1 of 3
Mount Wyze Sprinkler Controller anywhere, worry-free.
$59.99CAD
  • Mount Wyze Sprinkler Controller anywhere, worry-free
  • IP65 fully weatherproof rating for outdoor use
  • 4 clasps and gridded cover for extra durability
  • Hardwire or outdoor outlet power
  • Compatible only with Wyze Sprinkler Controller
Color: Light Gray
Finish: Matte
Dimensions (H x W x D): 11.6 in x 9.5 in x 3.4 in
Mounting Method: Screw-in, connect to Wyze Sprinkler Controller
Weather Resistance: IP65 Weatherproof
If your existing sprinkler controller is mounted outdoors, and you would like to replace it with Wyze Sprinkler Controller, then yes you will need Wyze Weatherproof Sprinkler Controller Box.
Wyze Weatherproof Sprinkler Controller Box is IP65 Waterproof. IP65 requires full protection from dust, oil, and other non-corrosive material, and full protection from contact with enclosed equipment.
While you may use the weatherproof box with other brands of sprinkler controllers, the box is designed for installing a Wyze Sprinkler Controller. Thus, any attachment method inside will be up to your discretion.
You can follow the instructions in this article, starting at Step 8.
