Shop nowSolar Cam Pan 2K
- Solar Powered
- 360° Pan + 70° Tilt
- AI Person Tracking Included
Shop nowVideo Doorbell
- Battery-Powered
- MicroSD Card Slot
- Color Night Vision
Shop nowBulb Cam
- 2K 160˚ FOV
- Group Lighting Control
Shop nowLock Bolt v2
- BHMA Grade 2 Security
- Fingerprint Recognition
- 8 Months Battery Life
Shop nowDuo Cam Pan
- 2K Video Resolution
- Two Cameras, Two Views.
- 360˚ x 180˚ Pan-Tilt Range
Shop nowPalm Lock
- Palm Vein Recognition
- Wi-Fi Control
- Auto Lock Gyroscope
Shop nowScale X
- Full-Glass ITO Sensors
- 22-Month Battery Life
- 13 Body Composition Metrics
Shop nowCam v4
- 2.5K QHD Resolution
- Enhanced Color Night Vision
- Motion-Activated Spotlight
Build your smarter home.
Trusted by over 12 million households
Indoor/Outdoor & Wire Free
Battery Powered Cam
"I’ve been using the Wyze Wireless Outdoor/Indoor Battery Security Camera for a few weeks now, and overall, I’m impressed. The 2K video quality is sharp, and I love the color night vision—it really helps identify people and objects clearly after dark. Setting it up was super easy, and I appreciate that it works both indoors and outdoors without needing a base station."
RV P.
Over 1,000 Amazon Reviews
2k Dual Cameras
“I really have been enjoying the new doorbell. I like the duo cameras, makes it easy to see when packages or groceries are dropped off, puts me at ease. The image is very clear, I would say the clarity is way better than my old ring doorbell. Over all I do recommend this doorbell especially if you already own other wyze products, this would integrate nicely with your wyze ecosystem.”
Fernie J
4.5 Rating on Amazon
Fast Palm Reader
“The Wyze Palm Door Lock delivers cutting-edge convenience with its lightning-fast palm recognition and seamless smart home integration. Its sleek design, effortless installation, and precise biometric accuracy make it a standout choice for secure, keyless living combining innovation, reliability, and style in one compact device.”
RBurra
Why Wyze?
