1 of 7
Wyze Cam Floodlight Plug-In Mount
Color
$29.98CAD
Low stock: 35 left
Low stock: 35 left
Say goodbye to the complexity and cost of installing a junction box. Go with an easy, plug-n-play floodlight solution instead.
    Compatible with Wyze Floodlights
    Works with Wyze Cam Floodlight v1/v2 and Pro.
  • A black screen with a 20ft icon.
    20 ft (6m) Power Cord
    Reach a outdoor-rated outlet with ease. Velcro cable strap included.
  • Install icon on a black screen.
    Easy to Install
    It's fast and easy. Just plug it in, and mount your floodlight.
    No Junction Box Required
    Skip the electrician and the construction. Plug-n-play in minutes.
  • Colors: White and Black
  • Outdoor safe: Yes
  • Operating Temperature: -22°F to 122°F
  • Input: 110 - 120V AC
  • Power Cord Rating: SJTW (Hard service, thermoplastic cable, S: service, J: junior, T: thermoplastic, W: weather-approved)
  • Cable Wire: 18 AWG
  • Power Cord Length: 20 feet (6m)
  • Package Dimension: 153mm x 155mm x 79mm
  • Package Weight: 1.39 lbs
  • Complete product: UL153, RoHS, REACH SVHC 240, CP65
  • Mount: UL94, UL 746A,B, ASTM D495
  • Power cord: UL62, UL817, UL2556, UL1581, 48h salt spray, 105°C temp rating
  • 1x Wyze Cam Floodlight Plug-in Mount
  • 1x Floodlight Pro mounting kit (silicone ring, long screw)
  • 1x Mounting screw kit
  • 1x Foam tape
  • 1x Quick Start Guide
Wyze Floodlight Cam Plug-in Mount is an accessory that offers a simple installation solution for all Wyze floodlight models–no junction box required. Use it to install any Wyze Cam to an outdoor GFCI power outlet.
Our Wyze Cam Floodlights require an outdoor junction box for installation. But many homes today lack multiple exterior junction boxes, and hiring a licensed electrician to install one can average ~$650.
With a Wyze Floodlight Cam Plug-In Mount, you don't need a junction box at all. You can install your Wyze Cam Floodlight near any outdoor-rated GFCI power outlet, simplifying installation and reducing the cost.
All Wyze Cam Floodlight models are compatible with this mount, including Wyze Cam Floodlight v1, v2, and Pro. The mount is not compatible with any non-Wyze floodlight camera.
The mount is available in matte white and matte black to seamlessly match our existing Wyze Cam Floodlight devices.
The included outdoor power cord is 20 feet long.
Yes, the plug-in mount and it's attached power cord are both outdoor-rated. It is suitable for outdoor environments when properly installed.
Yes, Wyze Floodlight Cam Plug-In Mount is safe for outdoor use as long as it is connected to a GFCI outdoor power outlet with a power output of 110-120V AC.
Wyze Floodlight Cam Plug-in Mount requires a power input of 110-120V AC. This is standard for most residential homes in the US.
No, DO NOT power the plug-in mount until the floodlight camera is completely wired and properly installed on the mount.
A flexible power solution for all Wyze Cam Floodlights.
Ditch the shock and zap (unless you're into that sort of thing). If you can plug in a cable, then you can enjoy the security of a Wyze Floodlight. No more scary junction boxes and expensive electricians.
A white table with a green plant on it.
A person holding a white light fixture with a camera on it.
Easy to install. No junction box needed.
Say goodbye to the complexity and cost of a junction box. No need to hire electricians and handy people, or cut giant holes into the exterior of your home.
Two lights attached to a wall.
Put it right where you need it.
Free thyself from the shackles of non-ideally-located junction boxes! The durable 20ft. cable reaches outdoor-rated outlets with ease. A velcro strap is included for clean cable management.
Seriously, watch how easy it is to install.
Compare Floodlights
Compare Floodlights
Camera Resolution
Field-of-View
Lumens
Floodlight Heads
Color Temperature
Wi-Fi Connectivity
Vision AI Light Control
Motion Detection
Sirens
Ambient Light Mode
Motion Warning
Device Setup Mode
IR Lights
MicroSD Card Compatibility
Power Supply
Smart Integrations
Certifications
