Direkt zum Inhalt
Lesen Sie unsere Erklärung zur Barrierefreiheit
Direkt zu den Produktinformationen
1 of 5
Wyze Battery Charging Dock
Charge up to two batteries at once.
⚠️ Compatible with Wyze Battery Cam Pro's battery packs. Battery packs not included with charging dock.
$26.99CAD
Exklusive Vorteile auf Wyze.com
18-monatige Garantieverlängerung
Erhalten Sie beim Kauf dieses Produkts auf wyze.com eine 18-monatige Garantieverlängerung. Außerdem profitieren Sie bei jeder Bestellung von speziellen Bundles, exklusiven Angeboten und Prämien.
Double the fun! Charge two batteries simultaneously with the Dual Battery Charging Dock.
Alle Details anzeigen
  • Made for Battery Cam Pro Batteries
  • Dual Charging Capability
  • Compact & Convenient
  • Always Have a Battery Ready
Wyze Battery Charging Dock Details
Model Number
  • WYZEDBCD
Color
  • Weiß
Weight
  • 2.75 oz (78 g)
Dimensions
  • Charging Dock: 2.6in x 2in x 1in (58mm x  52mm x 26mm);
  • Power Adapter: 42mm x 40mm x 23mm
Power
USB Cable
  • USB-A to USB-C
Power Cable Length
  • 6 ft (1.8 m)
Fully Charging Time
  • Approximately 8.5h at 25°C/77℉
Power Adapter Input
  • AC100-240V, 50/60Hz
Power Adapter Output
  • DC5V, 2A
Operating Temperature
  • +50℉ to +104℉ (+10°C to +40°C); Humidity < 90%
· Wyze Battery Charging Dock x1
· Adapter Cable x1
· Power Adapter x1
Note: Battery pack not included
The two charging indicator lights on the battery will both turn on once it is fully charged.
Yes, it can.
It takes approximately 8 hours and 30 minutes to fully charge a single battery pack.
Charge up to two batteries simultaneously to keep an always-ready power supply that eliminates security downtime.
Compact and Convenient
It's designed to be compact with a sleek, white finish to blend in to any space.
1 of 4
Take your Wyze Battery Cam Pro system to the next level
  • Wyze Removable Battery Pack
    Regular price $33 CAD
    Regular price $33 CADDeal $33
    Works with Wyze Battery Cam Pro, Wyze Duo Cam Doorbell and Wyze Palm Lock. Learn More
  • Wyze Solar Panel
    Regular price From $7.99 CAD
    Regular price CADDeal From $7.99
    12W Solar Charger for Outdoor Cams Learn More
    Choose your option
    View Options
  • Wyze Universal Camera Mount
    Regular price $14.99 CAD
    Regular price CADDeal $14.99
    A durable mount with a longer stem. Required when mounting Wyze Battery Cam Pro to a ceiling. Learn More
  • MicroSD Cards
    Regular price From $25.99 CAD
    Regular price CADDeal From $25.99
    Choose your option
    View Options
Designed for Wyze Battery Cam Pro
In den Warenkorb gelegt
Kostenloser Versand ab einem Bestellwert von 59 $
Zwischensumme
Warenkorb anzeigen
