Some offers and content vary by region. You're currently browsing the United Kingdom site.
Wyze vs. Blink: Which Delivers the Best Value for Home Security?
Hello friends! If you’re building a smart home security system, you’re stuck weighing two things: price and performance. That’s why you’ve narrowed it down to the top value contenders: Wyze and Blink.
In this guide, we’re putting the Wyze Cam v4, Wyze Cam Floodlight v2, and Wyze Battery Video Doorbell head-to-head against their Blink counterparts.
Let’s see who actually delivers the best tech, dollar-for-dollar.
Wyze Cam v4 vs Blink Mini 2K+
Small cameras like the Wyze Cam v4 and Blink Mini 2K+ are designed to be "eyes everywhere" tools you can tuck away on a bookshelf to check on pets or mounted under an eave for a low-profile look at the side gate. These cameras function similarly, but we’ll compare their hardware differences.
Wyze Cam v4 vs Blink Mini 2K+ Feature Comparison
Feature
Wyze Cam v4
Blink Mini 2K+
Top Performer
Price
$35.98
$49.99
Wyze: Lower entry cost, almost 30%
Resolution
2.5K [2560 x 1440]
2.5K [2560 x 1440]
Equal resolution
Night Vision
Color Night Vision with Starlight Sensor
Color Night Vision
Wyze: Superior low-light performance from its starlight sensor
Local Storage
MicroSD (up to 256GB, starts at $13)
Requires Sync Module 2 (+$50)
Wyze: No separate hardware device required
Field of View (FOV)
115.8° Diagonal
138° Diagonal
Blink: Wider field of view
Weatherproof
IP65
IP65
Equal device IP rating. Both units require a weather adapter kit for outdoor mounting.
Built-in Siren
Yes (99dB)
Yes (105dB)
Blink: Slightly louder siren
Ready to get started? Learn more about the Wyze Cam v4 today.
Design
Let’s be real: they’re both cubes. The main difference lies in the finish and the weight: Blink is constructed from a smooth, light plastic, while the v4 has a matte surface and a bit more heft. Both are designed to be unobtrusive, but the v4's extra weight helps it stay balanced on its magnetic base.
Storage and Subscriptions
The Cam v4 includes a standard, user-accessible MicroSD card slot for 24/7 continuous recording, no cloud required. In contrast, Blink local storage is tethered to their proprietary Sync Module 2 hub, which is often an extra cost if not bundled.
While both offer cloud plans, the 'best' value depends entirely on what you prioritize: smart features or storage history. Wyze Cam Plus ($2.99/mo per cam) provides unlimited clip length and advanced AI alerts for people, pets, and packages. Blink’s Basic Plan ($3.99/mo per cam) costs slightly more monthly, but keeps your clips stored on the cloud for longer; up to 60-day cloud clip storage while Wyze only stores your clips for 14 days.
Wyze has 60 days storage on higher tier plans, so we can see the data that shows it is incredibly unlikely a user will check footage beyond 14 days, it's as close to zero as you can get. We think this is an excuse to charge an extra dollar and do not think the extra storage days provide any real value to customers.
Smart Home Integration
Wyze Cam v4 supports both Amazon Alexa and Google Assistant, allowing for voice control across most smart displays. Blink Mini 2K+ is built for the Alexa ecosystem but lacks Google Assistant support. Both cameras integrate with IFTTT for custom automations, but Wyze provides more utility for households using Google's smart home platform.
Wyze Battery Video Doorbell vs Blink Video Doorbell
Video doorbells are your digital bouncers. Both of these options offer that 1:1 head-to-toe view, so the choice isn't about what they see, but how they handle the footage. It’s a toss-up between Blink’s ecosystem and Wyze’s stand-alone flexibility. Here’s how the specs actually compare.
Wyze Battery Video Doorbell vs Blink Video Doorbell Feature Comparison
Feature
Top Performer
Price
$65.98
$59.99
Blink: Slightly lower unit price
Resolution
2K [1536 x 1536]
2K [1440 x 1440]
Wyze: Slightly higher resolution
Night Vision
Black & White Night Vision
Wyze: Color night vision and increased brightness from its starlight sensor.
Local Storage
Field of View (FOV)
150° head-to-toe
150° head-to-toe
Equal field of view
Power Options
Included rechargeable battery or hardwired
Requires non-rechargeable AA batteries or hardwired
Wyze: Wins on battery; its rechargeable cell beats blink’s recurring AA cost. Equal performance if hardwired.
Secure your front porch with the Wyze Battery Video Doorbell.
Design
These doorbells share a similar footprint and the hardware choices differ slightly. Both units come with straight and angled mounting brackets and feature a shiny low-profile design. The Blink Video Doorbell runs on two AA lithium batteries, which are easy to swap but represent a recurring cost. While both offer a sleek, wire-free look, the Wyze unit is rechargeable via USB-C and manages to pack in a microSD slot for those who prefer physical storage over the "extra hub" requirement found on the Blink.
The "hidden cost" of a budget camera is usually the storage. Wyze provides a microSD slot right in the doorbell device itself, allowing for easy local storage. Blink's local storage is tethered to their proprietary Sync Module 2 hub, which is an extra piece of hardware you would need to purchase. Both companies use cloud-based AI to identify visitors and vehicles but Wyze gives you the choice to keep your data on your own hardware without buying into a proprietary bridge.
The front door is the heart of home automation. The Wyze Battery Video Doorbell integrates with both Alexa and Google Assistant, so you can see your visitor on a Nest Hub or an Echo Show. Blink, being an Amazon product, works great with Alexa but lacks the broad support for Google Assistant users. Both cameras integrate with IFTTT for custom automations like the last comparison, so if you want the flexibility to change your smart home ecosystem later then Wyze is the safer bet.
Wyze Cam Floodlight v2 vs Blink Floodlight Camera
For total perimeter protection, you need a heavy hitter. Floodlight cameras provide active deterrence for large areas like driveways, backyards, and side alleys. They combine powerful lighting with high-def video to ensure that when the sun goes down, your security doesn't. Here is how the Wyze and Blink floodlight cameras stack up on paper.
Wyze Cam Floodlight v2 vs Blink Floodlight Camera Feature Comparison
Feature
Blink Wired Floodlight
Top Performer
Price
$83.99
$99.99
Comparable pricing
Resolution
2K (2304 x 1296)
HD (1920 x 1080)
Wyze: Better resolution
Night Vision
Color Night Vision
Wyze: Better low-light sensor
Local Storage
Field of View (FOV)
160° Diagonal
143° diagonal
Wyze: Wider field of view
Brightness
2800 Lumens
2600 Lumens
Wyze: Slightly brighter
Built-in Siren
Yes (105dB)
Yes (105dB)
Equal siren volume
Light up the night with Wyze Cam Floodlight v2
Design
The Blink Wired Floodlight is a streamlined, all-in-one unit that won't clutter your roofline, though its fixed camera is limited to a 143-degree field of view. Wyze’s v2 trades that "slim" look for a more versatile setup, featuring a wider 160-degree lens and independent light heads you can aim exactly where you need them. Wyze also integrates its famous Starlight Sensor, meaning you get color night vision even when the floodlights are off. It’s a choice between Blink’s clean aesthetic and Wyze’s "see everything" philosophy that enables its floodlight to see with only a small amount of ambient light.
Wyze remains a strong choice for local recording. The Floodlight v2 includes a built-in MicroSD slot for onboard storage, while Blink requires the separate purchase of a Sync Module 2 to store clips locally.
When it comes to the cloud, both brands offer similar subscription structures. For single-camera setups, Wyze Cam Plus and Blink Basic provide per-device monthly plans. For households with several cameras, both Wyze Cam Unlimited and Blink Plus offer a flat monthly rate to cover every device on the account, ensuring neither side breaks the bank as your system grows.
Building a comprehensive ultimate smart house setup means your lights should talk to your cameras. Wyze Cam Floodlight v2 uses IFTTT to trigger other devices, like indoor Wyze Bulbs, upon motion detection. It supports both Amazon Alexa and Google Assistant. The Blink Wired Floodlight Camera integrates with Alexa and IFTTT but lacks native Google Assistant support, making Wyze the more versatile choice for multi-platform homes.
Bonus Section: AI and Subscription Plans
Most modern security cameras use AI to distinguish between general motion. Both Wyze and Blink offer subscription tiers that unlock advanced detection features, though the specific capabilities vary between the two ecosystems.
Blink’s AI focuses primarily on identifying people and vehicles. These features are standard across their paid tiers but are not available if you choose to use the cameras without a subscription. Wyze offers a similar baseline of person, vehicle, and package detection across its plans, while its higher-tier plans introduce specialized vision AI, such as facial recognition and descriptive alerts that summarize what the camera sees in plain language.
The following table breaks down the costs and features for each plan.
AI Feature Comparison: Wyze vs. Blink
It's not that close. Wyze is less expensive and outperforms Blink’s service in every AI category.
Feature
Wyze Cam Plus
Wyze Cam Unlimited
Wyze Cam Unlimited Pro
Blink Basic
Blink Plus
Monthly Cost
$2.99/cam
$9.99 (unlimited)
$19.99 (unlimited
$3.99/cam
$11.99 (unlimited)
Person & Vehicle Detection
Included
Included
Included
Included
Included
Pet & Package Detection
Included
Included
Included
No
No
Friendly Faces (Facial Recognition)
No
Included
Included
No
No
AI Descriptive Alerts
No
No
Included
No
No
AI Video Search
No
No
Included
No
No
Cloud Video History
14 Days
14 Days
30-60 Days
60 Days
60 Days
Choosing the right plan typically depends on how many cameras you have and how much detail you want from your notifications. For a single camera, the basic per-device plans are often sufficient. However, for households with multiple cameras, the unlimited plans provide a flat rate that covers the entire property.
Our Conclusion
Unless you're married to Alexa, Wyze makes a strong case for itself with better night vision, fewer hidden hardware purchases, and lower subscription costs. Blink offers a straightforward experience for those already tied to the Amazon ecosystem, but Wyze provides a more versatile setup without the need for extra hubs.
While specs like resolution and field of view are mostly comparable, the real difference is in the dark. Thanks to the Starlight Sensor found in all three Wyze products we compared, you get vivid Color Night Vision in lighting conditions where Blink often reverts to black-and-white.
Category
Wyze Advantage
Blink Comparison
Price (All-In)
Comparable for most cams; savings come from not needing to buy a storage hub or hard drives
Similar entry prices: requires a $50 hub for local storage
Resolution
Comparable for most cams, slight edge for the floodlight model
Matches Wyze on most models; falls behind on the floodlight
Local Storage
Device MicroSD Slot (up to 256GB, starts at $13)
Requires Sync Module 2 Hub (+$50)
Subscription Value
Cam Unlimited and Cam Unlimited Pro cover all cams for one fee
Per-device or limited multi-device plans
Integration
Alexa, Google & IFTTT compatibility
Alexa & IFTTT compatibility
*No extra hubs or required monthly fees
Ready to see how Wyze stacks up in other professional reviews? You can check out more deep dives like this one from Tom's Guide or see why Blink users on the Amazon Forums are looking for a change.
When you're ready to start securing your home the smart way, explore Wyze’s full range of smart home security systems and see how simple it is to get premium protection at a price that actually makes sense.
cameras
By Garrett Bogar
cameras
Wyze or Blink - Which to Buy?
By Silas Phillips
Newsletter background
Be in the know
FREE shipping on orders £59+
£0.00
