1 of 11
Wyze Duo Cam Pan
Wyze Duo Cam Pan
Two cams. Two views. Zero blind spots.
Wyze Duo Cam Pan (Quantity)
Add ons
    $79.98CAD
    FREE shipping on orders $99+
    $0.00 FREE / 1 month
    14-Day Cloud Storage
    Subscriber Discount
    Wyze Duo Cam Pan delivers two 2K cameras in one device for complete coverage. One stays fixed on your priority view while the other pans and tilts to track motion, with color night vision, spotlights, siren, and indoor/outdoor versatility.
    Outdoor use requires Wyze Universal Outdoor Power Adapter.
      Two Cameras. Two Views.
      One fixed + one pan and tilt cam eliminate blind spots.
      2K HD Resolution + Color Night Vision
      See every detail clearly in vibrant color, day or night.
    • An icon for the IP65 page.
      Indoor/Outdoor Security
      Place it anywhere with IP65 weather resistance.
      Two Motion-Activated Spotlights
      Automatically trigger the LED light and voice prompt for extra security.
    Wyze Duo Cam Pan Tech Spec
    Colors & Materials
    • Colors: White
    • Finish: Textured Matte
    • Body: Polycarbonate
    • Lens: Glass + Plastic
    • Lens FOV: DFOV 127.5°, HFOV 106°, VFOV 56.5° (Fixed), DFOV 127.5°, HFOV 106°, VFOV 56.5° (PT)
    • Image Sensor: 1/2.8'' CMOS (Fixed)
    • 1/2.8'' CMOS (PT)
    • LED Indicator: Front. Red + Blue.
    Dimensions & Weight
    • 2.36in x 2.16in x 5.26in (64mm x 54.9mm x 133.5mm)
    • 0.66lb (300g)
    Mounting
    • Stand, wall mount, ceiling mount.
    View Range
    • 360° horizontal, 180° vertical
    Power
    • Power Adapter: Input 110-240 V (AC/DC), Output 5V/1.5A
    • Compatible Outdoor Power Adapter (sold separately and coming soon)
    • Cable: 6-Foot Flat Type-C to USB-A
    Video
    • Resolution: 2K (2304*1296)+ 2K (2304*1296)
    • Wide Dynamic Range (WDR): Yes
    • IR Lights: 4x850 nm
    • Day/Night Vision: Yes
    • Night Vision: 4 IR LEDs (850 nm) + 4 white spotlight LEDs ( 80 lumens)
    • Color Night Vision: Yes
    • Video Encoding: H.264
    • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
    Audio
    • Speaker: 100dB, waterproof
    • Simultaneous 2-way Talk: Yes
    • Built-in Siren: Yes
    • Noise & Echo Cancellation: Yes
    Connectivity & Compatibility
    • Bluetooth® 5.0
    • Wi-Fi: 2.4 GHz Wi-Fi, Wi-Fi 6
    • Phone Compatibility: Android 10+ and iOS 16+
    Storage
    • Local (microSD card required)
    • MicroSD card up to 512 GB
    • Cloud (with subscription plan)
    Weather & Temperature
    • IP65 weather-resistant
    • Operating temp: -4ºF - 113ºF (-20ºC - 45ºC)
    • Storage temp: -22°F - 158°F (-30°C - 70°C)
    Language
    • English
    Warranty
    • 1-Year
    • Wyze Duo Cam Pan x1
    • Quick Start Guide x1
    • Mounting Kit x1
    • USB-C to USB-A Cable (6-foot, flat) x1
    • Indoor Power Adapter (5V, 1.5A.) x1
    Two cameras. Two views.
    One stays steady while the other one moves. Cover two areas with a single device for maximum coverage.
    Keep your head on a swivel with 360° pan and 180° tilt.
    Never miss the action with auto motion tracking. Crystal-clear 2K clarity on both cams capture every detail.
    A black door with a light switch on it.
    Integrated Spotlights + Siren
    More safety at night.
    A Wyze Duo Cam is mounted on a wall, showing a view of a house and the sky.
    ip65 weather resistance
    Place it anywhere.
    Wyze Duo Cam Pan is IP65 weather-resistant, so it can operate in any weather.
    Note: Outdoor use requires Wyze Cam Universal Outdoor Power Adapter (sold separately, learn more).
    A Wyze Duo Cam is mounted on a wall.
    Enhanced two-way talk
    Clearer conversation.
    Forget the days of sounding like you’re talking through tin cans. Advanced Audio Coding (AAC) and a revamped mic give our best audio experience yet.
    A white and black camera with a sun in the background.
    Record every second
    24/7 Recording with MicroSD Card.
    Record 24/7 locally with a microSD card up to 512 GB (sold separately). Add AI alerts and cloud backup with Cam Plus.
    See it in action.
    And check out the unboxing video to see more magic.
    Wyze Duo Cam Pan with WDR
    No WDR
    A panoramic camera is mounted on a house.
    Full coverage
    Double the coverage. No blind spots.
    It's especially effective when placed near a corner. Keep a fixed watch on the driveway, and at the same time follow the action if it moves to the backyard.
    A woman is holding a smartphone with a home monitoring app on the screen.
    Connect with bluetooth®
    Easy to set up.
    No need to scan QR codes. Enjoy hassle-free setup with Bluetooth®. We'll get you up and running within minutes.
    Wyze Duo Cam Pan Shopify 07
    Plug it in and go
    Versatile mounting.
    Four unique mounting options gives you the flexibility to secure your space exactly how you need to.
    A Wyze Duo Cam Pan is displayed on a table.
    Works with smart assistants
    Convenience and customization at your fingertips with integrations like Amazon Alexa, Google Assistant, IFTTT, and Wyze Automation.
    Patrol your room with Pan Scan.
    Set the camera’s patrol route with up to 4 custom waypoints.
    A map of a bathroom with a green arrow pointing to the Waypoint.
    A garage door with a green circle around it.
    Even more features to love.
    Look & listen for motion & sound. Wyze Duo Cam Pan sends your phone an alert and begins recording when either is detected.
    Receive an alert the moment Wyze Duo Cam Pan hears a Smoke or CO alarm go off. Wyze Cam records a video during this time.
    Support Articles
    Before you begin setup:
    2. Connect your device to a 2.4 GHz Wi-Fi network, and enable BluetoothⓇ.
    3. Unpack your Wyze Duo Cam Pan box, removing all plastic and packing materials.Be sure to remove the plastic film from each lens.
    To set up your Wyze Duo Cam Pan:
    3. Tap Cameras > Pan and Tilt Camera > Wyze Duo Cam Pan.
    5. Underneath the camera, single-press the SETUP button. It will say “ready to connect”.
    6. In the app, check the box next to I heard, “Ready to connect”.
    7. Tap Begin Setup.
    8. If BluetoothⓇ hasn't been enabled, you will be prompted to allow BluetoothⓇ access. Tap Okay.If BluetoothⓇ has already been enabled, it will skip to the next step.
    9. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.Tap the icon in the password field to display the password to ensure it was entered correctly.
    10. Your device will begin connecting.
    11. Once connected, you will be prompted to begin mounting.If you want to mount your camera now, tap Begin Mounting and follow along in the app.If not, tap Skip.
    12. Name your camera using the text field, or by choosing a suggestion.
    13. Tap Finish when done.
    14. Choose between the Basic plan (no subscription) or Cam Plus. Tap Continue.
    15. Set up some automations on the Things to Try* page, or tap Skip.
    16. Enjoy your new Wyze device!
    👉 Haven't set up your Wyze Duo Cam Pan yet? Check out Wyze Duo Cam Pan Setup Guide before installing.
    There are 4 ways to mount your Wyze Duo Cam Pan:
    • On a tabletop or flat surface.
    • On a wall, right-side up.
    • On a wall, upside down.
    • On a ceiling, upside down.
    To mount your camera on a flat surface:
    1. Set your camera on a flat surface.The fixed camera must be down, camera right-side up.We recommend mounting it on a horizontal surface, not angled.We recommend mounting it at the edge of the surfaceYou do not need to use the mounting kit.
    To mount your camera on a wall:
    1. Place the Mounting Sticker from the Mounting Kit where you want to install your camera.
    2. Mark your drill holes with a pencil.
    3. Use a 6mm drill to drill holes at the pencil marks.The holes must be 1/4 inches and 1 and 3/6 inches deep.
    4. Insert the included expansion tubes into the holes.
    5. Place the Wall Plate over the expansion tubes*, then screw into the expansion tubes to mount the wall plate. To mount right-side up, place the Wall Plate on the tubes with the tab pointing up. To mount upside down, place Wall Plate on the tubes with the tab pointing down. To use the camera, you will have to toggle on Rotate Image 180° in your Advanced Settings.
    6. On the camera, pull the bracket away from the base. If the screws on the camera's bracket are loose, tighten them before continuing. To mount right-side up, place the base onto the wall plate and firmly press down. To mount upside down, place the base onto the wall plate and firmly press up.
    7. Insert the power cable into the camera, then plug the USB end into the adapter.When powered, the status light on the camera will light up.
    To mount your camera on the ceiling:
    5. Place the Wall Plate over the expansion tubes* on the ceiling, then screw into the expansion tubes to mount the wall plate.
    6. Mount the camera base onto the Wall Plate, cameras facing outward.
    7. Because your camera is upside down, you will have to rotate the image in your settings.In the Wyze app, tap on the Settings gear > Advanced Settings > toggle on Rotate Image 180°.
    8. Insert the power cable into the camera, then plug the USB end into the adapter.When powered, the status light on the camera will light up.
    Additional Note: We recommend mounting your camera vertically upright or upside down. We do not recommend mounting your camera at an angle or side ways.
    You'll find the status light on the top front of your Wyze Duo Cam Pan. No light? Make sure it's properly connected to power.
    ⚡️ All Wyze devices have a handy status light that helps determine what state the device is in.
    Wyze Duo Cam Pan Status Light Guide
    • Solid red - The camera is powered on and initializing, recording an event, or you are watching the live stream.
    • Flashing red - The camera is ready to connect.
    • Flashing red and blue light - Connection is in progress.
    • Flashing blue light - The camera is connected and finishing setup, or updating its firmware.
    • Solid blue light - The camera is powered and fully connected.
