1 of 6
A color-changing smart bulb with a BR30 shape.
Wyze Bulb Color BR30
Wyze Bulb Color (BR30) - 1 Pack Promotional SKU (CA) (Quantity)
$44.99CAD
Low stock: 80 left
Low stock: 80 left
Light up your life with a dimmable, color-changing smart BR30 bulb that works in the recessed lighting fixtures you already own. Set the mood with any of our 16 million ultra-accurate colors and a wide lumen range that can both out-shine and out-dim the competition.
Not for use in dimmer switches.
  • A black background with a single light bulb shining in the center.
    Extra Bright 950 Lumens
    16 Million Colors & Tunable White
    Accurate Colors with 90+ CRI
  • A black image of a ceiling lamp with four lights.
    BR30 Bulb Shape/E26 Base
Dimensions
  • 3.74in x 3.74in x 5.24in
Weight
  • 0.25lbs
Lumens
  • 30 lumens-950 lumens
Wattage Equivalent
  • 75W
Color Temperature
  • 1800K - 6500K
Color Rendering Index
  • 90+
Power
  • 11.5W
Working Voltage
  • AC120V~60Hz
Bulb Shape
  • BR30
Base
  • E26
Life Expectancy
  • 25,000 hours
Communication Mode
  • 802.11 b/g/n, 2.4GHz, Bluetooth
Integrations
  • Alexa, Google Assistant, IFTTT
Usage
  • Suitable for damp locations, Not for use in totally enclosed luminaries or with dimmers.
Operating Temperature
  • -4F - 104F
Storage Temperature
  • -22F - 122F
  • Wyze Bulb Color BR30
  • Quick Start Guide
Brighter. Dimmer. Better.
Most BR30 color bulbs max out at 650lm. Tune ours brighter (950lm/75W), dimmer (30lm), or anywhere between with a wide-ranging lumen output that’s as intense or as subtle as you need.
A living room with a couch and a painting on the wall.
16 Million Colors.
Whether it’s game day or wine night, precise color control in the Wyze app lets you turn moments into memories.
A living room with a blue couch, a table with a red cup on it, and a green and yellow lighting system. A bottle of wine sits on a table with a plate of cheese and grapes.
Game Day
Wine Night
A white bulb with a colorful rainbow pattern on it.
E26 Base. BR30 Shape.
Wyze Bulb Color BR30 fits standard, E26 recessed/can lighting sockets to deliver soft-edged, directional light.
Create your perfect, custom lighting scenes.
Create and save your own custom, multicolor lighting scenes in the Wyze app. Quickly change between dozens of saved and preset scenes with a tap.
A cozy fort made of blankets and pillows with a yellow light inside. A computer desk with a monitor, keyboard, and mouse.
Fort Night
Blue Light
A light bulb is turned on in a bathroom.
White light temperature control
Cool it down and focus or warm it up and relax. Dedicated white light controls let you choose the perfect setting for your activity.
Stay in sync with Sun Match.
The light in your home can influence your internal clock, mood, and productivity. Sun Match automatically adjusts the color temperature through the day. Enjoy brilliant, cool light in the afternoon and soft, warm light in the mornings and evenings.
90+ CRI Rating.
See truer and more brilliant colors in your home with an advanced Color Rendering Index (CRI) rating. Never mistake navy or black in your closet again.
A painting of a tree with red flowers on a white background. A painting of flowers in a vase.
Dull, washed out colors
Vibrant, true colors with increased CRI
Blue light bulb recycling bin.
Brilliant notifications.
Shine a brighter light on important reminders. Create time-based color events or automate using other Wyze devices to create powerful visual notifications all in the Wyze app. Never forget to take the bins curbside again.
A door with a red light on it.
Did you forget to shut your door?
Trigger a colorful warning light with Wyze Bulb Color (BR30) and Wyze Sense Motion Sensors or Entry Sensors.
Sleep Routines
A smartphone app showing a color bulb setting.
Dance to the beat of the music.
Group your Wyze Bulb Color (BR30) with Wyze Light Strip or Wyze Light Strip Pro to sync your lights/colors to the beat of your favorite tracks with Music Mode.
*Requires Wyze Bulb Color (BR30) to be grouped with Wyze Light Strip or Wyze Light Strip Pro
A screen shot of a room with different colored lights on.
Brilliant Smart Features.
Make it look like someone's home whenever you are away. Just enable "Vacation Mode" in the Wyze app and our bulb does the rest.
Group Wyze Bulb Color together and with Wyze Light Strips for greater and more efficient control.
