1 of 11
Duo Cam Doorbell + Extra Battery
Battery 2K Doorbell with Dual Cameras
Add ons
$129.98 $159.97CAD
Wyze Duo Cam Doorbell is our most advanced battery-powered video doorbell yet. Dual camera views for people and packages, 2K video and local storage, two-way audio, real-time AI detections and alerts, and motion-activated voice deterrence. Includes Wyze Wi-Fi Chime and Wyze Removable Battery Pack and additional Battery so you always have a backup. You can enable 24/7 local recording when you add a MicroSD card (sold separately) and set up the doorbell with hardwired power.
Wyze Duo Cam Doorbell Specs
Color & Materials
  • Colors: Black/Silver
  • Materials: Plastic body, resin lens
Dimensions
  • 5.90in x 1.88in x 1.18in (150mm x 48mm x 30mm)
Weight
  • 0.92 lbs (416 g)
Video
Video Resolution
  • Front: 2K (2048 x 1536)
  • Bottom: 1920 x 1080
  • Frame Rate: Daytime: 20 FPS / Nighttime: 15 FPS
  • Digital Zoom: 8x
Camera FOV
  • Front camera - Horizontal: 132°,Vertical:100°
  • Bottom camera - Horizontal: 121°,Vertical: 60°
Audio
  • Siren: 90 dB
  • Audio: Two-Way Talk, simultaneous
  • Mic Sensitivity: -42 ± 3 dB
  • Motion Warning: “Hi, you’re currently being recorded.”
Wyze Removable Battery Pack Details
  • Model Number: WBAT2
  • Color: White
  • Weight: 3.9 oz (110g)
  • Dimensions: 2.9 in x 1.6 in x 0.9 in (75 mm x
     40mm x 22 mm)
  • Battery Capacity: 6200 mhA
  • Output Voltage: 3.6 V
  • Input Voltage: 5V DC
  • Charging Current: 800 mA
  • Battery Type: Lithium Ion
  • Connector: USB-C
  • Operating Temperature: -4℉ to 122℉ (-20°C to 50°C); Humidity
    < 90%
  • Charging Temperature: 32℉ to 122℉ (0°C to 50°C); Humidity
    < 90%
  • Fully Charging Time: Approximately 9h at 25°C/77℉
Connectivity & Compatibility
  • Wi-Fi: IEEE 802.11 a/b/g/n 2.4 GHz & 5 GHz Wi-Fi
  • Bluetooth® 5.0
Weather & Temperature
  • Operating Temperature: -4°F-122°F (-20°C-50°C)
  • Storage Temperature: -40°F-158°F (-40°C-70°C)
  • Weather Resistance: Indoor and Outdoor (IP65)
Certifications
  • FCC, IC, UL, IP65
Warranty
  • 1-year
Wyze Duo Cam Battery Doorbell
  • 1x Wyze Duo Cam Doorbell
  • 1x Wyze Wi-Fi Chime
  • 1x Back Plate
  • 1x Corner Kit
  • 1x USB-C Charging Cable
  • 3x Wire Nuts
  • 1x Jump Wire
  • 2x Extension Wires
  • 3x Long Screws
  • 3x Short Screws
  • 3x Expansion Tubes
  • 1x Adhesive Tape
  • 1x Doorbell Detaching Pin
  • 1x Removable Battery Pack
  • 1x Quick Start Guide
Wyze Removable Battery Pack:
  • Wyze 6200 mhA Battery Pack x1
FREE shipping on orders $0+
$7.99
