8 Common Misconceptions About Keyless Locks
Keyless Bluetooth locks are becoming increasingly popular as an alternative to traditional key-based locks. With a keypad, fingerprint, or Bluetooth app access, keyless locks offer convenient and secure ways to access your home. But there are many misconceptions about these locks. In this post, we discuss 8 common misconceptions about keyless locks - especially those with Bluetooth, fingerprint, and keypad options.
Smart lock bolt
1. They Are Not Secure
Criminal picking a door lock
Traditional door locks can be picked by locksmiths within 7 seconds to 10 minutes! How many movies have we seen where the lock gets picked by friends and foe?
By losing the keyhole, there is 0 chance of your home getting unlocked by a bobby pin. Plus, Bluetooth fingerprint locks like Wyze Lock Bolt use advanced encryption technology and have no cloud access to ensure maximum security.
2. They Are Difficult to Set Up or Use
Another common misconception is that keyless Bluetooth locks are difficult to install. However, these locks are designed to be easy to install and can be done by anyone with basic DIY skills. It took a college student (who has no home repair or life skills) 20 minutes to install and set it up with the app. And they’re intuitive and convenient to use too. Just ask my 5 year-old and his old-school, immigrant grandma.
3. They Are Expensive
Keyless Bluetooth fingerprint keypad locks can often be more expensive than traditional locks. Not at Wyze. Compare $300 to our $79.
4. They Are Not Compatible with All Doors
There is a common misconception that keyless Bluetooth locks are not compatible with all types of doors. However, these locks are designed to work with most US doors. You can always check the recommended dimensions first, too.
Lock bolt guide
5. They Are Prone to Malfunctioning
Keyless Bluetooth fingerprint keypad locks are often perceived as being prone to malfunctioning. However, these locks are designed to be reliable and operate for years without any issues. You think we want hundreds of lawsuits? Nah, we run our locks to the ground to check for these bugs.
6. They Can Be Hacked Easily
There is a belief that app-connected locks can be easily hacked. However, these locks use advanced encryption technology to prevent hacking and unauthorized access.
7. They Require Regular Maintenance
Some people believe that keyless Bluetooth fingerprint keypad locks require frequent maintenance. However, these locks are designed to be low-maintenance and only require changing the batteries every 10-12 months. And changing the batteries is super easy too - pop off the cover in the indoor unit, then put it back on. No unscrewing necessary.
8. They Are Difficult to Program
Another common misconception is that keyless Bluetooth locks are difficult to program. That’s what the app part is for! Pairing takes seconds and then you’re good to go. No memorizing codes or programming. Just open the app and tap away.
In conclusion, keyless, Bluetooth, fingerprint, and keypad locks are a convenient and secure way to access your home or office. By understanding the facts about these locks, you can make an informed decision about whether they are the right choice for you. For most, they are.
Check out Wyze Lock Bolt
cameras
By Garrett Bogar
Best Video Doorbell for Renters - Wyze Labs, Inc.
guides
By Silas Phillips
Living in a rental property usually means living by someone else's rules, which is why the best video doorbells for renters are the Wyze Battery Video Doorbell or the Wyze Duo Cam...
Newsletter background
Be in the know
