1 of 5
Wyze Removable Battery Pack
Works with Wyze Battery Cam Pro, Wyze Duo Cam Doorbell and Wyze Palm Lock.
$33CAD
Low stock: 93 left
Low stock: 93 left
Pack a punch with a replacement 6200mAh rechargeable battery designed for the Wyze Battery Cam Pro, Wyze Duo Cam Doorbell and Wyze Palm Lock.
*Charging cable not included. USB-C Charging Port.
Wyze Removable Battery Pack Details
Model Number
  • WBAT2
Color
  • White
Weight
  • 3.9 oz (110g)
Dimensions
  • 2.9 in x 1.6 in x 0.9 in (75 mm x  40mm x 22 mm)
Battery Capacity
  • 6200 mhA
Output Voltage
  • 3.6 V
Input Voltage
  • 5V DC
Charging Current
  • 800 mA
Battery Type
  • Lithium Ion
Connector
  • USB-C
Operating Temperature
  • -4℉ to 122℉ (-20°C to 50°C); Humidity < 90%
Charging Temperature
  • 32℉ to 122℉ (0°C to 50°C); Humidity < 90%
Fully Charging Time
  • Approximately 9h at 25°C/77℉
· Wyze 6200 mhA Battery Pack x1
Note: Charging cable not included
It takes approximately 9 hours to fully charge the battery.
Yes, you can use it with the Wyze Charging Dock.
It takes approximately 8 hours and 30 minutes to fully charge the battery.
Yes, you can use a PD charger to charge the battery pack. However, please note that it will not charge faster due to the battery charging IC design.
No. They are only compatible with the Battery Cam Pro and Duo Cam Doorbell.
A black camera attached to a wooden fence.
Long Battery Life
6200mAh of rechargeable battery power lasts up to 6 months on just one charge. You can place your camera outdoors and not worry about having a power outlet nearby.
A man is holding a white remote control.
Convenient Charging
Get charged up with just a cable. Our battery pack is equipped with a built-in USB-C charging port, making it a breeze to juice up with a standard USB-C charger.
A white battery attached to a black laptop.
1 of 4
Take your Wyze Battery Cam Pro system to the next level
  • Wyze Battery Charging Dock
    Regular price $26.99 CAD
    Regular price CADDeal $26.99
    Charge up to two batteries at once. Learn More
  • Wyze Solar Panel
    Regular price From $7.99 CAD
    Regular price CADDeal From $7.99
    12W Solar Charger for Outdoor Cams Learn More
    Choose your option
    View Options
  • Wyze Universal Camera Mount
    Regular price $14.99 CAD
    Regular price CADDeal $14.99
    A durable mount with a longer stem. Required when mounting Wyze Battery Cam Pro to a ceiling. Learn More
  • MicroSD Card
    Regular price From $25.99 CAD
    Regular price CADDeal From $25.99
    Choose your option
    View Options
Designed for Wyze Battery Cam Pro and Wyze Duo Cam Doorbell
