1 of 10
Wyze Cam OG
Wyze Cam OG
1080p Cam with Spotlight & Night Vision
Wyze Cam OG (Color)
Wyze Cam OG (Quantity)
$39.99CAD
The next generation of Wyze Cam has arrived. Now with quicker live-streaming, 3X faster notifications, improved 2-way audio, and a built-in spotlight. Indoor/outdoor*.
Note: There may be slight differences in appearance depending on which camera model you receive. The product functionality is identical. See the Tech Specs for details.
  • Color night vision camera.
    1080p HD Color Night Vision
  • Weather-resistant camera lens.
    IP65 Indoor/Outdoor Security
  • A bright spotlight on a black background.
    Built-In Spotlight with Integrated Siren
  • A black screen with a message about syncing a microSD card.
    24/7 Recording to Wyze microSD Card
    No subscription required.
Wyze Cam OG Specs
Color & Materials
  • Color: White or Black
  • Finish: Matte
  • Model: WYZECGSD
  • Image Sensor: CMOS-Starlight Sensor (1920 x 1080)
  • 2 spotlight (5000K, 40 lumens)
Dimensions
  • 2.05in x 2.05in x 2.05in (52mm x 52mm x 52mm) - 2025 WYZECGSD Model
  • 1.89in x 1.89in x 1.89in - WYZECGS Model
Weight
  • 4.4oz (125g) - 2025 WYZECGSD Model
  • 4.1 oz (116 g) - WYZECGS Model
Power
  • Power Adapter: Input - 110-240V (AC/DC) Output - 5V/1A
Built-in Spotlight
  • 40 Lumens
Additional Details
  • Power Cable Length: 6 ft (1.8 m)
  • Ports: 1 micro USB
  • Night Vision: 4 IR LEDs (850nm)
  • Digital Zoom: 8x
  • Field-of-View: 116°(DFOV), 99.7°(HFOV), 53°(VFOV) - 2025 WYZECGSD Model
  • Field-of-View: 121.4°(DFOV), 102.3°(HFOV), 54.1°(VFOV) - WYZECGS Model
  • Audio: Built-in Speaker & Microphone; Noise & Echo Cancellation
  • Local Storage: Supports up to 256 GB microSD in exFAT format
Connectivity & Compatibility
  • 802.11 b/g/n, 2.4 GHz Wi-Fi
Weather & Temperature
  • Weather Resistance: Indoor & Outdoor (IP65)
  • Operating: -4°F-131°F (-20°C-55°C)
  • Storage: -40°F-158°F (-40°C-70°C)
Language
  • English
Warranty
  • 1-Year
View our cam comparison chart
The latest 2025 model number is WYZECGSD on the box. The previous model number is WYZECGS.
Wyze Cam OG (Standard):
  • 1x Wyze Cam OG unit
  • 1x Indoor Power Adapter
  • 1x USB Cable
  • Wall Anchors
  • Wall Plate
  • Mounting Screws
  • 1x Quick Start Guide
Two white cameras on a table.
Independently amazing.
Upside down or right side up each camera operates on its own to cover every angle of any space.
A smartphone with a notification from the Wyze app.
3x faster motion notifications.
A speaker with a microphone on a wall.
Upgraded two-way audio.
Person holding a smartphone with a live video stream of their dog.
  • A smartphone displaying a local microSD card storage app.
    Supports all Wyze microSD cards, up to and including 256GB.
  • Get smarter security with Cam Plus.
A smartphone displaying a live view of a room.
A smartphone displaying a live view of a home.
An iPhone screen displaying an event review of a baby's sleep.
Wyze app settings page with various options to customize the app.
The image displays a smartphone screen with an alarm settings page.
A smartphone screen with a setting for alarm sounds.
A brand new app experience.
Unlike a stray Lego brick at 1 am, we've put all the handy tools exactly where you'd want them–from spotlight and siren controls to the new simplified event review.
Enjoy a new, easy-to-scan Recent Events section to quickly navigate footage.
Tell Wyze Cam OG exactly where you want it to watch. Get notifications only for detections within your customized zone.
  • A white Wyze Cam is sitting on a white stand.
    Wyze Cam OG
    • 120° Field of View
    • Built-In Spotlight with Color Night Vision
    • IP65 Weatherproof
    • Two-Way Audio
    • Works with Wyze Cam OG Stack Kit
  • A white Wyze Cam with a blue light on the bottom.
    Wyze Cam OG Telephoto
    • 3x Telephoto Camera (27° Field of View)
    • Color Night Vision
    • IP65 Weatherproof
    • Two-Way Audio
    Learn More
