Skip to content
1 of 9
Wyze Lamp Socket v2
Wyze Lamp Socket v2
Make your exterior lighting smart.
Motion-Activated Lights
Linkability Without Limits
Assign all lamp sockets to group controlled lighting
Dusk to Dawn
Scheduling
Conveniently Power
Wyze Cams
Style
$25.98CAD
Check out what's new:
  • Same Dusk-to-Dawn technology
  • Motion Activated lighting + AI Activated lighting for security plan subscribers
  • Now you can link unlimited Lamp Socket v2's ✓
  • Now compatible with Cam OG and Pan v3 ✓
You might be interested in
Make your exterior lighting even smarter. With our latest lamp socket, you can now power Wyze Cam v3/v3 Pro/v4, Cam OG, Pan v3, Pan v4 and Duo Cam Pan without the need for a power outlet.
  • A black image of a camera.
    Conveniently Power Wyze Cams
    No creative extension cord weaving required. Compatible with Cam v3/v3 Pro/Cam v4/OG/Pan v3/Pan v4.
    Converts standard bulbs into motion-activated security lights.
    Linkability, without limits
    Assign unlimited lamp sockets to your Wyze Cam automated, group-controlled lighting.
    Dusk to Dawn Scheduling
    Automatically turn your lights on at sunset and off at sunrise.
Wyze Lamp Socket v2 Specs
  • Color: White
  • Materials: Polycarbonate, Plastic
  • Dimensions: 56.5mm x 56.5mm x 65mm
  • Weight: 80 g
  • Socket Connector Type: E26
Power
  • Lamp Socket Input/Output 120V~, 60Hz
  • Max Lamp Power 20W
Compatibility
  • Phone: Android 7.0+, iOS 12.0+
  • Camera: Wyze Cam v3/v3 Pro/v4, Cam OG, Cam Pan v3, and Cam Pan v4.
Connectivity
  • 802.11 b/g/n, 2.4GHz, Bluetooth
Operating temperature
  • -4°F ~ 120°F (-20°C, ~ 50°C)
Weather Resistance
  • Not weatherproof or waterproof. Suitable for damp locations.
Certifications
  • FCC, IC UL496, CA65, TSCA, RoHS
Languages
  • English
Warranty
  • 1-Year
Note: Due to thermal limitations, incandescent bulbs cannot by used with this lamp socket. We recommend using a CFL or LED bulb under 20W, like Wyze Bulb White.
Wyze Lamp Socket v2
  • 1x Lamp Socket v2 unit
  • 1x Sticker
  • 1x Quick Start Guide
Thanks to Wyze Lamp Socket v2's high power output, it can support even more Wyze Cam devices: Wyze Cam v3, Wyze Cam v4, and now Wyze Cam v3 Pro, Wyze Cam OG, and Wyze Cam Pan v3 (more to come!). You can also pair unlimited lamp sockets to a single camera for seamless control.
No, Wyze Lamp Socket v2 requires a compatible Wyze Cam for initial setup in the Wyze app and most other functions. Features like motion light, person-triggered lighting, and manually turning on/off the lamp socket in the app require a Wyze Cam. Without a compatible Wyze Cam, you can only use the lamp socket as a USB power source.
Wyze Lamp Socket v2 gives your lamp smarts, like only turning on when motion is detected or by a set schedule in the Wyze app. You can also leave the power switch toggled ON with the light OFF to save power.
Wyze Lamp Socket not only provides faster motion detection and more accurate light triggering using Al detection, but it is an easy-to-install, security cam powering solution. It can control your bulb while also pairing seamlessly with your compatible Wyze Cam.
Yes, when you set up your lamp sockets in the Wyze app, you assign them to a Wyze Cam. All assigned lamp sockets will be grouped together and can be controlled all at the same time.
The limit does not exist! You can assign an unlimited number of lamp sockets to any compatible Wyze Cam.
No, you can use the same power cable that came with your Wyze Cam to connect it to your Wyze Lamp Socket v2.
No, it is not weatherproof or IP-rated. It is UL rated for Damp Locations, and must be protected from direct rain and water.
No, Wyze Lamp Socket v2 connects to your existing light fixture and bulb.
Flexible power for your Wyze Cams, now including Pan v4.
Skip the wiring and electrocution (unless you're into that sort of thing). Harness the electricity from your outdoor light fixture to continuously power your Wyze Cam v3/v3 Pro/v4, Wyze Cam OG, Wyze Cam Pan v3, and Wyze Cam Pan v4. No long, ugly wires. No hassle.
A white light bulb with a camera attached to it.
A person holding a light bulb in their hand.
Upgrade to smart lighting in seconds.
Wyze Lamp Socket v2 and compatible Wyze Cams work together to make your existing outdoor lighting smart. The socket gives the camera power and the camera gives the socket brains! Control your lights from anywhere in the Wyze app.
Illuminate your way to motion activated lights.
Set your newly smartened lights to illuminate whenever your compatible Wyze Cam detects motion. Now your old light fixture is a cutting-edge model of sleek security sophistication!
Smart home security camera and light bulb in fixture on a wall
Easily link multiple sockets for greater coverage and control.
Assign unlimited lamp sockets to your Wyze Cam automated, group-controlled lighting. Then schedule and control your smart setup from anywhere using the Wyze app.
A Wyze Lamp Socket v2 is hanging on the side of a garage.
Dusk to Dawn automation.
A light fixture with a tiny light bulb.
As easy as screwing in a lightbulb.
Some installations are as easy as screwing in a lightbulb. Other installations are literally the exact same as screwing in a lightbulb. Wyze Lamp Socket v2 falls in the latter category.
This video is for our Lamp Socket v1, but the installation process is still just as easy.
