Skip to content
1 of 8
Wyze Cam v3 Pro
Wyze Cam v3 Pro
2.5K Camera with Spotlight & AI Integration
Color
Option
SALE
$64.99 $69.99CADSAVE 7%
Meet the all-new pro version of our #1 best-selling camera. 2.5K resolution. Built-in spotlight. Integrated siren. Edge AI. And all the best IP65 indoor/*outdoor, two-way audio, microSD-ready, Color Night Vision goodness you've come to expect from the v3. From pet cam to security cam and back. The best. Now even better.
*For safe outdoor use, Cam v3 Pro requires a Wyze Outdoor Power Adapter v2 (sold separately).
  • A colorful logo of a person with a shield.
    2.5K Video with Color Night Vision
    See details even at night
  • Bright spotlight
    Built-in Spotlight and Integrated Siren
    5000K, 70 lumen
    Faster Detections with Edge AI.
    Free person detection
  • Weather resistant icon
    Indoor/Outdoor Weather Rated IP65
    Mount this anywhere
Wyze Cam v3 Pro Specs
Color & Materials
  • Color: White
  • FInish: Matte
  • Body: Plastic
  • CPU: 1.2 GHz
  • Image Sensor: CMOS (2560 x 1440)
  • Night Vision: 4 IR LEDS (850nm)
Dimensions & Weight
  • 2.05 in x 2.05 in x 2.3 in (52 mm x 52 mm x 58.5 mm)
  • 4.23 oz (120 g)
Lighting
  • Built-in: 2 Spotlight (5000K, 70 lumen)
Power
  • Power Adapter Input: 110-240V(AC/DC)
  • Power Adapter Output: 5V/2000mA
  • Power Cable Length: 6ft (1.8 m)
Video & Image
  • Video Encoding: H.264
  • Video FPS: Daytime—20 fps; Nightime—15 fps
  • Video Resolution: 2560x1440 (2.5K)
  • Night Vision and Color Night Vision
Additional Details
  • Mounting Method: Magnetic, Screw, Tape
  • Ports: 1 micro USB
  • Memory: 1 GB
  • Digital Zoom: 8x
  • Field-of-view: 116°
  • Audio: Built-in speaker & microphone; 2-way audio; Noise & echo cancellation
  • Alerts: Push notifications
  • Local Storage: Supports up to 32GB in FAT32 format. Supports up to 256 GB microSD in exFAT format.
Connectivity & Compatibility
  • 802.11 b/g/n, 2T2R 2.4 GHz (5 GHz Wi-Fi not supported)
Weather & Temperature:
  • Indoor and Outdoor (IP65)
  • Operating temp: -4°F - 131°F (-20°C - 55°C)
  • Storage temp: -40°F - 158°F (-40°C - 70°C)
Language
  • English
Warranty
  • 1 year
  • Wyze Cam v3 Pro x1
  • USB Cable x1
  • Power Adapter x1
  • Wall Plate x1
  • Mounting Tape x1
  • Screws & Expansion Tubes x2
  • Quick Start Guide x1
Higher image resolution, a faster CPU, an improved speaker and microphone, and a stronger Wi-Fi connection with 2 antennas. It also has a built-in spotlight for true Color Night Vision in any lighting conditions, and a brand new feature in its new UI: Smart Focus.
Smart Focus is a new feature (in the camera’s new UI!) that adds a smaller view of the Live stream, while the camera focuses on what matters - motion. When motion is detected, you will have two views of the Live stream at the same time.
Day: 20 frames per second (FPS)
Night: 15 FPS
No, Wyze Cam v3 Pro is powered by a USB cable with a new 5V 2A power adapter.
Yes. Wyze Cam v3 Pro supports Wyze Web View.
2560 x 1440p (2K)
No, as of right now, Cam Plus Lite only supports cameras released during or before April 2022, such as Wyze Cam Outdoor v2.
No, Wyze Cam v3 Pro is 2.4 GHz only because it works better over long distances and also has better wall penetration. However, we are always evaluating the benefits of adding 5 GHz to more of our future products.
No. The Wyze Cam v3 Pro has an integrated spotlight, though, so there's no need for the Spotlight Kit!
v3 pro cam on a city wall
Meet the v3 Pro.
Everything you love about Wyze Cam.
Now with better AI, better night vision, and better resolution.
Motion-activated spotlight.
Don't just detect, deter. Wyze Cam v3 Pro's integrated 70 lumen spotlight gives you more detail and lets trespassers know they're being recorded.
Plus an 89 decibel, built-in, user-activated siren for when you need to raise the alarm.
Our most popular camera. Reimagined.
exploded breakdown of the new v3 Pro's internal features and improvements
comparing the new 2K resolution to 1080p
Get all of the details
Crisp, clear 2.5K resolution.
See what you need to see and read what you need to read, from faces to license plate numbers.
cam v3's Edge AI makes faster detections because it doesn't rely on the cloud.
Faster detections with Edge AI.
Edge AI detection doesn't rely on the cloud to do its thinking. It can process person detections locally.
For Wyze Cam v3 Pro, that means free, near-instant person detection, right when you need it, with no subscription required.
An all-new cam, with a brand-new app experience.
the new live view
the new live view
the new playback view
A smartphone displaying a front yard security camera.
Front Yard Security Camera
Our redesigned user interface.
Get more from the Wyze app than ever before.
Handy tools at your fingertips, from spotlight and siren controls to the new Smart Focus feature and simplified event review.
All the playback tools you're used to, plus an easy-to-scan Recent Events section to help you navigate your footage quickly.
Tell Wyze Cam v3 Pro exactly where and what you want it to watch. Get notifications only for detections within your customized zone.
And introducing, Smart Focus.
a smartphone with a new focus slider. SmartFocus.
v3 Pro sees better
v3 Pro sees better
v3 Pro looks better
v3 Pro looks better
Inserting an SD card for 24/7 recording
Insert a microSD card for 24/7 recording.
Capture and view up to 15 days (in full 2K resolution) with a 128 GB microSD card (sold separately).
v3 Pro with an SD card captures candid life moments
Moments. Captured.
More than a security camera, inserting a microSD card turns your Wyze Cam v3 Pro into a 24/7 video diary of candid moments and everyday life.
v3 pro all wet for IP65 weather resistance
Indoor/Outdoor Weather Resistance.
Wyze Cam v3 Pro is IP65 rated for all-weather, year-round, indoor and outdoor security (with a Wyze Outdoor Power Adapter - Pick one up here).
two way audio allows you to speak to anyone in front of the camera
Two-way audio.
Talk, interact, and let people know you see them, whether you're confronting a stranger, or checking in on a loved one.
compatible with Alexa and Google home assistants
Works with Alexa and Google Assistant.
A great way to livestream baby or pet cams, 24/7. Plus, receive alerts, use voice commands to check and manage your livestreams, or create schedules and automations in the Wyze app.
subscribe to cam plus for even more features and smart detections
