Skip to content
1 of 21
Secure Entry Advanced Bundle
The key is the palm of your hand.
SALE
$225.98 $249.96CADSAVE 9%
Wyze Palm Lock offers secure, contactless entry with advanced palm vein recognition technology for fast, key-free access. Easily manage entry through a numbered keypad with access codes, control your lock remotely via Wi-Fi, and enjoy up to 6 months of battery life. For added reliability, it also includes a manual key option and auto-lock functionality for total peace of mind.
Wyze Cam Pan v4 enhances your security coverage with a redesigned 360° pan and 180° tilt camera, providing a full view of any space. Built to withstand the elements, it’s IP65 weather-resistant and ideal for indoor or outdoor use, ensuring that every angle is protected—day or night.
Together, these devices deliver intelligent access and comprehensive monitoring for your home or business—all managed seamlessly from anywhere.
  • A black image of a palm vein.
    Touchless Palm Scan Unlock
    Just hover your palm near the reader and the door unlocks using highly secure, contactless biometric tech.
  • A black screen with a white logo and text reading "Wifi Control".
    6 Entry Methods + Wi-Fi Control
    Unlock with your palm, code, keys, app, voice-assistant or latch. Control from anywhere with Wi-Fi.
    No Down Time with Dual Battery System
    The main battery provides 6-months of charge. The backup keeps things running while you recharge.
  • hammer and wrench icon
    Replaces Existing Deadbolt
    Includes a manual lock and key option (set of keys included).
Wyze Palm Lock Specs
Colors & Materials
  • Model: WPLCK1
  • Finish: Matte
  • Color: Black
  • Materials - Frame: Aluminum Alloy and Steel
  • Materials - Panel: Tempered Glass
Dimensions
  • External Assembly: 6.14 x 2.89 x 1.28 in (156 x 73.5 x 32.5 mm)
  • Internal Assembly: 7.16in x 2.93in x 1.18in (182mm x 74.5mm x 30mm)
Weight
  • 4 lbs (64 oz)
Wyze Cam Pan v4 Tech Specs
Color & Materials
  • Color: White
  • Finish: Textured Matte
  • Materials: Body: Polycarbonate, Lens: Glass + plastic
Dimensions
  • Dimensions (H,W,D): 4.91in x 2.48in x 2.17in (124.7mm x 63mm x 55mm)
  • Weight: 274.8 g (0.61 lbs)
Video
  • Resolution: 4K/8MP Resolution (3840 x 2160)
  • Field of View: 105.4° (D), 88° (H), 46° (V)
  • Pan Tilt Range: 360° (H) x 180° (V)
  • Video FPS: Daytime - 20 fps, Nighttime - 15 fps
  • Digital Zoom: 8x
Wyze Palm Lock
Certifications
  • Certifications: FCC ID+IC, TSCA+CA65, ANSI-BHMA, ROHS, REACH, SVHC, PFAS, IEC62133
Connectivity & Compatibility
  • Communication Method: Bluetooth® 5.0, 2.4 GHz Wi-Fi, Wi-Fi 6
  • Compatibility: Wyze app 3.7+, Android 10.0+ or iOS 16.0+
Door Compatibility
Compatible with most standard US doors. Replaces existing single-cylinder deadbolt.
Warranty
1-Year
Wyze Cam Pan v4
Temperature
  • Storage Temperature: -4°F-122°F (-20°C-50°C)
  • Operating Temperature: -40°F-158°F(-40°C-70°C)
Weather Resistance
  • IP65 Weather Resistant
  • Indoor/Outdoor compatible
  • Wi-Fi: 802.11a/b/g/n/ac/ax, 2.4/5 GHz, Wi-Fi 4/5/6
  • Phone app support: Android 10.0+, iOS 16.0+
Languages
  • English
Warranty
  • 1-Year
Wyze Palm Lock
  • 1x Wyze Palm Lock
  • 1 x Exterior Assembly
  • 1 x Interior Assembly
  • 1x Mounting Plate
  • 1x Deadbolt
  • 1x Strike Plate
  • 1x Dust Box
  • 1x Main Battery
  • 1x Backup Battery
  • 1x Silicone Plug
  • 1x Drilling Template
  • 1x Quick Start Guide
  • 2x Mechanical Keys
  • 4x Wood Screws
  • 3x Interior Panel Screws
  • 4x Mounting Screws
Wyze Cam Pan v3
  • Wyze Cam Pan v4 x1
  • 6' microUSB Cable x1
  • Power Adapter x1
  • Mounting Kit x1
  • Quick Start Guide x1
Highly secure, contactless biometric tech identifies you based on the unique pattern of veins beneath the surface of your palm. Just hover your palm near the reader, and voilà, the door unlocks. It’s like a secret handshake with your front door.
Unlocks for all types of hands.
Young, weathered, wet, or dirty, palm vein recognition is more accurate than fingerprints because it looks beneath the skin, so surface conditions don’t get in the way.
A boy is holding up his hand with a thumbs up.
A man holding up a sign that says "5".
  • A person is holding a door handle.
    Palm Scan
  • A black and grey electronic lock with a green button on the front.
    Access Codes
  • A phone with a lock screen that says "Front Lock" and "Wyze Palm Lock Methods 04".
    App Control
  • A person is unlocking a device with a key.
    Manual Key
  • A black and white image of a cross with a Google logo on it.
    Voice Control
  • A black lock on a door.
    Manual Latch
1 of 6
Check for door compatibility.
The Wyze Palm Lock replaces your existing lock bolt and will work on most standard residential doors sized between SPECS. Click to see more details.
A smartphone displaying a lock screen with the message "Access and Sharing" and a button to unlock the device.
Numbered keypad with access codes.
A bright, numbered keypad illuminates with a simple tap. Set and store up to 50 unique access codes, or create one-time guest passcodes that expire on a schedule.
A black device with a white label that says "Wyze Palm Lock.
No down time.
Wyze Palm Lock uses a dual-battery system, so there isn't any down time. The main battery provides up to 6 months of battery life, and the backup battery keeps things running for up to two weeks while you charge the main.
Peace of mind with auto lock.
A built-in gyroscope detects the angle and movement of the door in real time. Once it senses the door has closed then it automatically locks, preventing false or jammed locks.
A black smart lock that can be controlled via a smartphone app.
A black and green lock with the number 15493 on it.
Featuring anti-peep technology.
With anti-peep technology, you don't have to worry if someone watches you enter your code.
Simply add extra digits before or after your code and Wyze Palm Lock will still unlock.
A person is holding a key to a Wyze Palm Lock.
Discreet manual lock and key option.
Still yearning for the comfort of a traditional key? We got you covered. Simply slide down the damping cover and manually unlock the old-fashioned way (set of keys included).
Hey Luke, who's your deadbolt daddy?
OK, maybe don't ask him that. Instead, see what this modern day Skywalker had to say when we asked him about Wyze Palm Lock.
A Wyze Palm Lock is displayed on a smartphone screen.
Works with Wyze video doorbells.
Lock and unlock directly from the live view of your Wyze video doorbell without switching between screens to open the door for family and friends.
A black and wet Wyze Palm Lock Shopify 13.
IP53 weather-resistant & BHMA3 certified.
Backed by the Builders Hardware Manufacturers Association, this lock has been tested, slammed, twisted, and splashed thousands of times to make sure it can handle real life. It meets rigorous standards for security, durability, and performance. It’s not just smart, it’s strong.
BHMA Logo
Backed by industry-best security features.
  • A hand holding a leaf.
    Palm Vein Recognition
    Unlike fingerprints, palm vein pattern is an internal characteristic of the human body and cannot be copied or forged.
  • A lock on a door.
    Hardware Encryption
    Your palms and passcodes are encrypted and stored locally on the lock so no one can access your data.
  • A bell icon on a black background.
    Security Siren & Alerts
    An alarm sounds from excessive incorrect unlock attempts, and if you leave the door open (customizable in the Wyze app).
1 of 3
A smartphone screen displaying a lock screen with a green circle and the words "Front Lock" and "Locked" on it.
A smartphone screen displaying a list of users and their corresponding names.
A black device with a green outline and the words "USB-C Port" written on it.
A smart lock on a door with a message that says "Alexa, lock the front door.
Unlock even more goodness
Control and monitor the lock status from anywhere, anytime with Wi-Fi. See the full access history in the Wyze app. View how it was unlocked, the exact time, and if there were any failed passcode attempts.
If the batteries die while you're away, the USB-C port allows for a charge from a power bank so you can enter your access code for entry.
Works with smart assistants like Amazon Alexa and Google Assistant. Use your voice commands to lock, unlock, and check the status of their door. For security, unlocking via voice command requires a PIN which authorizes the action.
  • Try saying "Alexa, unlock the front door."
  • Try saying "Google, lock the side door."
  • Try asking "Alexa, is my front door open?"
Use Wyze Cam Pan v4 For Total Porch Protection.
Automatic motion-tracking.
Those cans never knew what hit them, but Pan v3 did. That's because it detects motion, follows, and records it automatically. Its upgraded tracking motor is quieter than a gossiping church mouse, so it won't wake napping babies or startle pets.
...wait till' the end 😂
See the whole room with 360° pan and 180° tilt.
Now with double the tilt coverage, Pan v3 can look straight up and down. Just like my middle school gym teacher, but way less judgy. It was an awkward time for me, okay?
