Wyze vs. Kasa: Preis, Leistung und Funktionen im Vergleich
Wyze and Kasa, two of the primary names in the low-cost security camera space. So, which one deserves your cash? It really comes down to what flavors of tech you prefer. Wyze tends to flex a bit more when it comes to AI parlor tricks, like spotting whether a package is being delivered or kidnapped. Meanwhile, Kasa brings the steady backing of its massive parent company, TP-Link—though they've been dodging some corporate and regulatory drama lately that’s given a few tech purists pause about the long game.
To help you figure out which brand actually fits your vibe, we’re putting their most popular gadgets head-to-head. We'll also dive into the messy world of cloud subscription math and  break down why Wyze’s cloud-powered AI behaves so differently from Kasa's on-device chip brain.
We think Wyze is the easy choice, but let’s see how they stack up in the real world, sans the marketing hype.
Indoor Pan & Tilt Cams: Wyze Cam Pan v3 vs. Kasa Spot Pan Tilt
If you have a pet that treats your living room like a Ninja Warrior course, these pan-and-tilt cameras give you a full 360-degree view without forcing you to buy multiple devices.
Feature
Wyze Cam Pan v3
Kasa Spot Pan Tilt (EC70)
Preis
$39.98
$29.99
Beschluss
HD (1920 x 1080)
HD (1920 x 1080)
Schwenken und Neigen
360° Pan/ 180° Tilt
360° Pan / 113° Tilt
Bewegungsverfolgung
Ja
Ja
Field of View (Diagonal)
120°
88.3°
Nachtsicht
Color Night Vision (Starlight Sensor)
IR Night Vision (Black & White)
Weather Rating
IP65
Indoor only. Kasa does not list its weather rating
Stromquelle
Wired (Micro-USB to USB-A cable)
Wired (9VDC Barrel Pin cable)
Lokaler Speicher
microSD (Up to 256GB)
The Wyze Cam Pan v3 pulls ahead on flexibility with full color night vision, a noticeably wider field of view, and a 180° vertical tilt. Plus, it’s weather-sealed with an IP65 rating so you can mount it to an outdoor eave or plop it on a bookshelf.
The Kasa EC70 is a much more traditional, indoor-only tabletop affair. Its tighter 113° tilt means it’s happiest sitting at eye-level on a counter and  it sticks strictly to classic black-and-white infrared at night. Kasa doesn't actually list an IP weather rating for the EC70, which makes sense given its indoor-only job description.
If you just need a straightforward, budget-friendly eye on the living room, Kasa saves you ten bucks. But if you want to mount your camera upside down on the ceiling, throw it outside in the rain, or see in full color after dark, Wyze justifies the extra cash.
Versatile Plug-In Cams: Wyze Cam v4 vs. Kasa 2K+ Outdoor Wired
Both of these wired options are designed to mount just about anywhere you have an outlet. These are the set it and forget it, entry-level outdoor cameras.
Feature
Wyze Cam v4
Kasa 2K+ Outdoor (KC420WS)
Preis
$35.98
$44.99
Beschluss
2K 4MP (2560 x 1440)
115.8°
113°
Nachtsicht
Stromquelle
Wired (USB-A)
Konnektivität
Wi-Fi 6
Wi-Fi 4
Shutter Speed
20 FPS Maximum
15 FPS Maximum
Lokaler Speicher
microSD (Up to 512GB)
Spotlight
72 lumens (Adjustable)
Not listed by Kasa
Wyze wins this matchup easily. You’re saving $9 on cost and getting better features. Even though the specs look virtually the same, the user experience is a little different. Wyze shoots at 20 FPS during the day, and 15 FPS at night. Kasa shoots at a 15 FPS maximum, which means moving objects look slightly less choppy on the Wyze Cam v4 during the day. Wyze also uses the newer Wi-Fi 6 standard, whereas Kasa uses Wi-Fi 4 hardware—a difference that helps the Wyze app pull up your live view a little quicker.
Both cameras have an IP65 weather rating, meaning they can handle heavy downpours or dust storms. Both cameras include built-in spotlights to trigger color night vision, though Kasa doesn't actually publish their lumen brightness. Both cams get the job done but Wyze gives you a faster wireless connection and smoother video for about ten dollars less.
Doorbell Cams: Wyze Video Doorbell v2 vs. Kasa Smart Video Doorbell
Wyze Video-Türklingel v2 uses your home’s existing wiring. The Kasa KD110 also uses your existing wiring and comes with its own digital chime you can plug into any outlet. However, the Wyze v2 allows for twice the amount of local storage.
Feature
Kasa Smart Video Doorbell (KD110)
Preis
$39.99
$49.99
Beschluss
2K 3MP (2048 x 1536)
2K 3MP (2304 x 1296)
166°
160°
Nachtsicht
Stromquelle
Hardwired (16-24V AC)
Lokaler Speicher
microSD (Up to 128GB)
Both of these doorbells can record 24/7 continuous footage to a local microSD card, so you don't necessarily need a subscription to see what happened on your porch. Wyze’s field of view is a little wider, but both doorbells are essentially a tie when it comes to visual real estate on the wall from the cameras’ POV. They both come with nearly identical 2K resolutions and ultra-wide, 160-plus degree fields of view.
Wyze supports up to a 256GB card—double Kasa’s 128GB limit—which buys you more playback history before the oldest footage gets overwritten. Wyze also features color night vision, whereas Kasa relies on traditional black-and-white infrared after dark.
Another Wyze advantage comes with motion alerts. Wyze uses a "pre-roll" feature that continuously caches a few seconds of video, allowing it to tack the moments before an event onto your alert clip. Kasa starts recording the exact second the sensor trips. Kasa does, however, throw a plug-in digital chime into the box so you can hear the ring anywhere in the house, a piece of hardware you have to buy separately with Wyze if you don't want to rely solely on your phone or your home's existing physical chime. But Wyze is $10 cheaper, so that is your decision you are not forced to make.
Storage: Local vs. Cloud
Across their product lines, Wyze and Kasa allow for local recording (continuous recording available for wired cameras) right to the camera via microSD without a subscription.
For cloud storage, Wyze Cam Plus costs $2.99 per month for a single camera and provides 14 days of event history, whereas the Kasa Care Plus plan costs $3.00 per month for one camera but offers a longer 30-day video history. If you have many devices, Wyze Cam Unlimited covers all your cameras for $9.99 per month, while the Kasa Care Premium plan also costs $10.00 per month but is strictly capped at 10 cameras. At the top of the ladder, Wyze offers Cam Unlimited Pro for $19.99 per month, which includes full descriptive alerts and 60-days of video history; Kasa currently does not have a direct equivalent to this tier, as their highest plan remains focused on cloud storage and more basic AI detections.
In-Depth AI Comparison
When you buy a smart camera, you’re buying its brain. Kasa uses "Edge AI," meaning all the heavy lifting happens on a tiny chip inside the camera itself. So the A is limited by its own hardware. Once that chip hits its processing ceiling, it’s not getting any smarter. What you buy on day one is what you’re stuck with until you upgrade the hardware.
Wyze, on the other hand, relies on a cloud-hybrid model. Newer models handle basic speed tasks on-device, but send the complicated thinking to Wyze’s cloud servers. Because internet servers have way more muscle than a tiny camera chip, Wyze can use complex logic to actually tell you a story. Instead of a generic "Motion Detected" alert, Wyze can tell you a "small white dog is playing with a tennis ball." Kasa just isn't built for that kind of detail.
Take package detection. Kasa uses basic shape matching. It looks for a static, box-like shape on your porch. If a porch pirate walks up, grabs the box, and leaves, Kasa might just trigger another "package" alert because it saw a box move. Wyze’s cloud tracks the object over time, meaning it actually understands the difference between a delivery and a theft.
Wyze also includes "Smart Focus," which digitally crops and zooms to follow a person's face across the yard so you aren't stuck squinting at a tiny, pixelated intruder like you would be on a standard Kasa feed.
The Verdict on the Brains: Kasa’s local chip offers great speed and zero monthly fees, but it ages like a smartphone. Eventually, it just feels old. Wyze’s cloud model means your camera ages more like fine wine; as Wyze upgrades its servers, your old hardware gets smarter without you needing to climb a ladder to replace it.
Why Kasa and Tapo Parent Company Under Scrutiny from US Government
Wyze is a US based company founded in Seattle by ex-Amazon employees. It's worth noting that TP-Link, Kasa and Tapo’s parent company, is based in China and has recently faced some intense scrutiny from U.S. federal agencies regarding national security. Probes involving the Departments of Commerce, Justice, and Defense are focused on fears that Chinese-based control could enable spyware or data exploitation. AS of writing, there is an active investigation into a potential ban on TP-Link networking products, which could impact the long-term support and reliability of the Tapo ecosystem for U.S. users.
Regulatory pressure  reached a boiling point in March 2026, when the FCC officially added foreign-produced consumer routers to its 'Covered List' under the ROUTERS Act. The law might be focused on routers first, but it could have a massive impact on how Tapo cameras work in the long run.
Because most Tapo users rely on the broader TP-Link networking ecosystem, they are now facing a regulatory 'expiration date.' The FCC currently allows existing devices to receive security patches, but that waiver is set to expire on January 1, 2029. After that date, unless TP-Link successfully moves its manufacturing to the U.S. or gains 'Conditional Approval' from the Department of Homeland Security, these devices may be legally blocked from receiving critical firmware updates.
On top of that, a major 2026 lawsuit filed by the Texas Attorney General alleges that TP-Link has intentionally misled consumers about its ties to China by using 'Made in Vietnam' labels for products whose components and R&D remain deeply entrenched in mainland China.
Bottomline? Wyze has the home field advantage as a U.S. based company. It's one less thing to worry about when you're trying to keep your home secure. If you choose Tapo, you’re getting great hardware today, but you’re also betting on a company that’s fighting a multi-front legal battle to stay relevant in the American market beyond 2027.
Final Thoughts
If you are looking to invest in a smart home ecosystem that you don't have to worry about replacing in a few years, Wyze is the safer, more value-packed bet. On a pure hardware-to-dollar comparison, Wyze gives you more features like larger storage capacities, pre-roll video alerts, and color night vision, for less money. As a U.S.-based company, it also offers long-term ecosystem stability.
Kasa makes excellent, highly capable hardware that stands toe-to-toe with Wyze on baseline video resolution and local storage. But, we can't ignore the elephant in the room: the active federal security probes facing Kasa’s parent company, TP-Link. Buying heavily into Kasa right now means gambling that they will clear their U.S. legal hurdles before a potential 2029 firmware block. Unless you are fully committed to Kasa’s local chip-based processing, Wyze offers more features and less risk for an equal, and often lower, price-point.
Häufig gestellte Fragen
What is the difference between Kasa and Tapo?
They are both owned by TP-Link. Kasa was their original smart home brand, but they are slowly shifting focus toward Tapo.
Will my camera still record if my Wi-Fi goes down?
Both Wyze and Kasa cameras can record to a microSD card without an active internet connection, provided they have power. However, you won't be able to view the live feed or receive alerts until the Wi-Fi comes back. Wyze makes this process a bit more user-friendly by letting you easily review that local footage once you're back online.
Which brand is better for local storage?
Wyze wins here. Most Wyze cameras, including the Cam v4 and Doorbell v2, support significantly larger microSD cards than their Kasa counterparts. If you want to keep weeks of 24/7 footage without relying on a cloud subscription, Wyze gives you more room to breathe.
Wyze vs. Kasa: Vergleich von Preis, Leistung und Funktionen – Wyze Labs, Inc.
Kameras
Von Garrett Bogar
Sind extrem günstige Smart-Kameras tatsächlich zuverlässig? Wir haben die besten Schwenk-Neige-Kameras, vielseitigen Spot-Kameras und Video-Türklingeln von Wyze und Kasa einem direkten Vergleich unterzogen. Spoiler: Eine Marke bietet intelligentere KI und mehr Speicherplatz...
Die beste Video-Türklingel für Mieter – Wyze Labs, Inc.
Anleitungen
Von Silas Phillips
In einer Mietwohnung zu wohnen bedeutet in der Regel, sich an die Regeln anderer halten zu müssen. Deshalb sind die besten Video-Türklingeln für Mieter die „Wyze Battery Video Doorbell“ oder die „Wyze Duo Cam“...
Hintergrund zum Newsletter
Bleiben Sie auf dem Laufenden
Abonnieren Sie unsere Top-Meldungen, Neuigkeiten und Tipps, wie Sie mit Wyze Ihre Sicherheit verbessern können.
In den Warenkorb gelegt
Kostenloser Versand ab einem Bestellwert von 59 £
Zwischensumme
£0.00
Warenkorb anzeigen
