1 of 7
Wyze Thermostat
Wyze Thermostat
Programmable Wi‑Fi Thermostat with Energy Reports
$129.99CAD
Smart heating & cooling - simplified.
  • Streamline force touch double tap
    Control from the app
    Manage your thermostat from anywhere with the Wyze app
  • A black background with a white microphone icon.
    Works with voice assistants
    Adjust your thermostat with your voice using Alexa & Google
  • A black background with a white clock icon.
    Simple, daily scheduling
    Set daily schedules for waking up, sleeping, and more
  • Wyze Sprinkler Icon 3
    Energy usage tracking
    Receive energy saving tips based on usage history
Wyze Thermostat Specs
Check Compatibility here.
Color & Materials
  • Color: Black and white
  • Body and back panel: PC+ABS
  • Faceplate: PMMA
Dimensions & Weight
  • Thermostat: 120mm (L) x 65mm (W) x 33mm (D)
  • Wall Cover: 165mm (L) x 140mm (W)
  • Weight: <1lb
Display
  • IPS Display
  • 180º Viewing angle
Power
  • Power source: 24VAC through C terminal
  • C-wire adapter included
  • Power consumption: <3.5VA
Weather & Temperature
  • Weather resistance: Indoor use only.
Operating
  • 32°F - 130°F (0°C - 55°C)
  • 5% - 95% RH (non condensing)
Storage
  • -31°F - 113°F (-35°C - 45°C)
Connectivity & Compatibility
  • Bluetooth
  • 2.4GHz WiFi
  • Integrations: Alexa and Google Assistant
Environmental Information
  • Certifications: FCC, IC, and California Proposition 65
  • Eco-Friendly: Recyclable packaging
  • Mercury-free
  • Arsenic-free
  • PVC free
Languages
  • English
Warranty
  • 1 Year
  • Wyze Thermostat x1
  • C-Wire Adapter x1
  • Back Panel x1
  • Mounting Plate x1
  • Wall Cover x1
  • Wall Screws x2
  • Wall anchors x2
  • Mounting Screws with anchors x2
  • Wire Label Sheet x2
  • Screw Driver x2
  • Quick Start Guide x1
Yes, Wyze Thermostat will continue operating based on the last updated schedule. You can also control your temperature or change the status from the thermostat itself.
No, not at this time. We're working towards qualifying for ENERGY STAR approval for Wyze Thermostat.
About 30 minutes! And all the tools you need are included in the box, though a power drill might be helpful.
Wyze Thermostat works with Alexa, but it does not have an internal speaker and Alexa is not built-in. You'll need to own an Echo speaker (or another device with Alexa) to control your thermostat with your voice.
No, the thermostat does not work with electric baseboard heating, which is a high voltage (120V or 240V) heating system. Wyze Thermostat was made to control low voltage (24V) heating systems only.
Yes, the C-wire powers Wyze Thermostat. Don’t have a C-wire? We’ve included a C-wire adapter in the box.
Check your voltage! Wyze Thermostat is compatible with low voltage (24V) systems such as forced air, hydronic, heat pump (including dual fuel), oil, gas and electric. It is compatible with most single-stage and multi-stage conventional and heat pump heating and cooling systems.
No, the thermostat will not work if the electricity goes out. It will automatically reconnect and resume its schedule once power returns.
Yes, using the Rules feature in the Wyze app.
If your 2 thermostats are controlling 2 different HVAC systems, then yes. You can use 2 Wyze Thermostats to control each system.
A person holding a phone with a temperature reading of 68 degrees.
Adjust your thermostat on the go...
No matter where you are in the world, you’re always just a few taps away from dialing in the perfect temperature.
• Arrive home to the perfect temperature
• Save Energy
• Keep pets comfortable
• Prevent frozen plumbing
...or from the comfort of your couch
Works with voice assistants. When your morning coffee and blanket aren’t cutting it, adjust the thermostat with your voice by asking Alexa or Google Assistant.
A woman sitting in a chair with a cup in her hand.
A woman in a red sweater is sitting in a chair, holding a cup.
A white thermostat with a black face and a black button.
A room sensor is sitting on a shelf.
Person holding phone with wyze open to sensor settings.
Person placing room sensor on dining room table.
Comfort in every room with Wyze Room Sensor.
Save energy. Stay comfortable. Remotely view the climate of any room.
Rid your home of hot and cold spots by placing Wyze Room Sensors in important rooms and letting Wyze Thermostat balance your home's climate.
When Motion-Sensing Comfort Mode is enabled, Wyze Room Sensor uses motion detection to prioritize only the rooms you're actually using. Save energy and stay comfortable without ever thinking about it.
Monitor the temperature of your baby's room upstairs or your furry friends down the hall. Quickly adjust the climate with just a few taps in the Wyze app.
Easily pair and place up to 6 Wyze Room Sensors throughout your home in minutes. Wall mount for easy viewing or use the included magnetic table stand.
Schedule your day with Wyze Thermostat
Simple, daily scheduling. Create schedules for every weekday and weekend so you don’t have to keep going back and forth to your thermostat.
A man sleeping in bed with a blue blanket.
6:59 AM
You’re moments away from starting the day.
Wake up to a warm welcome - your home has been heating for the last 15 minutes.
A person walking out their front door.
7:30 AM
You’ve completed your mad dash out the door.
Avoid warming an empty house - your home automatically turns heating off, saving you money on energy bills.
A woman wearing a green shirt is hanging up her coat.
6:00 PM
You’re home after a long day of saving the world.
Arrive home to the perfect temperature - your house began warming up as you left work.
A woman is reading a book in bed.
10:30 PM
You’re on the last chapter and ready for bed.
Enjoy the most comfortable sleep of your life - Your home cools down as you slip under the comforter.
A blue screen with a thermostat on it.
Unscheduled moments?
Wyze Thermostat covers those, too.
Temporarily interrupt any schedule by opening the app and adjusting your temperature on the fly. Your schedule will resume upon its next start time.
A thermostat with a blue and orange display.
Receive energy-saving tips based on usage history
We’ll do the thinking for you. Like an energy-saving gnome inside your phone, the Wyze app will recommend actionable insights based on your usage to help reduce wasted energy.
No learning curve for temperature control
Easy control for guests and family. Adjusting the temperature is as straightforward and intuitive as walking to the wall and turning the dial.
Hand holding a thermostat.
A 20-minute DIY installation that anyone can do
Installing a new thermostat is easier than you might think. The Wyze app guides you through the installation process, step-by-step.
Support Articles
Installing your Wyze Thermostat should be a quick, 30-minute process. If you've confirmed that your HVAC system is compatible using the Compatibility Checker, follow the steps below and in the video to get started. Important: Don't feel prepared or safe to install your own thermostat? We've designed Wyze Thermostat to be easy to install, but use your own judgment. If you're in doubt, stop. Call your local HVAC technician for assistance.
To set up your Wyze Thermostat:
  3. Tap Home > Wyze Thermostat.
  4. Tap Begin Preparation.
  5. Follow along in the app, and with the video below.
    With your Wyze Thermostat installed and powered on, it's time to finish setting it up in the Wyze app!
  6. Make sure your phone/tablet’s Bluetooth is enabled.
  7. The Wyze app will automatically begin searching for and pairing with your Wyze Thermostat. Be sure to keep your phone near the thermostat.
  8. Once paired, you will be prompted to enter your Wi-Fi name and password.
  9. You’re connected! To finish up, name your new thermostat and begin customizing your settings.
Additional Notes:
  • You may have to enable Location Services on your device to use Bluetooth.
  • Wyze Thermostat is only compatible with 2.4 GHz Wi-Fi networks.
Download the Quick Start Guide for Wyze Thermostat here.
Below is the Quick Start Guide for Wyze Thermostat, a short manual on how to get started.
This guide is a short user manual with the basics about Wyze Thermostat, including:
  • What's in the box for Wyze Thermostat.
  • A diagram of WyzeThermostat.
  • How to install Wyze Thermostat.
  • A diagram of Wyze Thermostat.
  • How to set up Wyze Thermostat.
Hands off the thermostat!
With Schedules, you can program your thermostat settings for one week, each individual day of the week, any group of days, or a few hours at a time. You can go even further to customize the temperature of a specific time period without changing any other time slots.
To create a schedule for Wyze Thermostat:
  1. In the Wyze app, tap on your Wyze Thermostat.
  2. Tap on the Settings gear on the top right.
  3. On the Settings screen, tap Schedule > Create schedule.
  4. On the Edit Schedule screen: Tap the day(s) you want your schedule active under Repeats.
    Create schedules for Home, Away, and Sleep under Blocks > Add block.
    If you add a Home block, that schedule will only apply when your thermostat is in Home mode.Tap Save to save your new block.
  5. Tap Save to create your schedule.
To delete a schedule for Wyze Thermostat:
  1. In your Wyze Thermostat Settings, tap Schedule.
  2. Swipe left on the schedule you want to delete, then tap the trashcan icon.
FREE shipping on orders $0+
