Skip to content
Wyze vs. Reolink: Which Security Camera Should You Choose?
Wyze vs. Reolink: The Reality of Your Smart Home Setup
Today we’re comparing two of the most popular brands in the smart home space: Wyze and Reolink. Both companies have become go-to choices for homeowners and renters looking to secure their property for a reasonable price. Ultimately, Reolink provides the granular control needed for complex setups, while Wyze offers a unified app experience that manages your entire home in one place.
The Hardware Breakdown
It’s easy to get lost in the numbers when every brand is promising 2K this and Ultra-HD that. Hardware is only as good as the software that runs it, but you still need a solid foundation to start with. Wyze tends to pack a lot of tech into smaller, more flexible designs, while Reolink hardware is built for those who prefer a more permanent, wired-in feel. We’re comparing their entry-level cams, battery-powered options, solar-powered cams and doorbells to see which brand offers the most value for your specific patch of grass.
Essential Starter Cams: Wyze Cam v4 vs. Reolink Lumus
If you just need the basics, these two models represent the standard entry point for each company. Both options feature integrated spotlights and 2K-tier resolutions, but the low-light performance and the price point create a clear divide. Here is the side-by-side comparison.
Feature
Wyze Cam v4
Reolink Lumus (Upgraded 2K)
Price (MSRP)
$35.98
$59.99
Resolution
2K (2,560 x 1,440)
2K (2,560 x 1,440)
Night Vision
Color (Starlight Sensor) & B&W (Infrared)
Color (Spotlight Required)
Integrated Lighting
Built-in Spotlight (72 lm)
Built-in Spotlight (180 lm)
Operating Temperature
-4°F to 122°F
14°F to 131°F
Weather Resistance
IP65 Rated
IP65 Rated
Field of View
116° (Diagonal)
129° (Diagonal)
Local Storage
MicroSD (Up to 512GB)
Outdoor Battery Cams: Wyze Battery Cam Pro vs. Reolink Argus 3 Pro
Battery-powered cameras are the go-to for a fence or roof overhang where a traditional wired setup is a hard pass. Both companies offer high-res 2K sensors, but Wyze utilizes Radar+PIR to filter out the noise that Reolink’s PIR-only sensor might miss. Plus, Wyze has a removable battery pack compared to Reolink’s fixed internal one.
Feature
Reolink Argus 3 Pro
Price (MSRP)
$89.99
$119.99
Resolution
2K (2,560 x 1,440)
2K (2,880 x 1,616)
Night Vision
Integrated Lighting
Built-in Spotlight (150 lm)
Built-in Spotlight (230 lm)
Motion Detection
Radar + PIR
PIR Only
Power Source
Removable / Swappable Battery (6,200 mAh)
Removable / Swappable Battery (6,000 mAh)
-4°F to 122°F
14°F to 131°F
Weather Resistance
IP65 Rated
IP65 Rated
Field of View
134° (Diagonal)
122° (Diagonal)
Local Storage
MicroSD (Up to 256GB)
Solar-Powered Pan & Tilt Cams: Wyze Solar Cam Pan vs. Reolink Argus PT 2K
If you need to monitor a massive backyard or a long driveway where power outlets are non-existent, solar-powered pan-and-tilt cameras are the standard solution. Wyze includes auto-tracking to follow anyone entering the property, unlike Reolink which focuses on a deeper vertical tilt and manual control. Here is a breakdown of the specs.
Feature
Wyze Solar Cam Pan
Reolink Argus PT 2K
Price (MSRP)
$79.98
$119.99
Resolution
2K (2,560 x 1,440)
2K (2,880 x 1,616)
Night Vision
Pan & Tilt Range
360° Horizontal / 70° Vertical
355° Horizontal / 140° Vertical
Motion Tracking
Automatic Tracking Included
Manual Control Only
Power Source
Integrated Battery (6,400 mAh) + Solar Panel (1.8 W)
Integrated Battery (6,000 mAh) + Solar Panel (3 W)
-4°F to 122°F
14°F to 131°F
Weather Resistance
IP65 Rated
IP65 Rated
Field of View
130° (Diagonal)
110° (Diagonal)
Local Storage
MicroSD (Up to 128GB)
Battery Doorbell Cameras: Wyze Battery Video Doorbell Pro vs. Reolink Video Doorbell
The front door is usually the busiest part of the house, so the most important feature is how much of that space the camera actually captures. Both doorbells provide clear resolution and a square 1:1 aspect ratio to ensure you see everything from head to toe. Wyze relies on a starlight sensor for color night vision, while Reolink utilizes HDR to balance out the bright lighting often found at a front door. Here is how they stack up side-by-side.
Feature
Reolink Video Doorbell (Battery)
Price (MSRP)
$65.98
$119.99
Resolution
HD+ (1,536 x 1,536)
2K+ (2,048 x 2,048)
Night Vision
Color (HDR)
Power Source
Integrated Battery (6,400 mAh) or Hardwired
Integrated Battery (7,000 mAh)
-4°F to 122°F
14°F to 131°F
Weather Resistance
IP65 Rated
IP65 Rated
Field of View
150° (Diagonal) (1:1 Head-to-toe view)
Local Storage
Installation & Local Storage
If you have ever tried to mount a camera on a brick wall or stucco you know that every millimeter of cable bulk matters. While Reolink professional PoE cameras use a pigtail cable design, their consumer Wi-Fi models like the Lumus and Argus use slim USB power cables. However those are still standard round cables that can be difficult to hide. Wyze stays lean with flat wiring that can actually tuck into trim or siding seams to keep your curb appeal intact.
Cable shapes aside, local storage is where the real differences are. While both brands support local storage they handle the data differently. Reolink treats the microSD card as a secondary option to their professional NVR systems while Wyze treats the card as the primary storage method. An NVR (Network Video Recorder)  is a dedicated recording box that lives inside your home and usually requires you to buy a separate surveillance grade hard drive which can cost between 60 and 150 dollars depending on the size. A standard 8 channel Reolink NVR starts at around 220 dollars meaning a full professional setup often reaches a 400 dollar entry point before you even buy the cameras. This system provides a massive amount of storage for 24/7 recording but it changes how the app functions.
Reolink’s "UID" (Unique ID) technology is optimized for P2P (Peer-to-Peer) streaming to NVRs. When accessing large files on an SD card without an NVR, Reolink users frequently report "Buffering" or "Loading" delays because the app has to index the card remotely. Wyze’s "Playback" UI is specifically indexed for local card scrolling, allowing users to scrub through footage in the app  with less buffering. Wyze also simplifies the setup by using Bluetooth for an instant connection while Reolink products often rely on a QR code scan that can be a disadvantage if the camera is already mounted on a ladder.
Software and Ecosystem Integration
The software experience is where the gap between these two brands becomes clear. Reolink often leans on a desktop client for advanced settings, a workflow that feels a bit dated in a mobile-first world. Reolink does provide an added layer of security by allowing unique access passwords for each camera, though all devices are still managed under a single primary account login within the app.
Wyze centralizes the entire home into a single app. Using Bluetooth for "instant-on" discovery, the app manages not just cameras, but bulbs, plugs, and sensors in one place. You have one account for the entire home, which shifts the focus from hunting for passwords to actually viewing your footage.
If you want your house to actually react to what your camera sees, the two brands offer very different levels of support. While Wyze has deep-rooted IFTTT support for all models, Reolink has only recently begun rolling out IFTTT integration (App v4.59+). Currently, Wyze remains the more established choice for those relying on complex smart home triggers.
AI and Detection: Cloud vs. Edge
Reolink primarily uses "Edge AI," which means the camera's internal chip does the heavy lifting to identify people or vehicles. While this allows for basic smart alerts without a subscription, the intelligence is limited by whatever chip happens to be inside that specific piece of hardware.
Wyze uses a cloud-based AI model. When a camera detects motion, the footage is analyzed by high-performance servers. Because the "brain" is in the cloud, Wyze cameras can be updated to get smarter over time without you needing to buy new hardware. This infrastructure enables advanced features like Descriptive Alerts and AI Video Search.
With Descriptive alters, instead of a short notification like "Motion Detected" or "Pet detected on Backyard Cam," you'll get more detail, like "Small white dog playing with a tennis ball in the backyard at 4:04 PM." AI video search lets you type "brown dog in the driveway" to find specific clips in seconds—a task that a camera trying to do all the math locally simply can't handle.
The Resolution Sweet Spot
It's tempting to look at a 4K spec sheet and assume it's the superior choice, but higher resolution comes with a cost that isn't listed on the price tag. 4K video files are massive. They require more bandwidth to stream and more storage space to save. If your home Wi-Fi isn't perfect, viewing a 4K stream on your phone can be a sluggish, buffering experience.
Wyze does offer a 4K option (Wyze Cam Pan V4) for those who prioritize maximum pixel count, but they focus on 2K and 2.5K resolution because it hits the sweet spot for a mobile-first world. It provides enough detail to read a license plate or identify a face without putting a strain on your home network. It’s about efficiency over empty numbers.
The Final Take
The reality is that both companies offer excellent, reliable hardware for the money. Reolink wins on raw power and the ability to grow into a professional wired system that functions entirely off the grid. Wyze wins on ecosystem integration and the ease of managing a whole home through a mobile first interface. Whether you choose the granular control of Reolink or the background simplicity of Wyze depends on whether you view your home security as a weekend project or a set it and forget it utility.
Frequently Asked Question's
Q: Which brand is better for a complete smart home setup?
A: Wyze is generally the better choice for a unified smart home. The Wyze app manages not just cameras, but also smart bulbs, plugs, locks, and sensors in one place. While Reolink offers excellent standalone camera performance, their ecosystem is primarily focused on security video rather than a broad range of smart home automation.
Q: Do I need a subscription to use these cameras?
A: Both brands allow for essential features like live viewing, local storage, and detection notifications without a monthly fee. Wyze offers three distinct security plans to unlock AI features and cloud recording. Reolink offers basic person/vehicle detection notifications on the "edge" (locally on the camera) for free. Reolink provides two cloud storage plans as well, but lacks Wyze's advanced AI features.
Q: Can I record 24/7 with these cameras?
A: Yes, but with specific requirements. For both Wyze and Reolink, 24/7 continuous recording requires you to buy and insert a MicroSD card into the camera. Additionally, the camera must be a wired model (or a battery model connected to a continuous power source); battery-powered cameras typically only record when motion is detected to preserve power.
cameras
By Garrett Bogar
Best Video Doorbell for Renters - Wyze Labs, Inc.
guides
By Silas Phillips
Living in a rental property usually means living by someone else's rules, which is why the best video doorbells for renters are the Wyze Battery Video Doorbell or the Wyze Duo Cam...
Newsletter background
Be in the know
£0.00
