1 of 7
Wyze Cam Pan v3
Wyze Cam Pan v3
360° 1080p Cam with Night Vision
Wyze Cam Pan v3 (Color)
Wyze Cam Pan v3 (Quantity)
$59.99CAD
Wyze Cam Pan v3 is a redesigned indoor/outdoor, 360° pan and 180° tilt security camera, and is fully IP65 weather resistant.
*For safe outdoor use, Pan v3 requires a Wyze Outdoor Power Adapter (sold separately).
Wyze Cam Pan v3 Specs
Color & Materials
  • Color: White
  • Finish: Matte
  • Body: Polycarbonate
  • Lens: Glass + plastic
  • CPU: 1.5 GHz
  • Image Sensor: 1/2.9'' CMOS
  • LED indicator: Front. Red + Blue
  • Night Vision: 4 IR LEDs (850 nm)
Dimensions & Weight
  • 124mm (H) x 60mm (W) x 63mm (D)
  • 11.29 oz (320 g)
Video
  • Video Encoding: H.264
  • Video FPS: Daytime - 20 fps; Nighttime - 15 fps
View Range
  • 360° horizontal, 180° vertical
Field-of-view
  • 120° FOV
Additional Details
  • Digital Zoom: 8x
  • Mount: Screw 1/4" - 20
  • Circular Base: Diameter 1.69" (43mm)
  • Ports: 1 micro USB
  • Memory: 128 Mb
  • Rotation Speed: Up to 110° per second
  • Audio: Built-in speaker and microphone; 2-way audio; Noise & Echo cancellation
  • Alerts: Push notifications
  • Night Vision and Color Night Vision
Power
  • Power Cable Length: 6" (1.8 m)
  • Power Adapter Input: 110-240V (AC/DC)
  • Power Adapter Output: 5V/2000mA
Connectivity & Compatibility
  • 802.11 b/g/n, 2.4GHz (5GHz Wi-Fi not supported)
  • Upload speed 1.0 Mbps for SD, 1.5 Mbps for HD
Storage
  • Supports up to 256 GB microSD in ExFAT format
Weather & Temperature
  • Operating temp: -20°C - 50°C (-4°F - 122°F)
  • IP65 Water Resistance
Certifications
  • FCC, IC, UL, TSCA, IP65
Language
  • English
Warranty
  • 1-Year
Important note
  • Wyze Cam Pan v3 comes with one of two versions of the Mounting Kit, as shown here. The Mounting Kit pictured on the product packaging is currently of the original design but the package could contain the new design. Both mounts allow you to install the Pan v3 upside down.
  • 1x Wyze Cam Pan v3
  • 1x 6' micro USB Cable
  • 1x Power Adapter
  • 1x Mounting Kit (Please note: There has a been change in our mounting bracket's design. Customers may get either design regardless of the design on the packaging. However, this shouldn't affect functionality. Learn more here.)
  • 1x Quick Start Guide
