1 of 5
Wyze Surge Protector
Power for the modern home.
SALE
$14.99 $24.99CADSAVE 41%
Power for the modern home. This surge-protected power strip has 3 USB ports and 3 grounded outlets for your devices to plug into.
  • 3 USB ports
    Total 5V/3.1A, each 5V/2.1A max.
  • 3-outlet surge protector
    With 268 joules suppression rating
  • Flame resistant
    Safety first! Flame retardant to 1,380℉ (750℃).
  • Low profile design
    Slim design with right-angle flat plug and 4 non-slip rubber pads.
Color
  • White
Dimensions
  • 8.58″ (L) x 1.61″ (W) x 1.02″ (H)
Weight
  • 0.89 lbs
Power
  • AC 15A, 125V, 60Hz, 1875W
  • 4ft Power Cord (14 AWG)
  • 20µA ground fault protection
Additional Details
  • 3 USB ports, total 5V/3.1A, each 5V/2.1A max.
  • 3-outlet surge protector with 268 joules suppression rating
  • Right-angle flat plug
  • 4 non-slip rubber pads located on the bottom
  • Soft-white LED light indicator
  • Scratch-resistant
15A Overload Protection
  • Product will automatically switch off when the current reaches its limit and a manual reset is required for reuse.
Flame Retardant
  • Up to 1,380℉ (750℃)
Certifications
  • UL and FCC certified
Warranty
  • 1-year warranty
  • Wyze Surge Protector 1x
  • Quickstart Guide 1x
No, the Wyze Surge Protector is not IoT (Wi-Fi) capable. If you're looking for a smart plug that enables you to control connected devices remotely, please take a look at Wyze Plugs for indoor applications and Wyze Plug Outdoor for outdoor uses.
Yes. Here are a few facts that most customers ask about.
  • Outlets tested to be plugged in over 10,000 times.
  • Flame retardant up to 1,380℉ (750℃)
