1 of 6
Wyze Plug Outdoor
Wyze Plug Outdoor
Weatherproof Smart Outlet with WiFi Controls
$24.99CAD
Power up the outdoors, rain or shine, with an outdoor smart plug – because even your garden lights deserve a tech-savvy friend. From festive holiday inflatables to backyard soirées, take full control with the ease of an app. Monitor usage, set schedules – and just like that, your outdoor space just got a whole lot easier to manage, all thanks to you.
Wyze Plug Outdoor Details
  • Color: Black
  • Weight: 7.2 Ounces
  • Dimensions (L x W x D): 4.0” x 2.8” x 1.4”
  • 1/2 HP Max Motor
  • Weather Rating: IP64
Additional Details
  • Operating Environment: Indoor and Outdoor
  • Operating Temperature: -4°F to 120°F
  • Input: 120V~, 60Hz
  • Output: 15A Max with Overload Protection
  • Compatibility: Android 5.0+ and iOS 9.0+
  • Certifications: FCC, IC, ETL
  • Warranty: 1 Year
  • Connectivity: 2.4GHz WiFi
  • Bluetooth V4.2 (for simple setup)
  • Wyze Plug Outdoor x 1
  • Quick Start Guide x 1
  • Mounting Accessories x 1
Wyze Plug Outdoor has long-range WiFi to ensure it can be used in many locations. It can reach up to 300 feet in an open environment but the exact distance will depend on the location (how many walls between the hardware, the building materials, etc.).
Wyze Plug Outdoor has a built-in photocell sensor that measures ambient light around the device. It is important to follow the in-app instructions and orient the device so it faces away from the wall so the sensor is exposed to the surrounding environment.
Yes, Wyze Plug Outdoor requires WiFi for setup and all features except the light sensor which (once configured using WiFi) can automatically turn Wyze Plug Outdoor on/off based on ambient light.
Yes, there are two on/off buttons on the hardware that let you control it directly from the plug.
Yes, Wyze Plug Outdoor should plug directly into an outlet and then hang down so that water does not run into the sockets. It should not be left flat or in standing or running water. If you would like to use the light sensor, it will need to face away from the wall so the sensor is exposed to the surrounding environment.
A smartphone displaying a screen with a Wyze outdoor plug in app.
Monitor USAGE
Consume less energy and more cold brew
Energy Monitoring. Set energy consumption alerts and see historical energy usage in the Wyze app.
A large home with a circle overlaid on it.
Large WiFI Range
Long-range WiFi lets you plug in nearly anywhere
Up to 300’ WiFi Range. Confidently control outlets around your home with Wyze Plug Outdoor’s extended WiFi range (300 ft. in open space).
IP64 Weather Resistant. Made for the outdoors.
Safely plug into areas that are exposed to rain, dust, dirt, and snow.
A black device with a blue cord plugged into a wall.
A close up of an outdoor plug with both outlets being used.
2 Outlets, 2 Separate Controls
Independent control of both outlets at any given time
Two Outlets in One. Turn off your outdoor lights but leave your inflatable snowman standing strong.
A person holding a smartphone with the Wyze app open.
VOICE COMMANDS WITH ALEXA
Turn your lights off without putting your boots on.
App & Voice Control. Light up your block in seconds by asking your voice assistant or pulling up the Wyze app on your phone.
  • Streamline icon Christmas lights 40x40 1.
    Outdoor Lighting
  • A black background with a white snowflake icon.
    Roof De-icers
  • A black square with a faucet in the center.
    Pond Pump
1 of 3
Safely power melters, and more this winter
15 AMP Output with Overload Protection. Wyze Plug Outdoor offers one of the highest output ratings available for a smart plug, allowing for more ways to use it.
A black box with a blue plug hanging from a tree.
