Living in a rental property usually means living by someone else's rules, which is why the best video doorbells for renters are the Wyze Battery Video Doorbell or the Wyze Duo Cam Battery Doorbell. Often, lease agreements prohibit drilling holes into walls or messing with electrical wiring, making standard smart home upgrades a headache. You want the convenience of knowing when your takeout has arrived, but you also want your security deposit back. A traditional hardwired doorbell is a quick way to lose that deposit.
The Wire-Free Solution
The obvious answer is a battery-powered option. The Wyze Battery Video Doorbell was built for this exact scenario. It requires zero wiring and zero tools for installation. You attach it to your doorframe using the included heavy-duty 3M adhesive backing. The process takes less time than making a cup of coffee. When your lease ends, you simply remove it and pack it with your boxes.
The Full Picture
A camera is only useful if it actually captures what you need to see. Many standard cameras have a narrow field of view, showing you a visitor's torso while completely missing the package sitting by their feet. The Wyze Battery Video Doorbell features a wide viewing angle. You get a clear picture of your entire porch, from the welcome mat to the ceiling.
The Dual-Camera Defense for Exterior Doors
If your rental has a direct exterior entrance, your front step is essentially a buffet for opportunistic package thieves. The Wyze Duo Cam Battery Doorbell was designed to fix this. It utilizes the same wire-free, renter-friendly installation but adds a second camera pointing straight down at your doormat. One lens handles the human visitors, while the bottom lens keeps a permanent watch over your deliveries. It removes the blind spots where porch pirates love to operate, letting you secure your packages without making permanent changes to the property.
Skip the Extra Purchases
A common frustration with battery-powered doorbells is the hidden costs. You buy the camera, only to realize you need to purchase a separate chime unit to actually hear the doorbell inside your home. Wyze includes a wireless chime directly in the box with the Wyze Duo Cam Battery Doorbell. You just plug it into any standard wall outlet. It is a complete system right from the start.
Premium Features Without the Premium Price
Upgrading your rental should not require a small loan. Smart home tech should be accessible. Wyze provides high-quality video, reliable battery life, and easy installation at a cost that makes sense. It is a straightforward upgrade that adds convenience to your daily routine while keeping your landlord entirely oblivious to your DIY skills.
Which Doorbell is Right for You?
Feature
Starting Price
$65.98
$119.98
Lenses
Single Camera
Dual Cameras (Front & Bottom)
Resolution
1536 x 1536 HD+
Front: 2K / Bottom: 1080p
Field of View
150° x 150° (Head-to-toe)
Front: 132° x 100° / Bottom: 121° x 60°
Power Options
Built-in Battery or Hardwired
Removable Battery or Hardwired
Wireless Chime
Sold Separately
Included
Best For
Standard entryways and standard budgets.
Exterior doors with frequent package deliveries.
Frequently Asked Questions
Can I install a video doorbell without drilling holes? Yes. Both the Wyze Battery Video Doorbell and the Duo Cam Battery Doorbell use a heavy-duty adhesive backing to stick securely to your doorframe. You do not need power drills or a degree in electrical engineering to set them up.
Do I need an existing wired doorbell to use this? Not at all. Because they run entirely on battery power, you can place them wherever they give you the best view of your porch. The Wyze Duo Cam Battery Doorbell comes with a wireless chime that plugs into a standard wall outlet so you never miss a visitor.
Will the adhesive damage the paint when I move out? The included 3M adhesive is designed to hold strong but can be removed cleanly when your lease is up. Just follow the basic removal instructions, and your landlord will never know it was there.
cameras
By Garrett Bogar
cameras
Wyze or Blink - Which to Buy?
By Silas Phillips
Newsletter background
Be in the know
FREE shipping on orders $99+
