Skip to content
1 of 15
Wyze Video Doorbell v2
2K Wired Smart Doorbell
Style
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
$59.99CAD
Answer your door from anywhere with our clearest and most capable wired video doorbell yet. Wyze Video Doorbell v2 gives you 2K video and local microSD storage, so you can capture every moment in more detail than ever. Plus, get video doorbell essentials like two-way audio, real-time alerts, and motion-activated voice deterrence.
    2K Video Resolution
    Capture all porch arrivals and departures with greater detail than ever.
  • A black and white image of a clock with a small arrow pointing upwards.
    24/7 Recording with MicroSD
    Don't miss a thing with continuous local recording.
  • A black and white image of a bell.
    Works with Existing Doorbell Chime
    No more bypassing your home's existing chime when you upgrade to a smart doorbell.
    Motion-Activated Voice Prompt
    When enabled, a voice prompt plays to alert visitors that they're being recorded.
    Note: Cam Plus or Cam Protect subscription is required for this feature.
Wyze Video Doorbell v2 Specs
Color & Materials
  • Color: Black
  • Body: Polycarbonate
  • Lens: Resin
  • Sensor: CMOS Starlight Sensor
Dimension
  • 4.3in x 1.7in x .9in (110mm x 44mm x 24mm)
Video
  • Resolution: 2K (2048 x 1536)
  • Video Format: H.264
  • Sensor Size: 1/2.8"
  • Aperture: F2.0
  • Focal Length: 2.1mm
Frame Rate
  • Day: 20FPS, Night: 15FPS
Field-of-View
  • Horizontal: 135°, Vertical: 103°, Diagonal: 166.8°
Power
  • 16V-24V AC,≥10VA
Audio
  • Microphone: ECM (Electric Condenser)
  • Speaker: 8Ω 1W,Box
Additional Details
  • Zoom: Digital Zoom
  • Flash: 16MB
  • Memory: 128MB
  • CPU Clock Frequency: 1.5GHz
  • IR Light: 6 x 940nm IR lights
Storage
  • MicroSD card: Up to 256G in FAT32 format
  • Cloud: When paired with a Wyze Security Plan
Important Note
  • A 16V 10VA transformer sits at the lower end of the power supply spectrum. Aging and wiring conditions could affect its efficiency in powering the Video Doorbell v2 or ringing a mechanical chime. Please check your transformer and wiring before purchasing.
Connectivity & Compatibility
  • IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
  • Chime compatibility checker
Weather & Temperature
  • IP65 weather resistant
  • Operating temp: -4°F - 122°F (-20°C - 50°C)
  • Storage temp: -40°F - 176°F (-40°C - 80°C)
Certifications
  • FCC, IC, UL, CA65, ROHS, REACH, and IP65 Certified
Languages
  • English
Warranty
  • 1-Year
  • 1x Wyze Video Doorbell v2
  • 1x Wyze Chime Controller Unit (Click here to check compatibility)
  • 1x Wall Plate
  • 1x Wedge (30°)
  • 1x Installation Kit
  • 3x Wire Caps
  • 2x Extension Wires
  • 1x Screw Kit
  • 2x Long Screws
  • 2x Short Screws
  • 2x Wall Anchors
  • 1x Quick Start Guide
Wyze Video Doorbell v2 is a true upgrade from our original wired doorbell, delivering some of our most requested features in a new, shiny black package. It comes with cloud and local storage (up to 256 GB) for 24/7 continuous recording, 2K resolution with an even larger diagonal FOV of 166.8º, and it now supports your own in-house chime.
Don't forget to remove your old device and the fuse wire inside your chime box before installing your new Wyze Video Doorbell v2. Otherwise, your chime may not ring!
No, Wyze Video Doorbell v2 is hardwired and does not use batteries.
Yes, Wyze Video Doorbell v2 works with most in-house mechanical chimes! However some custom, vintage, and high-end chime kits may not be compatible.
Yes, you can still use this doorbell without an in-house chime. Though even without a functioning chime, we highly recommend installing the included Wyze Doorbell Chime Controller to keep your new doorbell running smoothly.
When enabled, a voice prompt plays to alert visitors that they're being recorded. You will need either a Cam Plus or Cam Protect license to be able to use this feature. Open the Wyze app > Home > Select your Video Doorbell v2 device > Settings (cog icon) > Detection Settings > Motion Warning. You will not see this functionality if your camera does not have a Cam Plus or Cam Protect license attached to it.
The FOV is 135° horizontal, 103° vertical and 166.8° diagonal.
No, Wyze Video Doorbell v2 comes with a Chime Controller, which works with your existing in-house chime.
No, the original Wyze Chime does not work with Wyze Video Doorbell v2.
Wyze Video Doorbell v2 provides 12-second video clips when the doorbell is pressed, and if the microSD card is ejected unexpectedly. All other events will generate a snapshot. For full-length event videos, and so much more, subscribe to Cam Plus or Cam Protect.
Yes! Use your smart hubs to view live video feeds of people at the door on your Echo Show and Google Home devices. For a complete breakdown of what functionality is available with Alexa or Google please take a look at this support article.
Of course! We have a range of installation and setup articles for the Video Doorbell v2 over on our support site
While we try to make sure the overall installation of Wyze Video Doorbell v2 is easy we understand that it's complex and there are many elements to consider between the camera unit, controller, chime box, and transformer. Troubleshooting can be frustrating but please take a look at our support articles for common issues and suggested solutions over on our support site.
Enjoy crystal-clear 2K video.
Head-to-toe viewing and immaculate 2K resolution means you can capture all porch arrivals and departures in more detail than ever.
A man in a yellow vest is holding a box.
A person is holding a video doorbell.
24/7 local recording with microSD card.
The first-of-its-kind onboard microSD card slot allows for continuous local recording. So you can stop wondering what happened before or after the doorbell press.
A person is holding a black device with the word "WYZE" on it.
Works with your home's existing chime.
No more bypassing the existing chime when you upgrade to a smart doorbell. A chime controller is included so you can keep ding-donging the old fashioned way.
Learn more with our chime compatibility check.
Two-way talk.
Quickly respond to visitors by pressing the "talk" button in the Wyze app.
A video doorbell is attached to a white door.
A person is standing in front of a doorbell.
Nothing says, "Don't try any funny business" quite like an automated voice prompt that alerts visitors they're being recorded. Simply enable this feature in the Wyze app.
A boy wearing a helmet is skateboarding in front of a house.
Pre-roll motion recording.
The wired power setup enables 3-6 seconds of pre-roll recording for motion events, so you'll capture the scene before the motion starts.
A man is holding a box in front of a doorbell.
A black smartphone with a blue circle on the front.
IP65 weatherproof.
Rated to withstand any weather. Especially, the "it's raining packages which means my partner maxed out the AMEX again" type of weather. That's the worst weather.
A man wearing a hoodie is standing on a porch holding a box.
Night as clear as day.
A white doorbell with a picture of a person on it.
A black video doorbell with a blue circle on the front.
A smartphone app with a video doorbell.
A smartphone screen displaying a video doorbell.
An angled mounting wedge is included with every doorbell to help you achieve the perfect view.
Use preset quick responses to have the doorbell say things like: "Be there shortly" or "Leave the package at the door."
Leave no dong un-dinged.
Here's a fancy pants recap of why Wyze Video Doorbell v2 is the best smart video doorbell around.
Compare Doorbells
Compare Doorbells
from $59.99 $84.98
Resolution
2048 x 1536 (2K)
Field-of-View
H: 135°, V: 103°
Chime
Existing
Power Option
Wired Only
3P Integration
Amazon Alexa, Google Home
Storage
Local & Cloud
View
