Skip to content
1 of 4
Wyze Solar Panel
Wyze Solar Panel
12W Solar Charger for Outdoor Cams
Style
$34.99CAD
Record for longer. Attach a solar panel to your Wyze Battery Cam Pro to extend the battery life. Designed to be weather resistant and mountable anywhere.
Works with Wyze Cam Outdoor v1/v2 and Wyze Battery Cam Pro.
  • Weather-resistant page.
    IP65 Weather Resistant
  • A black background with a streamlined icon of a hammer and wench.
    Easy 360° Mount
  • sunset icon
    Run on Sun Power
  • plug icon
    13-foot Power Cable
Wyze Solar Panel Details
Color
  • White frame and mount
  • Black solar cells
Dimensions
  • 173 mm x 120 mm x 17 mm
Solar power rating
  • 2.5W, 5VDC
Micro USB cable length
  • 13 ft (4m)
Waterproof level
  • IP65
  • Wyze Cam Outdoor and Wyze Battery Pro recharge frequency vary based on device settings, motion notifications, and sun exposure in the area of placement.
  • For the most sunlight, position your Wyze Solar Panel so that it’s facing south and is tilted upward at a 30º angle.
  • Make sure it’s not in a shaded area and avoid placing it directly under a tree. Tree sap, falling leaves, and large shadows can greatly reduce the solar panel’s efficiency.
  • Solar panel x1
  • Wall mount x1
  • Micro USB adapter cable x1
  • USB-C adapter cable x1
  • Screws x3
  • Wall anchors x3
  • Quick start guide x1
The solar panel converts sunlight into electrical energy to charge Wyze Cam Outdoor or Wyze Battery Cam Pro.
The maximum power output is 2.5 watts.
Mount the solar panel where you get the most sunlight during the day. Make sure it’s not in a shaded area and avoid placing it directly under a tree. Tree sap, falling leaves, and large shadows can greatly reduce the solar panel’s efficiency.
No, we do not recommend using Wyze Solar Panel with other Wyze cameras. This is only compatible with Wyze Cam Outdoor and Wyze Battery Cam Pro.
Wyze Solar Panel is an accessory for Wyze Cam Outdoor and Wyze Battery Cam Pro to extend its battery life. We do not recommend using it to charge other devices.
Depending on the intensity of the sunlight, the solar panel is unlikely to perform well in cloudy or rainy weather.
Yes, Wyze Solar Panel is IP65 weather resistant and dustproof but is not waterproof.
No, Wyze Solar Panel is an accessory for Wyze Cam Outdoor and Wyze Battery Cam Pro to extend its battery life and is not related to the Base Station. Your Base Station needs a constant power source to keep your Wyze wireless cameras online.
Continuous Power
Extend the length of time you can keep your Wyze cam recording without having to bring it back inside to recharge.
A solar panel is attached to a house.
360° Freestyle Mount
Get the perfect angle to achieve maximum sun exposure IP65 Weather Resistance - Weatherproof and dustproof.
A person is holding a white device that is plugged into a wall outlet.
Long Range Power Cable
A 13-foot weatherproof power cable provides ultimate mounting flexibility.
1 of 4
Cameras that work with this solar panel
  • MicroSD Cards
    Regular price From $25.99 CAD
    Regular price CADDeal From $25.99
    Choose your option
    View Options
