Some offers and content vary by region. You're currently browsing the United Kingdom site.
Security Camera with the Best Night Vision can see in Low Light
Most security footage is functionally useless. It only serves to tell you that something happened, while leaving you to guess at the actual details. If your current camera makes your driveway look like a scene from a 1940s film noir, you’re not alone. The industry has been selling "night vision" as a premium feature for years, but most of it is just the bare minimum.
Don't feel like reading the whole article? Here's the short answer: Any camera with a starlight sensor will provide the best color night vision capabilities in low light.
The Old Way: Infrared
For years, "night vision" just meant infrared (IR) light. The camera blasts out invisible light, the sensor picks it up, and you get a high-contrast, black-and-white image. This tech hasn't fundamentally changed in decades. It’s better than total darkness, sure, but it’s terrible for details. You might see a person in a hoodie, but you won't know if that hoodie is neon green or navy blue. It’s effective, but it’s the bare minimum.
The New Way: Starlight Sensors
Most brands try to fake "color night vision" by just slapping a cheap LED spotlight on the front of the camera which washes out faces and makes everything look like a crime scene photo. A real solution requires better hardware.
Instead of relying on fake light, a Starlight Sensor works more like a cat’s eye. It’s designed to be physically more sensitive to the tiny amounts of light that are already there. Usually, a streetlight three houses down or a sliver of moonlight is enough to keep the image clear.
Instead of switching to black and white, cameras with this tech, like the Wyze Cam v4, can pull enough light out of the shadows to show you the world in full color.
We have integrated this tech across almost our entire lineup. Whether you are using the Wyze Bulb Cam, the Wyze Duo Cam Pan, or our top-tier wire-free options like the Wyze Battery Cam Pro or Wyze Solar Cam Pan, you are getting a sensor that finds light where other cameras find nothing but shadows.
Why Color Matters at 2 AM
When you're reviewing footage of an "uninvited guest" on your property, color is a massive data point. Knowing the color of a getaway car or a trespasser's jacket can be the difference between a helpful police report and a shrug from the authorities.
The Wyze Battery Cam Pro takes this a step further. Not only does it have a 2.5K sensor that excels in low light, but it also features a built-in spotlight. If the Starlight Sensor needs a nudge, the spotlight kicks in to ensure you get full-color details without needing a professional film crew's lighting rig. Plus, if you add the Wyze Solar Panel, that night-time vigilance doesn't come at the cost of your battery life.
What to Look for in a Low-Light Camera
Don't get distracted by megapixels. If the sensor is cheap, extra pixels just give you a higher-resolution blur. If you actually want to see at night, pay attention to these two things:
  • Aperture: This is the physical size of the lens opening. A wider opening (look for a lower f-stop number) lets in more light. It’s like opening the curtains wider on a cloudy day.
  • Sensor Quality: High-end sensors can "see" in light levels that look like a pitch-black void to the human eye. If a camera brand doesn't mention their sensor specs, it’s probably because they’re using older, cheaper hardware and hoping you don’t notice.
Tweaks for Better Night Vision
A high-end sensor is a great start, but even the best hardware can be crippled by poor installation. If you want pro-level clarity without hiring a contractor, focus on these two factors:
  • Watch Your Foreground Exposure: Night vision sensors struggle when there is a bright object (like a white wall or an eave) in the immediate foreground. The camera will "expose" for that bright wall, leaving your actual yard in total darkness. Angle the camera so it’s looking at your subject, not at the side of your own house.
  • Toggle the IR Cut Filter: In "Auto" mode, some cameras switch to black and white too early. If you have even a little bit of ambient light, try forcing the camera to stay in "Color" mode. You might be surprised at how much a Starlight Sensor can pull out of the shadows when you stop it from falling back on the black-and-white crutch.
Premium Features Without the Premium Price
You don't need to spend hundreds of dollars to get clear night footage. We put 2.5K QHD resolution and an enhanced Starlight Sensor into the Wyze Cam v4 and The Wyze Battery Cam Pro. It pierces through the dark to give you a crisp, colorful view of your porch, backyard, or living room.
It also comes with a motion-activated spotlight. So, if the sensor needs a little extra help, it can shine a light on the situation. It’s helpful for the camera and generally quite startling for anyone creeping around where they shouldn't be.
Night Vision vs. Low Light: A Quick Reality Check
No camera can see in literal zero light without help. If you put a camera in a sealed, windowless basement with no lights on, it’s going to see nothing. In those rare cases, the camera has to create its own light using IR (the black and white mode) to see. But for 99% of outdoor and indoor use cases, a good low-light sensor will keep your security footage colorful long after the sun goes down.
Seeing clearly at night is the whole point of a security camera, not a feature you should have to pay extra for.
Frequently Asked Questions
Q: Will a higher megapixel count (like 4K) automatically give me better night vision?
A: Actually, no. If a high-resolution sensor is physically small or poor quality, it can’t capture enough light, resulting in a "high-resolution blur." When shopping for night performance, you should prioritize a wider aperture (a lower f-stop number) and specialized low-light sensor technology over the raw pixel count.
Q: Will the Starlight Sensor work if I live in a rural area with no streetlights?
A: If it is a moonless night in the middle of the woods, the sensor will eventually hit a limit. In these "true dark" scenarios, the camera will automatically supplement the sensor with its built-in spotlight or fall back to IR mode. The tech is designed to be a "best-of-both-worlds" system that adjusts based on exactly how much light is available.
Q: Does "Color Night Vision" make the video file size much larger? While color files contain more data than high-contrast black-and-white files, Wyze cameras use efficient compression (like H.265) to keep storage manageable. You shouldn't see a significant impact on your cloud storage limits or microSD card capacity compared to standard daytime recording.
cameras
By Garrett Bogar
cameras
Wyze or Blink - Which to Buy?
By Silas Phillips
Newsletter background
Be in the know
FREE shipping on orders £59+
£0.00
