’s in your ear and knows what to do when it’s not.
IPX5-rated moisture resistance can withstand sustained perspiration from crossfit to marathons and everything in between.
Tune Wyze Buds to your liking by adjusting the equalizer in the Wyze app. Create and save your own custom preferences or choose selections that are optimized for music, movies, voices, gaming, and more.
A 4-microphone system let's you hear the world around you with a simple touch.
Instantly connect to Amazon Alexa to play your favorite music, check the weather, get news, and more. Wyze Buds are also compatible with your phone’s native smart assistant (Siri, Bixby, Google Assistant).
* Optimized for Android. iOS requires the Alexa app in the background.
  • Wyze Buds are wireless earbuds with a black design.
    Wyze Buds
    -30 dB passive noise reduction
    -Up to 27 hrs of battery life
    -4-microphone system
  • A pair of black earbuds with a touch of gray.
    Wyze Buds Pro
    -40 dB active noise cancellation
    -6 microphone system
    -Wireless charging
    Learn More
