Direkt zum Inhalt
Lesen Sie unsere Erklärung zur Barrierefreiheit
Direkt zu den Produktinformationen
1 of 9
Lock + Gateway + Keypad
$183.98CAD
Low stock: 99 left
Low stock: 99 left
Exklusive Vorteile auf Wyze.com
18-monatige Garantieverlängerung
Erhalten Sie beim Kauf dieses Produkts auf wyze.com eine 18-monatige Garantieverlängerung. Außerdem profitieren Sie bei jeder Bestellung von speziellen Bundles, exklusiven Angeboten und Prämien.
Keep your door's dead bolt. Just add the brains.
Alle Details anzeigen
A mother carrying a child while watching her other child open the door to the house.
Unlocks as you approach. Locks when you leave.
Hands full? Wyze Lock knows when you arrive home and automatically unlocks as you approach. When it senses the door is closed, it automatically locks behind you.
Wyze Lock Details
  • Color: Silver
  • Dimensions: 4.9" Length x 2.5" Width x 1.3" Depth (2" including knob)
  • Weight: 0.67 lb
  • Power Source: 4x AA Batteries (included)
  • Battery Life: 5-6 months (depending on usage)
  • Communication Method: Bluetooth, Zigbee
  • Range: To Keypad: 9', To Gateway: 50', BLE to phone: 16'
  • Compatibility: Android 5.0+, iOS 9.0+
  • Weather Resistance: Indoor use only
  • Operating Temperature: 14°F - 131°F / -10°C - 55°C
  • Storage Temperature: -22°F - 158°F / -30°C - 70°C
Keypad (sold separately)
  • Color: Silver
  • Dimensions: 3.7" Length x 1.3" Width x 1.0" Depth
  • Weight: 0.1 lb
  • Power Source: 2x AA Batteries (included)
  • Battery Life: 4-6 months (depending on temperature)
  • Range: To Lock: 9'
  • Weather Resistance: IPX5
  • Operating Temperature: -4°F - 140°F / -20°C - 60°C
Gateway
  • Color: White
  • Dimensions: 2.1" Length x 2.1" Width x 1.2" Depth (1.9" including pins)
  • Weight: 0.12 lb
  • Power Source: 110-240V, ~60Hz
  • Battery Life: NA
  • Communication Method: Bluetooth, Zigbee, Wifi
  • Range: To Lock: 50', To Router: 50
Same key. Same deadbolt. Infinitely smarter.
Wyze Lock uses your door's existing hardware so you can keep your key, but still get all the benefits of a smart lock.
Wooden door open with keys opening the Wyze Lock.
Person holding phone with Wyze app open and the status of their backyard door being locked
Remote access and history viewing.
Unlock the door for friends and family, even if you're away from home with a tap in the Wyze app. See who accessed your home from anywhere and get notified whenever the door is left unlocked.
Wyze Lock installed on a wooden door with an Amazon Alexa device nearby as the two devices communicate
Control with Alexa, Google, and Wyze Switch.
Wyze Lock works with Alexa and Google Assistant so you can lock your door by just saying, "Hey Alexa, lock the front door."
Wyze Lock also works with Wyze Switch, so you can lock or unlock your door with a tap.
Person holding a phone with an overlay of a phone notification that informs them of a virtual key to the home
Send virtual keys to family and friends.
Wyze Lock makes sharing access to your home simple and puts you in complete control. Easily grant or revoke access to your home through the Wyze app. Only you can see the history of how each key is used.
Compatible with most single cylinder deadbolts.
We made Wyze Lock to work with most single cylinder deadbolts—deadbolts with a keyhole on only one side. Find out if your deadbolt works with Wyze Lock here.
Prefer your guests access with a code?
Meet Wyze Lock Keypad, a wireless, mountable keypad that communicates with Wyze Lock to unlock or lock your deadbolt with a code.
Smartphone app enabling the locking feature of Wyze Lock
Unlock with your Wyze Video Doorbell.
You can control your Wyze Lock right from the Wyze Video Doorbell (or Video Doorbell Pro) viewer, so you don't have to switch between apps just to open the door.
Shop Wyze Video Doorbell
Installs in under 15 minutes.
Wyze Lock only replaces the interior side of your existing deadbolt, so it's much quicker (and easier) to install than a complete deadbolt replacement.
  • Wyze Lock Bolt
    Wyze Lock Bolt
    Built for Convenience: Quickly unlock the door with your fingerprint
    • Fingerprint unlock
    • Local app access only
    • No Wyze automations or Alexa/Google support
    • Replaces existing deadbolt
    • Basic Auto-Lock
    • No Auto-Unlock
    • Keypad built-in
    Shop Wyze Lock Bolt
  • Wyze Lock
    Wyze Lock
    Built for Smart Homes: Monitor and access your door from anywhere
    • No fingerprint unlock
    • Access the app from anywhere
    • Wyze automations & Alexa/Google support
    • Attaches to existing deadbolt
    • Advanced door position Auto-Lock
    • Auto-Unlock
    • Optional keypad sold separately
In den Warenkorb gelegt
Kostenloser Versand ab einem Bestellwert von 59 $
Zwischensumme
Warenkorb anzeigen
