Skip to content
Floodlight + OG Security Kit
Color
SALE
$166.98 $168.98CADSAVE 1%
With this much lumen power, you'll dominate the dark, and spot the bad guys, with ease.
    2K HD Resolution & Color Night Vision
    Capture more details.
  • A black image with a wide angle lens.
    160° View + 270° PIR Motion Detection
    Eliminate blind spots.
  • icon sun
    2800 Super-Bright LEDs
    Dimmable & adjustable.
  • MicroSD card with arrows that represent continuous recording
    24/7 Recording with MicroSD Card
    No subscription required.
Wyze Cam Floodlight v2
  • Color: White or Black
  • Finish: Matte
  • Mount: Wall/Ceiling
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • 2 dimmable LED light panels
  • 2800 total lumens of brightness
  • 5000K color temperature
  • Dimmable: Yes
  • 2K (2304 x 1296)
  • Night Vision
  • Color Night Vision
  • Hardwired 110 - 120V AC
  • -4°F - 140°F (-20°C - 60°C)
  • IP65 Water Resistance
  • Safe for outdoor use
Learn more
Wyze Cam OG
  • Power Adapter: Input - 110-240V (AC/DC) Output - 5V/1A
  • Video FPS: Daytime - 20 FPS Nighttime - 15 FPS
  • Video Encoding: H.264
  • 2 spotlight (5000K, 40 lumens)
  • 802.11 b/g/n, 2.4 GHz Wi-Fi
    Weather Resistance: Indoor and Outdoor (IP65)
  • Operating: -4°F - 131°F (-20°C - 55°C)
  • Storage: -40°F - 158°F (-40°C - 70°C)
  • Power Cable Length: 6 ft (1.8 m)
  • Ports: 1 micro USB
  • Night Vision: 4 IR LEDs (850nm)
  • Digital Zoom: 8x
  • Field-of-View-OG: 121.4°(DFOV), 102.3°(HFOV), 54.1°(VFOV)
  • Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
  • Local Storage: Supports up to 256 GB microSD in exFAT format
Learn more
Connectivity & Compatibility
  • IEEE802.11 b/g/n. Wi-Fi 2.4G b/g/n
  • Warranty: 1 Year
Wyze Cam Floodlight v2:
  • x1 - Wyze Cam Floodlight v2
  • x1 - Quick Start Guide
  • x1 - Mounting Accessory Kit
  • x2 -Bracket Screws (#6, #8, and #10)
  • x1 - Ground Screw
  • x1 - Floodlight Screw
  • x1 - Rubber Stopper
  • x1 - Mounting Bracket
  • x2 - Wire Nuts
  • x1 - Hook x
Wyze Cam OG (Standard):
  • x1 - Camera
  • x1 - Indoor Power Adapter
  • x1 - USB Cable
  • x1 - Wall Anchors
  • x1 - Wall Plate
  • x1 - Mounting Screws (M4)
Enjoy crystal-clear 2K resolution.
Immaculate 2K image quality means you can capture events in more detail than ever, especially at night. Because we all know the devil is in the details. Or maybe it was just Brad, the hypersensitive HOA president.
Hands holding phone with livestream of man approaching car parked in a driveway. Security camera light illuminates the scene.
A Wyze Cam Floodlight v2 is shown in a side-by-side comparison of a traditional view and a wide-angle view.
See more, worry less.
A 160° wide-angle view gives you double the visibility compared to the previous generation. Moms everywhere are wondering if this can be applied to genetics.
A man standing in front of a garage door with a white car.
The dark doesn't stand a chance.
Turn night into day with two 2800 lumen, adjustable and motion-activated LED lights that illuminate your path and keep intruders at bay.
Ambient Light Mode.
When enabled, it provides constant low-level light and automatically switches to increased brightness when motion is detected. It's like a reverse night light for crooks and creepers.
Wyze Cam Floodlight v2 mounted on a wall. Box-shaped cam with lights attached. The light is turned on and shining brightly.
Wyze Cam Floodlight v2 PDP Artboard 14.
Person inserting a microSD card into a Wyze security cam. The phone in front is displaying a live feed from the cam, which shows a backyard at night.
24/7 local recording with microSD card.
Don’t miss a thing with continuous local recording to a microSD card up to 256 GB. No subscription required.
Man looking up at a Wyze Floodlight v2 and speaking to a person through the built-in mic.
Two-way talk + loud siren.
Respond to visitors and familiars by tapping on the mic icon in the Wyze app. Still not getting the message? Sound the 105dB siren for extra deterrence.
An aerial view of a house, driveway, and lawn with a green circle showing PIR coverage area. Wyze Cam Floodlight v2 is mounted on the side of the house, facing the driveway.
Bye bye, blind spots!
Eliminate blind spots and trigger lights faster than ever with a 270° PIR motion detection area.
No junction box needed.
Add a floodlight plug-in mount if you prefer a power outlet.
Skip the electrician appointment! By following some simple instructions, you can now totally DIY install a floodlight camera. No need for a junction box or pesky power lines. Learn more.
Perfect for those with a handy outdoor outlet open and renters.
Black floodlight cam shining bright during sunset.
Dusk-to-dawn automation.
The floodlight knows when the sun goes down and when it comes back up. No need to turn it on and off manually.
A black security camera with two floodlights attached, mounted to a wall. Rain is falling on the camera and lights.
IP65 weatherproof.
Rated to withstand any weather. Especially, the "it's raining packages which means my partner maxed out the AMEX again" type of weather. That's the worst weather.
Man carrying packages away from the house during the night with the lights shining directly at him. Phone notification overlay of alert about the camera's detection.
A tablet computer displaying a live video feed from a security camera mounted outside. The cam is showing a person standing in driveway..
A smart speaker on a table.
Phone screen showing the step of device pairing during onboarding.
A phone screen with a message about pairing a device.
Phone showing app screen where Detection Zone is set up.
A Wyze Cam Floodlight v2 is displayed on a smartphone screen.
Super simple setup.
Use your Amazon Echo, Alexa, and Google Home devices to view live feeds of floodlight cam. Even get smart alerts when a person is detected, with Cam Plus.
Access Point Wi-Fi setup lets you pair Wyze Cam Floodlight v2 with
the Wyze app without climbing a ladder to scan a QR code.
It's time to shine!
Here's a fancy pants recap of why Wyze Cam Floodlight v2 is changing the game.
Compare Floodlights
Compare Floodlights
Camera Resolution
Field-of-View
Lumens
Floodlight Heads
Color Temperature
Wi-Fi Connectivity
Vision AI Light Control
Motion Detection
Sirens
Ambient Light Mode
Motion Warning
Device Setup Mode
IR Lights
MicroSD Card Compatibility
Power Supply
Smart Integrations
Certifications
