Meet the New Wyze Lever Lock
Wyze Lever Lock: You Don't Need a Key Anymore. Just a Grip.
Hello, friends!
Most smart locks give you a keypad. Some add a thumbprint sensor. Wyze Lever Lock just puts the fingerprint reader exactly where your hand already goes: right on the handle. Grip it, it knows it's you, the lock pops, and you're in. It's biometric access that takes zero extra steps and half a second.
Oh, and it's a lever, not a deadbolt. That means it actually fits all the doors your smart deadbolt can't: garage doors, side and back doors, balcony and patio doors, and interior office and bedroom doors at home or work. One lock. Fits both exterior and interior scenarios. Ships for $99.98 starting November 10, 2026.
Unlock the moment you grab it
Your fingerprint is read continuously as you grip, so the latch releases in under half a second. Advanced biometric tech learns your print with every use, getting faster and more accurate over time. The success rate is over 98%, with a false acceptance rate under .0001% and a false-rejection rate under 2%. It's the same proven fingerprint engine we use in the Lock Bolt v2, now woven into a handle you were grabbing anyway.
You can register up to 50 fingerprints and 50 passcodes per lock, which is more than enough for every family member, roommate, or small-business staff member to get their own credential. No shared keys. No "the code is 1234, just don't tell anyone."
Built-in Wi-Fi. No hub, no extra box.
Wi-Fi 6 (2.4 GHz) is built into the lock, so you get remote unlock, real-time notifications, user management, and full event history straight from the Wyze app. No separate bridge to plug in. No monthly subscription required for basic remote access.
It works with Wyze Doorbell, Amazon Alexa, and Google Home, and lives in the same app as the rest of your Wyze gear for a single, unified smart-home experience.
12+ months of battery life, and two backup ways in if it dies
Powered by 8 AA batteries, typical use (10 to 20 unlocks per day) gets you up to 12 months before you swap them. You'll get a low-battery notification at around 20% remaining. If you ignore that, the lock flips into Super Battery Save Mode to stretch what's left. If you ignore that, there's a USB-C emergency power port on the exterior: just plug in any power bank and unlock instantly. (The USB-C port is for emergency power only, not for recharging the batteries.)
All your fingerprints, passcodes, and settings stay saved when you change batteries. And if all tech fails, two metal keys are in the box.
Five ways to unlockA person holding a smartphone and a keypad.
1. Fingerprint on the handle
2. Passcode on the hidden touch keypad
3. Wyze app (remote unlock over Wi-Fi)
4. Mechanical key (in the box)
5. Wyze Doorbell, Alexa, or Google Home integration
The keypad only lights up when you touch it, so the lock stays sleek and minimal the rest of the time. Anti-peep codes let you pad your real PIN with random digits so onlookers can't steal it. After repeated failed passcode attempts, the lock temporarily disables the keypad and alerts you.
Fits the doors your smart deadbolt can't
Wyze Lever Lock is a single-bore lock. It replaces a standard lever handle on doors that don't have (or don't need) a deadbolt, like garage connection doors, side and back doors, balcony and patio doors at home, and interior doors like a home office, bedroom, or study. It also works great for small-business staff doors and private offices.
It's certified to ANSI/BHMA Grade 3 for residential durability and security, and it's rated IP54 against dust and water spray, so it holds up on exposed exterior doors, not just sheltered interiors.
It works on most standard North American wooden doors, 35mm to 55mm thick. It installs with a screwdriver so no drill is needed unless you have a brand new door with no bore-hole. It converts between left-hand and right-hand door swing in seconds. For compatibility details and to measure your door, check the Wyze Lever Lock Door Compatibility guide.
Auto-lock, guest access, and one-time codes
You can set the lock to re-secure automatically after a delay you choose. Share access with other Wyze users and let them register their own fingerprints or codes, with or without a schedule. Generate single-use passcodes for a cleaner, contractor, or delivery that expire after one unlock—remote, temporary access with no lasting security risk.
You'll get real-time notifications when someone unlocks the door, when the battery runs low, or when someone tries and fails to get in.
What's in the box
  • Exterior assembly (fingerprint handle + hidden keypad)
  • Interior assembly (with thumb-turn and escape lever)
  • Latch and strike plate
  • Mounting hardware (screws, adapters, silicone pad)
  • 8 AA batteries
  • 2 metal keys
  • Drilling template and quick-start guide
The finish is matte black—low-profile dark metal on both sides. The frame is aluminum alloy and steel. The handle is metal with a plastic front plate where the fingerprint sensor lives.
Tech specs you might care about
  • Dimensions: Exterior 5.9 × 2.8 × 1 inch, interior 6.5 × 2.8 × 1.3 inch, handle 5.2 × 1.7 × 1 inch
  • Weight: 4 lbs
  • Connectivity: Bluetooth 5.3, Wi-Fi 6 (2.4 GHz)
  • App compatibility: Wyze app 3.7+, Android 10.0+, iOS 16.0+
  • Weather resistance: IP54, operating temps from -4°F to 122°F exterior, 32°F to 122°F interior
  • Warranty: 1 year
Real-world use cases
Families with kids: Register every family member's fingerprint so the kids can get in after school without carrying (and losing) a key. You'll get a notification the moment they're home, and you can set the lock to auto-secure behind them.
Renters and apartment dwellers: Install it on your bedroom or home-office door for privacy and security without needing landlord permission for a deadbolt. Remove it when you move and take it with you.
Small businesses and coworking spaces: Give each employee or member their own fingerprint or passcode, track who enters and when, and revoke access instantly when someone leaves—no rekeying, no collecting physical keys.
Garage and utility doors: Secure the door between your garage and house, or a side door you use constantly, without fumbling for keys every time your hands are full of groceries or tools.
Airbnb and vacation rentals: Generate one-time passcodes for each guest reservation. They get in easily, codes expire after checkout, and you never have to hide a key under the mat or coordinate handoffs.
Home offices and studios: Lock your workspace when you're done for the day, even if it's just a spare bedroom. No one else in the house needs a key, and you can unlock remotely if you forgot something.
Frequently asked questions
Can I install Wyze Lever Lock myself, or do I need a locksmith?
Most people can install it with just a screwdriver in about 15 minutes. The box includes a drilling template and quick-start guide. If your door already has a standard single-bore hole for a lever handle, you won't need a drill at all. Just swap out the old handle and follow the step-by-step instructions in the Wyze app. If you're replacing a deadbolt or your door has a different bore configuration, check the Wyze Lever Lock Door Compatibility guide first, or hire a locksmith to help.
What if the batteries die?
You'll get a low-battery notification in the Wyze app when power drops to around 20%, giving you weeks of advance warning. If you ignore it and the batteries die completely, there's a USB-C emergency power port on the exterior: just plug in any USB power bank, phone charger, or portable battery and the lock will unlock instantly. (The USB-C port is for emergency power only—it doesn't recharge the batteries.) And if all else fails, there are two metal keys in the box.
Can I share access with family, friends, or temporary guests?
Yes. You can register up to 50 fingerprints and 50 passcodes per lock. Share access with other Wyze users so they can add their own fingerprints or codes directly through the app, with or without a schedule. For temporary access—like a cleaner, contractor, or Airbnb guest—you can generate one-time passcodes that expire after a single unlock. You can also grant or revoke access remotely at any time.
When and where you can get it
Launch day is November 10, 2026. MSRP $99.98. Ships immediately upon launch.
Available direct from Wyze, Amazon, TikTok Shop, and The Home Depot.
Shop Now
Enjoy!
Wyze Team
cameras
By Garrett Bogar
The Best Camera for Garage and Driveway Security - Wyze Labs, Inc.
featured
By Silas Phillips
Look, if you're wondering what the absolute best camera for garage and driveway security is, I’ll save you the suspense: it's a high-tech tag team featuring the Wyze Cam Floodlight Pro for...
cameras
Wyze or Blink - Which to Buy?
By Silas Phillips
Newsletter background
Be in the know
FREE shipping on orders $0+
