1 of 4
Wyze Universal Wi-Fi Chime
No complicated wiring needed, just plug-in and know.
$29.99CAD
Free Shipping & 30-day hassle-free returns.
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Easily set up your home's doorbell with the Wyze Universal Wi-Fi Chime. No complicated wiring required—just plug it in and stay informed. Know exactly when someone rings your doorbell (or tries to ditch).
With smart Automations, you can even have it chime when your camera detects a person on your kitchen's cookie cam. Never miss a ding-dong again with this convenient, fuss-free chime.
  • Works with all Wyze Cams
    Compatible with all Wyze Cams and doorbells.
  • 17 different tones
    Choose one tone or switch it up depending on the situation.
  • Easy installation
    Compatible with your everyday wall socket. No need to stress about batteries or electrical wiring.
  • Connect multiple devices
    Why settle for one chime when you can have a bunch! Pair up those chimes with cams for full coverage.
Color: Black
Materials: Plastic
Dimensions: 81 x 53 x 38 mm
Speaker: φ40mm
Wi-Fi: IEEE802.11 b/g/n 2.4 GHz
Power Input: 10-24V AC, 10VA 60HZ
Operating Temperature: -4°F ~ 122°F (-20°C ~ 50°C)
Note: Indoor use only
Bluetooth BLE 5.0
Works with IFTTT, Hey Google, and Alexa
Certifications: FCC, IC, UL, CP65
  • 1x Wyze Wi-Fi Chime
  • 1x Quick Start Guide
Yes, you can adjust the volume or change ringtone in the Wyze app, in your Chime settings.
A black and white image of a doorbell camera.
Ding dong from anywhere. Hear alerts exactly where you want in your home. Built-in Wi-Fi enables you to trigger audio alerts with all Wyze Cams and Doorbells.
A man is holding a box with a camera on it.
Get chime alerts when a person is detected, even if they don't ring.
We all expect our chimes to ring when our doorbell cameras are pressed. But you can do so much more! Setup an Automation inside the Wyze app that chimes you when your camera detects a person.
Works with all Wyze cams but pairs perfectly with doorbells
Wyze Video Doorbell v2
from $59.99 $84.98
Resolution
2048 x 1536 (2K)
Field-of-View
H: 135°, V: 103°
Chime
Existing
Power Option
Wired Only
3P Integration
Amazon Alexa, Google Home
Storage
Local & Cloud
View
