Direkt zum Inhalt
Lesen Sie unsere Erklärung zur Barrierefreiheit
Direkt zu den Produktinformationen
1 of 7
Wyze Sprinkler Controller + Sprinkler Controller Box Kit
Smart Irrigation Controller with App Scheduling
8-Zone WiFi sprinkler controller + 1 Year of Sprinkler Plus Weather Service.
$144.98CAD
Exklusive Vorteile auf Wyze.com
18-monatige Garantieverlängerung
Erhalten Sie beim Kauf dieses Produkts auf wyze.com eine 18-monatige Garantieverlängerung. Außerdem profitieren Sie bei jeder Bestellung von speziellen Bundles, exklusiven Angeboten und Prämien.
Smarter, simpler, and greener control over your lawn's irrigation system with smart zoned control over your sprinklers.
Alle Details anzeigen
  • Personalized schedules for routines
  • sprinkler controller icon
    Customizable irrigation zones
    Set up to 8 different zones.
  • Easy control from an App
    Unlock weather-based watering with Sprinkler Plus
Color
  • Black/white
Dimensions
  • 9.1in x 3.3in x 1.5in (231 mm x 84 mm x 38 mm)
Weight
  • 7.6 oz
Zones
  • Up to 8
Operating Temperature
  • -4ºF - 122ºF (-20°C - 50°C)
Weather Resistance
  • Indoor-use only
Power Source
  • 24V AC, 60Hz, 850mA
Power Cable Length
  • 6 feet
Valve Output
  • 24V AC, 60Hz
Compatible Wire Sizes
  • 12 - 28 AWG
Certifications
  • FCC part 15B
  • RoHS
  • CEC
Model Number
  • WSPRK1
  • Wyze Sprinkler Controller x1
  • Wyze Weatherproof Sprinkler Controller Box x1
  • Power Adapter x1
  • Mounting Plate x1
  • Screw x2
  • Wall Anchor x2
  • Cord Wrap x2
  • Quick Start Guide x1
  • Wire Label Sheet x1
  • 1-Year Sprinkler Plus Coupon x1
Control your sprinkler remotely.
No more watering the grass when it rains and no more manual timers. Wyze Sprinkler Controller is designed to provide a convenient and affordable way for you to control the watering of your lawn or garden from anywhere with Wi-Fi.
Person holding phone with wyze app open to sprinkler settings
  • "Affordably priced smart sprinkler controller"
    -DigitalTrends
  • "Wyze Sprinkler Controller is a good value"
    -Wirecutter
  • "#1 Affordable Smart Sprinkler Controller"
    -ZDNet
1 of 3
Person touching a plant leaf with watering schedule overlay
Personalized schedules for your weekly routine.
Customize a watering schedule that is most convenient for your busy life. Easily start or stop a watering schedule with just a tap in the Wyze app.
Wyze app showing sprinkler zones
8 customizable irrigation zones.
Customize schedules for up to 8 different irrigation zones. Set unique names and photos for each watering zone in the Wyze app so you know which zone is which.
Wyze Outdoor Cam v2 mounted on fence
Peace of mind with Wyze Cam.
Curious if the dog is using your lawn watering as a slip-and-slide? View live footage of your waterings quickly in the Wyze app and get notified when your system is running.
Person holding basket with grapes. Text overlay says, " look for water sense, meets EPA criteria."
Smarter for the planet.
Wyze Sprinkler Controller earned the coveted WaterSense certification from the EPA for using weather-based watering schedules with Sprinkler Plus.
If every landscape in the United States with an automatic irrigation system installed and properly operated a WaterSense labeled weather-based irrigation controller, we could save 220 billion gallons of water and $2.9 billion in water costs across the country annually from not overwatering lawns and landscapes.
Unlock weather-based watering with Sprinkler Plus.
Water when your plants are thirsty, not when it's raining with Sprinkler Plus. (free 1 year subscription included with the purchase of Wyze Sprinkler Controller)
Wet plant leaves with weekly weather forecast overlay
Advanced insights into your yard screen
Advanced insights into your yard.
With Sprinkler Plus, you can see the historical, current, and future moisture levels for each watering zone. Even view the upcoming weather forecast and watering activities right from the app.
In app sprinkler settings with weather forecast
Intelligent weather skips.
Sprinkler Plus can skip unnecessary scheduled waterings based on hyper-localized weather data to save you water and protect your plants.
DIY Installation in 20 minutes.
Wyze Sprinkler replaces your existing controller in less than 20 minutes and automatically creates a schedule for you after setup.
In den Warenkorb gelegt
Kostenloser Versand ab einem Bestellwert von 59 $
Zwischensumme
Warenkorb anzeigen
