Skip to content
1 of 7
Ultimate smart home front porch security.
Style
SALE
$199.99 $229.98CADSAVE 13%
Low stock: 5 left
Low stock: 5 left
$0.00 FREE / 1 month
14-Day Cloud Storage
Subscriber Discount
Meet the ultimate smart home front porch security bundle. With Wyze Video Doorbell and Chime, view your front porch in 1080p HD and say hello with two-way audio. With Wyze Lock, unlock and lock the door remotely and view your lock history in the Wyze app.
  • Video camera icon
    View your porch in 1080p HD
  • Locked home and smartphone icon
    Lock/unlock the front door remotely
  • Motion event icon
    View motion events and lock history
  • Voice assistant icon
    Works with Alexa and Google Assistant
Wyze Video Doorbell
  • Power: 16V-24V AC, ≥10VA (May use existing doorbell-chime circuit, or standalone transformer and wires.)
  • Weight: 1.7oz / 49gSize: 1.5'' x 3.25'' x 0.625''
  • Image Sensor: 2K (2048 x 1536)
  • Camera: F2.0 aperture, 2.7mm focal length, 1/2.8" CMOS
  • Image Quality: 1080p and 480p w/ 8x Digital Zoom
  • Frames per Second: 20 Daytime, 15 Nighttime
  • Audio: Built in Speaker & Microphone (with 2-way Audio & Noise/Echo Cancellation)
  • White LED (Fill Light): 6 x 5000K (daylight color temperature)
  • IR Night Light: 4 x 940nm Infrared LED
  • Connectivity: Direct to WiFi 802.11 b/g/n, 2.4GHz (5GHz WiFi not supported)
  • Sub1G: 906.8MHz, used for local connection between doorbell and chime.
  • IP65 Weather-resistant
  • Storage Temperature: -40 to 176°F (-40 to 80°C)
  • Operating Temperature: -4 to 122°F (-20 to 50°C)
  • Field of View: 120° Vertical x 88° Horizontal
  • Operating Systems: iOS 9.0 and Android 5.0 or later
  • Data Security: End-to-end encryption, HTTPS secure transfer protocol, AES 128-bit encryption
Wyze Chime
  • Chime Power: Standard US Power Outlet: 100V-240V, 0.1A, 50/60Hz
  • Weight: 2.0 oz / 56g
  • Size: 2'' x 2'' x 1.4''
  • Chimes: 5 modern, 4 classic doorbell, 3 animal sounds, 6 automation sounds, 1 intruder alarm
Lock
  • Color: Silver
  • Dimensions: 4.9" Length x 2.5" Width x 1.3" Depth (2" including knob)
  • Weight: 0.67 lb
  • Power Source: 4x AA Batteries (included)
  • Battery Life: 5-6 months (depending on usage)
  • Communication Method: Bluetooth, Zigbee
  • Range: To Keypad: 9', To Gateway: 50', BLE to phone: 16'
  • Compatibility: Android 5.0+, iOS 9.0+
  • Weather Resistance: Indoor only
  • Operating Temperature: 14°F - 131°F / -10°C - 55°C
  • Storage Temperature: -22°F - 158°F / -30°C - 70°C
Keypad (sold separately)
  • Color: Silver
  • Dimensions: 3.7" Length x 1.3" Width x 1.0" Depth
  • Weight: 0.1 lb
  • Power Source: 2x AA Batteries (included)
  • Battery Life: 4-6 months (depending on temperature)
  • Range: To Lock: 9'
  • Weather Resistance: IPX5
  • Operating Temperature: -4°F - 140°F / -20°C - 60°C
Gateway
  • Color: White
  • Dimensions: 2.1" Length x 2.1" Width x 1.2" Depth (1.9" including pins)
  • Weight: 0.12 lb
  • Power Source: 110-240V, ~60Hz
  • Battery Life: NA
  • Communication Method: Bluetooth, Zigbee, Wifi
  • Range: To Lock: 50', To Router: 50
Wyze Lock
  • Wyze Lock x1
  • Wyze Lock Gateway x1
  • AA Batteries x4
  • Adhesive Strip x1
  • Mounting Plate x1
  • Adapter x3
  • Quick Start Guide x1
Wyze Video Doorbell + Chime
  • Wyze Video Doorbell x1
  • Wyze Chime x1
  • Wall Plate x1
  • Wedge (Horizontal, 30°) x1
  • Wire Caps x4
  • Bracket Screws x2
  • Screws & Expansion Tubes x2
  • Extension Wires x2
  • Fuse x1
Smartphone app enabling the locking feature of Wyze Lock
Did you know?
You can lock/unlock the door right from the Wyze Video Doorbell (or Video Doorbell Pro) viewer. Watch the video to see how simple it is.
