Skip to content
1 of 14
Wyze Cam OG
Wyze Cam OG
1080p Cam with Spotlight & Night Vision
Color
SALE
$29.98 $39.99CADSAVE 25%
The 2023 generation of Wyze Cam has arrived. Now with quicker live-streaming, 3X faster notifications, improved 2-way audio, and a built-in spotlight. Indoor/outdoor*.
*For safe outdoor use, OG cameras require a Wyze Outdoor Power Adapter v1 or v2 (sold separately). Please note: The OG Stack Kit does not work with our Outdoor Power Adapters.
Wyze Cam OG
Looking for telephoto?
For 3X zoom, check out Wyze Cam OG Telephoto.
Shop now
  • Owl in front of color wheel icon
    1080p HD Color Night Vision
  • Rain cloud with the sun behind it
    IP65 Indoor/Outdoor Security
  • Bright spotlight
    Built-In Spotlight with Integrated Siren
  • MicroSD card with arrows that represent continuous recording
    24/7 Recording to Wyze microSD Card
    No subscription required.
Wyze Cam OG Specs
Color & Materials
  • Color: White or Black
  • Finish: Matte
  • Image Sensor: CMOS-Starlight Sensor (1920 x 1080)
  • 2 spotlight (5000K, 40 lumens)
Dimensions
  • 1.89 in x 1.89 in x 1.89 in (48 mm x 48 mm x 48 mm)
Weight
  • 4.1 oz (116 g)
Power
  • Power Adapter: Input - 110-240V (AC/DC) Output - 5V/1A
Built-in Spotlight
  • 40 Lumens
Video
  • Video FPS: Daytime - 20 FPS Nighttime - 15 FPS
  • Video Encoding: H.264
Additional Details
  • Power Cable Length: 6 ft (1.8 m)
  • Ports: 1 micro USB
  • Night Vision: 4 IR LEDs (850nm)
  • Digital Zoom: 8x
  • Field-of-View-OG: 121.4°(DFOV), 102.3°(HFOV), 54.1°(VFOV)
  • Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
  • Local Storage: Supports up to 256 GB microSD in exFAT format
Connectivity & Compatibility
  • 802.11 b/g/n, 2.4 GHz Wi-Fi
Weather & Temperature
  • Weather Resistance: Indoor and Outdoor (IP65)
  • Operating: -4°F - 131°F (-20°C - 55°C)
  • Storage: -40°F - 158°F (-40°C - 70°C)
Language
  • English
Warranty
  • 1-Year
View our Wyze Cam Comparison Chart
Note: There may be slight differences in appearance depending on which camera model you receive. The product functionality is identical.
The latest 2025 model number is WYZECGSD on the box. The previous model number is WYZECGS.
Wyze Cam OG (Standard / Telephoto):
  • Camera
  • Indoor Power Adapter
  • USB Cable
  • Wall Anchors
  • Wall Plate
  • Mounting Screws (M4)
  • Quick Start Guide
Wyze Cam OG Stack Kit:
  • Stack Mount
  • Dual Micro USB Power Cable (6ft)
  • 5v/1.5A Indoor Power Adapter
  • Quick Start Guide
There are two key differences: The telephoto camera has a 3x telephoto lens, while the standard OG camera has an integrated spotlight. Both are great cameras with all of the features you know and love. Use Wyze Cam OG to monitor your home with a wide angle lens. Use Wyze Cam OG Telephoto to clearly monitor points-of-interest that are further away.
Yes, both cameras can be used as standalone cams. But we like using them both together - you get the OG’s integrated spotlight, Wyze Cam OG Telephoto’s closer details, and the ability to view the livestream of both cameras at the same time.
No, Wyze Cam OG is not wireless or battery powered. It is powered via the included 6 ft USB cable.
Yes, Wyze Cam OG is IP65-rated and can be used both indoors and outdoors.
You can stack 2 total cameras together, in any combo! That could be a Wyze Cam OG and a Wyze Cam OG Telephoto, or two Wyze Cam OG cams, or two Wyze Cam OG Telephoto cams.
1920 x 1080p Full HD.
Day: 20 frames per second (fps); Night: 15 fps.
No, Wyze Cam OG only supports 2.4 GHz networks.
Wyze Cam OG is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night.
Yes, Wyze Cam OG is compatible with Wyze Web View.
Yes, the telephoto cam can be used as a standalone camera, without a Wyze Cam OG. But we like using them both together - you get the OG’s integrated spotlight, Telephoto’s 3x closer details, and the ability to view the livestream of both cameras at the same time.
Yes, Wyze Cam OG Telephoto is IP65-rated and can be used both indoors and outdoors, rain or shine.
Day: 20 frames per second (fps); Night: 10 fps.
No, Wyze Cam OG Telephoto only supports 2.4 GHz networks.
Yes, Wyze Cam OG Telephoto is compatible with Wyze Web View.
Only Wyze Cam OG and Wyze Cam OG Telephoto have Picture-in-Picture functionality.
Yes. You can use Picture in Picture to view two Wyze Cam OGs or two Wyze Cam OG Telephoto 3x cameras at the same time. It is not limited to only Wyze Cam OG + Wyze Cam OG Telephoto viewing.
No, neither camera is compatible with Cam Plus Lite. Cam Plus Lite only supports cameras released during or before April 2022.
No, only Wyze Cam OG has a spotlight.
No. The Wyze Cam OG Stack Kit is a useful way to mount any two Wyze Cam OG or Wyze Cam OG Telephoto cameras on top of each other and use a single outlet to power them both. The Picture-in-Picture feature is a software feature and does not require the physical stack kit to work.
The Wyze Stack Kit includes a USB Cable Splitter, a Power Brick, and Stack Mount that allows you to power and stack-ably mount two Wyze Cam OGs or Wyze Cam OG Telephoto Cameras on top of each other.
Yes. Both cameras take all Wyze microSD cards up to and including 256GB microSD cards.
Two white cameras on a table.
Independently amazing.
Upside down or right side up each camera operates on its own to cover every angle of any space.
Smartphone camera with Wyze app notification on it.
3x faster motion notifications.
A speaker with a microphone on a wall.
Upgraded two-way audio.
Person holding a smartphone with a live video stream of their dog.
  • Smartphone with livestream video open on the screen. White text overlay of local microSD card storage features: timeline, calendar view, continuous recording, and timelapse..
    Supports all Wyze microSD cards, up to and including 256GB.
  • Smartphone with detected events on the screen. White text overlay of Cam Plus features: Unlimited cloud storage, smarter notifications, and advanced detection of people, packages, vehicles, and pets.
Cam OG's live view inside the Wyze app.
A smartphone displaying a live view of a home.
Cam OG's playback timeline with labelled events inside the Wyze app.
Cam OG's detection zone settings inside the Wyze app.
Cam OG's smoke and carbon alarm settings inside the Wyze app.
A smartphone screen with a setting for alarm sounds.
A brand new app experience.
Unlike a stray Lego brick at 1 am, we've put all the handy tools exactly where you'd want them–from spotlight and siren controls to the new simplified event review.
Enjoy a new, easy-to-scan Recent Events section to quickly navigate footage.
Tell Wyze Cam OG exactly where you want it to watch. Get notifications only for detections within your customized zone.
  • 3D render of Wyze Cam OG security camera against a white background.
    Wyze Cam OG
    • 120° Field of View
    • Built-In Spotlight with Color Night Vision
    • IP65 Weatherproof
    • Two-Way Audio
    • Works with Wyze Cam OG Stack Kit
  • 3D render of Wyze Cam OG Telephoto security camera against a white background.
    • 3x Telephoto Camera (27° Field of View)
    • Color Night Vision
    • IP65 Weatherproof
    • Two-Way Audio
    Learn More
