Some offers and content vary by region. You're currently browsing the United Kingdom site.
Video Doorbells Explained: Ultimate Video Doorbell Buying Guide
A video doorbell is essentially a front-door sentry that lets you see and talk to visitors from your phone, whether you are in bed or at the grocery store. It combines a doorbell and a security camera into one package so you never have to guess who is knocking. Deciding on one is a bit like getting a dog. You want one who watches over the house at night, tells you exactly when someone is at the door, and doesn’t poop in the house. Since a dog can do that with the right training, a video doorbell can do all that and comes pre-trained from the factory. I can’t promise you will get as much fulfillment of companionship, though.
If you are new to the world of smart home tech, it can feel like a maze of technical terms and confusing numbers. This guide clears the air so you can pick a doorbell that actually works for your home without spending your month’s rent.
Wired vs. Battery Power
The first question is how your doorbell gets its juice. This is the "power struggle" of the smart home world.
Wired Doorbells
These connect to your existing doorbell wires. They are great because you never have to charge a battery. It is a set-it-and-forget-it situation. However, if your house was built before doorbells were a thing, or if your current wires are acting like they belong in a museum, this might require a bit of DIY effort or a friend who knows their way around a circuit breaker.
Battery-Powered Doorbells
These are the kings of convenience. You can stick them almost anywhere with a few screws, or even 3M tape. They are perfect for renters or people who would rather not touch electrical wires. The trade-off is that you will eventually need to charge them. Think of it like your phone, but it lives outside and only needs a charge 2-3 times a year. Many battery models also offer an optional wired connection if you want the best of both worlds.
Resolution: How Clear Is the Picture?
In the world of cameras, resolution is just a fancy way of saying how many pixels are crammed into the image.
  • 1080p: This is the standard. It is clear enough to see that a person is at your door.
  • 2K or Higher: This is like putting on glasses for the first time. It allows you to zoom in on details, like the text on a delivery driver’s vest or the exact type of squirrel currently digging in your garden beds.
High resolution is great, but remember that clearer video uses more internet bandwidth. If your Wi-Fi is still running on hopes and dreams, 1080p might be the smoother experience.
Field of View: Seeing the Whole Story
Field of view determines how much of your porch the camera actually sees. Most older doorbells use a wide landscape view, which is fine if you want to see your neighbor’s yard.
For a front door, you really want a "head-to-toe" view. This usually means a 1:1 aspect ratio. This allows you to see the person’s face and the package they left on the ground. A doorbell that cannot see the ground is like a security guard who only looks at the ceiling. It misses the most important part.
Storage: Where Do the Videos Go?
When your doorbell catches someone doing something they shouldn't (or something funny), you need that video saved somewhere.
  • Cloud Storage: The video is sent to a secure server. You can access it from anywhere, but it usually comes with a small monthly fee.
  • Local Storage: Some doorbells still let you keep your footage locally on the device by sliding in a microSD card for continuous recording. The battery-powered models can also do this, provided they are connected to a wired power source to handle the extra work.
Smart Features and Alerts
A "dumb" camera tells you every time a leaf blows past. A smart doorbell uses artificial intelligence to tell the difference between a person, a pet, or a package.
These smart alerts save you from checking your phone twenty times a day just to see the wind blowing. You can set your doorbell to only bother you when a human is actually standing there. It is a great way to ignore the world until it actually matters.
The Wyze Lineup: Finding Your Match
Now that you know the basics, let's look at the specific tools for the job. Wyze offers a few different ways to guard your porch, depending on your house and your patience for wires.
At-A-Glance Comparison
Feature
Wyze Video Doorbell v2
Wyze Battery Video Doorbell
Wyze Duo Cam Doorbell
Power Source
Wired Only
Battery + Optional Wired
Resolution
2K
2K
2K (Top) + 1080p (Bottom)
Field of View
1:1 Head-to-Toe
1:1 Head-to-Toe
Dual-View (Face + Package)
Local Storage
Yes (microSD card)
Yes (microSD card)*
Yes (microSD card)*
24/7 Recording
Yes
Only when wired
Only when wired
Best For
Homeowners / Constant monitoring
Renters / Quick setup
Package security / Maximum coverage
*24/7 Local recording on battery models requires a wired power connection.
This is the choice for the "never-charge-a-battery" crowd. It is a wired-only doorbell that offers 2K resolution and a head-to-toe view. Its biggest trick is 24/7 local recording. If you put a microSD card in it, this camera will record all day, every day.
If you live in an apartment, don’t have wiring run near your door, or simply do not want to drill holes into your siding, this is your winner. It is primarily wireless but offers an optional wired connection if you decide to upgrade to constant power later. It offers a crisp 2K head-to-toe view and is built for a quick setup. In battery-only mode, you can’t use 24/7 recording, but it will record all events using Wyze’s AI detection features.
For those who are truly serious about their deliveries, the Duo Cam is the heavy hitter. It features two separate cameras: one for people’s faces and one pointed directly down at your packages. Like the other battery models, it works wirelessly or can be hardwired for nonstop power and continuous recording.
Conclusion: Wyze Delivers Value Over Everything
You do not need to spend hundreds of dollars to get premium features. The smart home industry loves to charge extra for "pro" labels, but the reality is that high-quality hardware is more affordable than ever. Whether you go with the wired Wyze Video Doorbell v2 or the dual-camera setup of the Wyze Duo Cam Doorbell or the Wyze Battery Video Doorbell, you are getting high-end specs without the high-end price tag.
At the end of the day, you want a device that makes your life easier, not more expensive. A good video doorbell is an investment in your peace of mind, and it is even better when it leaves you with enough money to actually buy the stuff being delivered to your porch.
Frequently Asked Questions:
Can I share access with my family or roommates? Yes, you can share the device with others through the Wyze app. It is a much better solution than handing out physical keys to people who are prone to losing them. Just be aware that once they have access, they can see every delivery you receive. If you are trying to hide a late-night taco habit from your roommates, this might not be the feature for you.
What happens if someone decides to steal the doorbell itself? It is a valid concern, though it rarely happens because the thief’s face is being recorded and sent to the cloud the moment they approach. Most Wyze doorbells come with secure mounting hardware that makes them difficult to remove without the proper tools. If you are using a cloud service, you will have a very clear video of the person who committed the crime to show the authorities.
Do I have to buy a special chime for inside my house? Not necessarily. Most Wyze doorbells come with a digital chime that you just plug into any wall outlet. If you choose a wired model like the Doorbell v2, it can even work with your existing mechanical chime if you enjoy that classic "ding-dong" sound. It's a nice way to keep a bit of tradition in your increasingly digital life.
cameras
By Garrett Bogar
cameras
Wyze or Blink - Which to Buy?
By Silas Phillips
Newsletter background
Be in the know
FREE shipping on orders £59+
£0.00
