Skip to content
1 of 10
Cam v4 + 32GB microSD card
The clearest Wyze Cam ever made.
Wyze Cam v4 (Color)
SALE
$59.98 $64.98CADSAVE 7%
Bundle Includes
Bundle Includes
Get unmatched security with Wyze Cam v4. Crystal-clear 2.5K QHD resolution, Enhanced Color Night Vision, and motion-activated spotlight keep your home safe day or night. Plus, 24/7 local recording, Wi-Fi 6 support, and compatibility with Alexa and Google Assistant for ultimate convenience. Plus, unlock continuous recording and time lapses for your Wyze Cams with the included 32GB MicroSD card — never miss a moment, whether it’s big or small!
    2.5K QHD Resolution + Color Night Vision
    See every detail clearly in vibrant color, day or night.
  • weather icon
    Indoor/Outdoor Security
    Place it anywhere with IP65 weather resistance.
  • spotlight icon
    Motion-Activated Spotlight
    Automatically trigger the LED light and voice prompt for extra security.
  • A purple circle with a white cross in it.
    Person Detection and more
    With Cam Plus, you get unlimited video length storage and advanced AI detection.
Wyze Cam v4 Specs
Colors & Materials
  • Colors: White and Grey
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • Lens FOV: DFOV 115.8°, HFOV 98.5°, VFOV 53.1°
  • Sensor: CMOS Starlight Sensor
  • LED Indicator: Front. Red + Blue.
Dimensions & Weight
  • 2in x 2in x 2 3/8in
  • 0.49 lb (222 g)
Mounting
  • Stand, wall mount, ceiling mount,
    or magnetic wall mount (adhesive)
Power
  • Power Adapter: Input 110-240 V (AC/DC), Output Indoor 5V/1A
  • Outdoor Power Adapter (sold separately)
  • Cable: 6-Foot Flat micro USB to USB-A
Video
  • Resolution: 2.5K QHD (2560x1440)
  • Digital Zoom: 8x
  • Wide Dynamic Range (WDR): Yes
  • IR Lights: 4x850 nm
  • Day/Night Vision: Yes
  • Night Vision: 4 IR LEDs (850 nm) + 2 white spotlight LEDs (72 lumens)
  • Color Night Vision: Yes
  • Video Encoding: H.264
  • Video FPS: Daytime 20 FPS / Nighttime 15 FPS
Audio
  • Speaker: 99dB, waterproof
  • Simultaneous 2-way Talk: Yes
  • Built-in Siren: Yes
  • Noise & Echo Cancellation: Yes
Connectivity & Compatibility
  • Bluetooth® 5.2
  • Wi-Fi: 2.4 GHz Wi-Fi, Wi-Fi 6
Storage
  • Local (microSD card required)
  • MicroSD card up to 512 GB
  • Cloud (with subscription plan)
Weather & Temperature
  • IP65 weather resistant
  • Operating temp: -4ºF - 122ºF (-20ºC - 50ºC)
  • Storage temp: -40°F - 158°F (-40°C - 70°C)
Warranty
  • 1-Year
Cam v4 - 1 pack:
  • Wyze Cam v4 x1
  • Quick Start Guide x1
  • Wall Mount Plate x1
  • Wall Mount Plate Tape x1
  • Screw Kit x1
  • Indoor USB Power Adapter x1
  • 6-Foot Flat micro USB to USB-A cable x1
+32GB MicroSD Card
A young boy is flexing his arm in front of a map of the world.
Wyze Cam v4 with WDR
No WDR
A Wyze Cam v4 is shown in a green circle.
Even more features to love.
Unlock amazing camera features
With the Included 32GB MicroSD you can unlock powerful features for free. No monthly fees.
Inserting an SD card for 24/7 recording
Local Recording
Get around the clock local recording for free with your Wyze Cam.* Add a MicroSD card and simply setup your settings inside of the Wyze app. That's it. Now you can access playback footage through the app or physically remove the card to access the files on your computer.
*The majority of Wyze Cams have an MicroSD card slot built-in, however, please double-check technical specs to be sure if there is a slot and the size of card that is compatible.
A smartphone with an app that shows a baby in a crib.
night vision house picture dark
Outside view of house where the lights in each room are a different color
glass house light
v3 image
v3 image
Available footage will be highlighted in the timeline. Pinch and zoom on the timeline to select a specific point in time. It's that easy.
Quickly find events in a few convenient taps.
Capture every moment effortlessly! Your camera will keep rolling, recording footage directly to the microSD card. Revisit and relive your favorite moments at your convenience. No subscription needed.
Capture the world in motion and watch as time unfolds before your eyes. From stunning sunsets to bustling cityscapes, create mesmerizing timelapse videos. No extra cost.
Saving videos to your Wyze Cam is as easy as 1-2-3.
To learn more, click the button below.
* Requires Wyze Outdoor Power Adapter for outdoor use.
* Requires microSD card for local recording.
