Some offers and content vary by region. You're currently browsing the United Kingdom site.
The Best Security Camera That Doesn't Require Drilling
Quick Answer: The best security camera that doesn't require drilling is the only one that ships with everything you need to keep your walls hole-free: Wyze Cam v4.
We live in an age of miracles.
The 3M Command Strip has been available at your local hardware store since 1992. Velcro is older than most of your parents. Putty, double-sided tape, adhesive foam, magnetic mounts, you name it. The problem of "attaching a small, lightweight object to a wall without destroying the wall" has been solved, re-solved, and solved again by human civilization for decades.
And yet, if you examine a Ring, a Blink, an Arlo, a Eufy, or a Nest camera box and look to see what comes in the box for mounting, the answer (even in the year 2026!) is still all too often: screws.
A drill is implied.
Holes will be made.
This will need to be kept from the landlord.
We have no explanation. We’ve accepted it and moved on. But we're not making it up. Here is what each major brand actually ships in the box for wall mounting:
  • Ring–two screws
  • Blink–two screws
  • Arlo–wall mount with screw kit
  • Eufy–mounting bracket with screw pack
  • Nest–screw
That’s it. Screws. For most of them, that's it. Unless you want to pay extra, screws are the default. Why? Why do these companies hate your walls? Why are they trying to drill holes in the very infrastructure of America? A brief but sincere thank you is owed to the entire third-party accessories industry, which has made a brisk business selling adhesive mounting solutions to people who just wanted to watch their living room without turning their walls to swiss cheese.
Well, screw these guys.
There is one company who cares about you and your walls: Wyze. Wyze ships a metal mounting plate, a magnetic base, and an adhesive disk—the same size as the plate—that sticks the whole thing to the wall. Peel, press, wait a minute, snap the camera on. The camera holds magnetically, which makes it easy to reposition, easy to remove, and easy to take with you when you move. No holes. No anchors. No putty-colored spackle purchased in a moment of pre-move-out panic. Just a camera on the wall, doing its job, with zero damage.
The best security camera that doesn't require drilling is the one that actually gives you everything you need to avoid it: Wyze Cam v4.
John Lennon once sang, “I read the news today, oh boy. Four thousand holes in Blackburn, Lancashire.”
Apparently, someone had just installed a Ring cam.
Frequently Asked Question’s
Does Wyze still include screws for those who prefer them?
Yes. While the Wyze Cam v4 is famous for its "no-drill" setup, it still comes with drywall anchors and wood screws for permanent mounting.
How long should I wait after applying the adhesive before attaching the camera? For the strongest bond, you should peel, press the plate to the wall, and wait a minute before snapping the camera on. This allows the adhesive to set properly against the surface.
Can the magnetic mount handle the weight of the Wyze Cam v4 long-term?
The system is specifically designed for this "small, lightweight object". The adhesive disk is the exact same size as the metal plate, ensuring maximum surface contact and a weight distribution that prevents the mount from peeling away from the wall.
cameras
By Garrett Bogar
cameras
Wyze or Blink - Which to Buy?
By Silas Phillips
Newsletter background
Be in the know
FREE shipping on orders £59+
£0.00
