Best Security Cameras Under $50
If you're hunting for the best security cameras under 50 dollars, the answer is delightfully simple: grab the Wyze Cam v4 for stunning 2.5K clarity, the Wyze Cam Pan v3 to track motion across your massive living room, or the Wyze Cam OG to aggressively illuminate those sketchy tight corners. You want total peace of mind, but you also want to keep your hard-earned cash for important things—like an overpriced iced coffee or an extra-large pepperoni pizza. Good news! You don't have to sacrifice quality for price, especially when you know exactly where to look.
Here is how our budget-friendly MVPs stack up:
Camera Price Resolution The Superpower Perfect For
Wyze Cam v4 $35.98 2.5K QHD Enhanced Color Night Vision Upgrading your entire perimeter on a budget.
Wyze Cam Pan v3 $39.98 1080p HD 360° Pan & 180° Tilt Massive rooms, big backyards, and chaotic pets.
Wyze Cam OG $19.98 1080p HD 40-Lumen Built-in Spotlight Covering tight corners and blind spots.
The All-Around MVP: Wyze Cam v4
Let's start with the undisputed champion of value. Coming in at just $35.98, this mighty little powerhouse is essentially a steal. It delivers crisp 2.5K QHD resolution, meaning you can finally zoom in and see actual facial features instead of pixelated, blurry blobs. Plus, it rocks our Enhanced Color Night Vision. Instead of suffering through spooky, black-and-white ghost footage, your midnight motion alerts are vivid and packed with detail. Weather-resistant and built like a tank, it's ready to handle everything from your living room shelf to the harshest blizzards on your patio.
The Robotic Guard: Wyze Cam Pan v3
Got a massive open space like a sprawling backyard or a three-car garage? You need a camera that doesn't just stare blankly at a wall. Enter the Wyze Cam Pan v3. For just $39.98, you get a literal robotic guard that physically spins 360 degrees horizontally and tilts 180 degrees vertically. It tracks motion like a bloodhound on a fresh scent, so if a delivery driver (or the neighborhood raccoon plotting a heist) walks across your driveway, the camera physically follows them. It sees everything, leaves zero blind spots, and isn't afraid of a little rain.
The Reliable Workhorse: Wyze Cam OG
If you want to completely blanket your property in security without having to take out a second mortgage, the Wyze Cam OG is your new best friend. Grab it on deal for just $19.98 (regularly $29.98). This absolute workhorse gives you crisp video, a built-in 40-lumen spotlight, and a 90-decibel user-activated siren. It’s perfect for covering side gates, tight corners, or that one mysterious spot in the yard where your golden retriever keeps digging holes.
Premium Security for the Rest of Us
At Wyze, we have a minor obsession with making premium smart home tech accessible to normal folks. We firmly believe that incredible features shouldn't be locked behind a ridiculous paywall. You deserve the same top-tier security as the folks living in gated mansions, and you absolutely shouldn't have to pay an annoying monthly fee just to access your own video recordings. That’s exactly why all these cameras support local microSD card storage. You stay in total control.
Don't just take our word for it. The Wyze community proves the value of these cameras every single day, sharing everything from hilarious clips of pets actively destroying the mid-century modern sofa to serious footage of porch pirates getting caught red-handed.
Frequently Asked Questions (FAQ)
Q: Are these prices real? Why are they so affordable?
A: Yes, they are very real! At Wyze, we make premium smart home technology accessible to everyone. We cut out the massive markups and bloated marketing budgets of the "other guys" so we can pass the savings directly to you. Your wallet will thank you.
Q: Do I absolutely need a subscription to use these cameras?
A: Nope. We firmly believe you shouldn't be forced into a monthly fee just to use your own hardware. You can pop in a microSD card (sold separately) for continuous local recording. If you do want to give your camera a brain, you can add Cam Plus for top-tier AI alerts, but the choice is entirely yours.
Q: I have a massive yard. Which camera gives me the best bang for my buck?
A: Definitely the Wyze Cam Pan v3 at $39.98. Since it physically pans 360° and tilts 180°, one camera can cover an incredibly wide area. It's essentially the cost of a single camera but gives you the coverage of three.
cameras
By Garrett Bogar
Best Video Doorbell for Renters - Wyze Labs, Inc.
guides
By Silas Phillips
Living in a rental property usually means living by someone else's rules, which is why the best video doorbells for renters are the Wyze Battery Video Doorbell or the Wyze Duo Cam...
Newsletter background
Be in the know
