Skip to content
1 of 9
Wyze Bird Feeder
Wyze Bird Feeder
Smart Bird Feeder Camera with Live View
⚠️ Note: Camera and solar panel sold separately.
Color
SALE
$54.99 $69.99CADSAVE 21%
NEW Bird Detection
Great news for Wyze Battery Cam Pro owners. Bird Detection is now available with Wyze Security Plans. Test it with a Cam Plus trial.
It's birdwatching on easy mode. View and record live video of every feathered visitor with Wyze Bird Feeder. The feeder's vibrant blue body and orange top is designed to attract a variety of birds. Use your favorite top-selling Wyze Camera to explore the world around you like never before. A must-have for the birder in all of us!
  • Icon for IP65 page.
    Weather-Resistant Polycarbonate
    Constructed for resilience against outdoor elements.
    Works with Multiple Wyze Cameras
    Compatible with Cam v3/v4, Battery Cam Pro, and Cam Outdoor v1/v2.
    Includes Macro Lens Adapter
    Macro magic. Switch the focus from distant sights to close-up bird watching.
  • A black screen with a white icon.
    Watch Live in the Wyze app
    Stream live video on your phone without any fees.
  • Color: Blue and Orange
  • Material: Polycarbonate
  • Dimensions: 7.48 in x 10.12 in x 8.58 in (190mm*257mm*218mm)
  • Net Weight: 2.5 lb (1.13 kg)
  • Gross Weight: 3.42 lb (1.55 kg)
  • Bird Seed Capacity: 1 Liter
  • Weather Resistance: IP65 Weatherproof
  • Operating Temperature: -4°F to 122°F (-20°C to 50°C), Humidity < 90%
  • Warranty: 1 year
  • Wyze Bird Feeder x 1
  • Food Tray x 1
  • Food Tray Stand x 1
  • Solar Panel Cover x 1 (Wyze Solar Panel sold separately)
  • Camera Bracket x 1
  • Lens Bracket x 1
  • L-Shaped Bracket x 1
  • Suction Cup Bracket x 1
  • Pillar Connecting Piece x 1
  • Cable Tie x 1
  • Suction Cup x 2
  • Safety Cord x 1
  • Mounting Cord x 1
  • Screw Accessory Pack x 1
  • Screwdriver x 1
  • Quick Start Guide x 1
Wyze Bird Feeder is compatible with Wyze Cam Outdoor v1/v2, Wyze Battery Cam Pro, and Wyze Cam v3/v3 Pro/v4. If using a Wyze Cam that is not battery-powered, you'll need a Wyze Outdoor Power Adapter to plug it into power.
Wyze Bird Feeder was designed specifically for select Wyze Cams - from the housing to the lens bracket.
Yes, it works with Wyze Solar Panel! You can use a Wyze Solar Panel (sold separately) with a Wyze Battery Cam Pro or Wyze Cam Outdoor v1/v2 to minimize taking down the camera to recharge it. Truly hassle-free.
While you can view and manage the camera installed in the bird feeder from the Wyze app, Wyze Bird Feeder itself is not a connected or an IoT device. We say it's the smartest way to bird watch.
After much research and consultation, we’ve concluded that any attempt to prevent squirrels from visiting would be futile. Instead, we focused on making sure that the materials used will be able to withstand significant damage, which should prevent the squirrels from destroying the feeder itself. Right now, our priorities lie in making sure that no harm could come to our feathered friends.
It has a sloped food tray that slowly dispenses the bird feed. Yay gravity!
Not at this time, but we happen to love the funky blue and orange.
It depends on what species of bird you want to attract, and in what season. Any dry seed mix will work in Wyze Bird Feeder, but we're not bird experts. Head to your local feed & seed supply store for recommendations.
Wyze Bird Feeder
Birding on easy mode.
A screenshot of a computer screen with a video playing.
A person holding a cell phone with a picture of a bird on it.
A blue and red bird feeder with a camera inside.
Weather-resistant for all seasons.
Birds of every feather will flock your way, no matter the weather. Come rain or shine, the durable polycarbonate design of Wyze Bird Feeder serves as a safe haven for wild birds to hang out and grab a bite.
A bird feeder with a blue and orange base.
Easy install with many mounting options.
Choose between 5 easy installation options—wall, tree, pole, cord, and suction cup. Place it anywhere you (or they) need it.
  • A small bird is sitting on a bird feeder, looking at a camera.
    Compatible with Wyze Cams for remote birdwatching.
    Wyze Bird Feeder supports various Wyze cameras, including Battery Cam Pro, Cam v3/v4, and Cam Outdoor v1/v2.
  • A white circle with a black border.
    Macro Lens Adapter included.
    It's like a monocle, but for your Wyze Cam. This special lens slips over compatible cameras correcting the focus to ensure you get clear up-close views of bird friends.
  • A solar panel on a white pole.
    Compatible with Wyze Solar Panel (for battery cam setups).
    There’s a designated space for a Wyze Solar Panel to minimize recharging for battery powered cameras.
  • A man holding a camera with a picture of a camera on it.
    Live stream video and get notifications with the Wyze app.
    View, record, and get notified about every visitor with the Wyze app.
1 of 4
    2K HDR with Color Night Vision
    Capture more details.
  • Battery
    Removable Battery Packs
    Swap and recharge to eliminate downtime.
  • A black screen with a single white letter "W" on it.
    Outdoor/Indoor. Wire-Free.
    Place it anywhere. Hassle free setup.
  • solar panel icon
    Works with Solar Panel
    Convert sun rays into power so you can leave your camera up longer with less charging.
  • Purple circle with a white icon of a bird in the center
    Bird Detection
  • Wyze Cam V3 front view
    Wyze Cam v3
    From $32.98
    Shop now
  • A white camera with a blue light on the bottom.
    Wyze Cam v4
    From $35.98
    Shop now
  • (Refurbished) Wyze Cam Outdoor v1
    Wyze Cam Outdoor v1
    See our latest wireless cam, Wyze Battery Cam Pro.
  • A black camera with a white base.
    Wyze Cam Outdoor v2
  • A white camera with a light on it.
    Everyday low price $125
    Shop now
1 of 5
  • A red bird perched on a blue perch.
  • A bird perched on a blue object.
  • A small brown bird sitting on a blue tray.
  • A blue jay perched on a blue bird feeder.
1 of 4
Send videos and images of bird friends to wow@wyze.com! We'd love to share them.
⚠️ WARNING: THE ELUSIVE "FUR BIRD" ⚠️
Disclaimer: While our bird feeder is top-notch, it unfortunately doesn’t include a squirrel defense system. These tiny furry ninjas who’ve mastered the art of stealth and parkour will likely visit. So, sit back, relax, and enjoy the inevitable squirrel circus. You’ve been warned, friend.
A cartoon of a squirrel with a sign that says "will launch self as ninja.
