1 of 5
Wyze Window Mount
Wyze Window Mount
Mount for Wyze Cam Outdoor
Upgrade your exterior security by attaching a Wyze Cam v3/Cam v3 Pro/Cam v4, Wyze Cam OG, or Wyze Cam OG Telephoto to your window. Mount your cam on a glass surface with this accessory and enjoy a clear view free of glare or reflection.
Style
Wyze BOGO Icon
WYZE EXCLUSIVE
BOGO
50% OFF when you buy a Wyze Cam v4, Wyze Cam OG, Wyze Cam v3 or Wyze Cam v3 Pro
Applies automatically. See terms.
$19.99CAD
The Wyze Window Mount is designed to hold a Wyze Cam securely in place.
FAQs
Yes. We had a v1 design, but updated this product to a v2 design as our inventory moved over time. You're getting the latest, v2, version on this page.
Just your hands. Our window mount comes with a simple adhesive system so that you can get your camera snug against the window pane.
  • Cam v3
  • Cam v3 Pro
  • Cam v4
  • Cam OG
  • Cam OG Telephoto
