Skip to content
1 of 6
Pan v3 + Lamp Socket v2 Bundle
Make your exterior lighting smart while powering a Pan v3.
Wyze Cam Pan v3 (Color)
SALE
$74.98 $85.97CADSAVE 12%
Make your exterior lighting even smarter with this power duo. With our latest lamp socket, you can now power Pan v3 without the need for an outlet.
  • A black image of a camera.
    Conveniently Power Wyze Cams
    No creative extension cord weaving required. Compatible with Cam v3/v3 Pro/Cam v4/OG/Pan v3/Pan v4.
    Motion-Activated Lights
    Converts standard bulbs into motion-activated security lights.
    Linkability, without limits
    Assign unlimited lamp sockets to your Wyze Cam automated, group-controlled lighting.
    Dusk to Dawn Scheduling
    Automatically turn your lights on at sunset and off at sunrise.
Wyze Lamp Socket v2 Specs
  • Color: White
  • Materials: Polycarbonate, Plastic
  • Dimensions: 56.5mm x 56.5mm x 65mm
  • Weight: 80 g
  • Socket Connector Type: E26
Power
  • Lamp Socket Input/Output 120V~, 60Hz
  • Max Lamp Power 20W
Compatibility
  • Phone: Android 7.0+, iOS 12.0+
  • Camera: Wyze Cam v3/v3 Pro/v4, Cam OG, and Cam Pan v3.
Connectivity
  • 802.11 b/g/n, 2.4GHz, Bluetooth
Operating temperature
  • -4°F ~ 120°F (-20°C, ~ 50°C)
Weather Resistance
  • Not weatherproof or waterproof. Suitable for damp locations.
Certifications
  • FCC, IC UL496, CA65, TSCA, RoHS
Languages
  • English
Warranty
  • 1-Year
Wyze Cam Pan v3
Note: Due to thermal limitations, incandescent bulbs cannot by used with this lamp socket. We recommend using a CFL or LED bulb under 20W, like Wyze Bulb White.
Pan v3
  • 1x Wyze Cam Pan v3
  • 1x 6' micro USB Cable
  • 1x Power Adapter
  • 1x Mounting Kit (Please note: There has a been change in our mounting bracket's design. Customers may get either design regardless of the design on the packaging. However, this shouldn't affect functionality. Learn more here.)
  • 1x Quick Start Guide
Lamp Socket v3
  • 1x Lamp Socket v2 unit
  • 1x Sticker
Flexible power for your Wyze Cams, now including Pan v4.
Skip the wiring and electrocution (unless you're into that sort of thing). Harness the electricity from your outdoor light fixture to continuously power your Wyze Cam v3/v3 Pro/v4, Wyze Cam OG, Wyze Cam Pan v3, and Wyze Cam Pan v4. No long, ugly wires. No hassle.
A white light bulb with a camera attached to it.
A person holding a light bulb in their hand.
Upgrade to smart lighting in seconds.
Wyze Lamp Socket v2 and compatible Wyze Cams work together to make your existing outdoor lighting smart. The socket gives the camera power and the camera gives the socket brains! Control your lights from anywhere in the Wyze app.
Illuminate your way to motion activated lights.
Set your newly smartened lights to illuminate whenever your compatible Wyze Cam detects motion. Now your old light fixture is a cutting-edge model of sleek security sophistication!
Smart home security camera and light bulb in fixture on a wall
Easily link multiple sockets for greater coverage and control.
Assign unlimited lamp sockets to your Wyze Cam automated, group-controlled lighting. Then schedule and control your smart setup from anywhere using the Wyze app.
A Wyze Lamp Socket v2 is hanging on the side of a garage.
Dusk to Dawn automation.
A light fixture with a tiny light bulb.
As easy as screwing in a lightbulb.
Some installations are as easy as screwing in a lightbulb. Other installations are literally the exact same as screwing in a lightbulb. Wyze Lamp Socket v2 falls in the latter category.
This video is for our Lamp Socket v1, but the installation process is still just as easy.
