Skip to content
Wyze vs Arlo: High-End Features Without the High-End Price Tag
Choosing a smart home camera shouldn't feel like you’re trying to explain a meme to your grandmother. You want it to be simple. You want to see who’s at your door, keep an eye on the dog, and maybe catch that neighbor who keeps "borrowing" your trash can. Usually, you’re forced to choose between a "budget" camera that looks like it was made from recycled toy parts or a "premium" camera that costs more than your monthly car payment. Luckily, Wyze doesn't set you back an arm and leg just to help you secure your home.
Arlo has long been the choice for those who don’t mind a high price tag. But Wyze has spent years proving that you can have high resolution, color night vision, and smart AI alerts without clearing out your savings account. Here is how the two stack up when you actually look at the details.
Indoor Security: Privacy and Performance
Indoor cameras are all about balance. You want them to be smart enough to tell the difference between a person and a curtain blowing in the wind, but you also want them to stay out of your business when you’re home.
The Standard View
The Arlo Essential Indoor 2K is their lowest cost base model for indoor monitoring. It features a physical privacy shield that slides over the lens, which is a nice touch for those who are a bit wary of a camera in the living room.
On the other hand, the Wyze Cam v4 offers 2.5K resolution, which actually edges out the Arlo’s 2K clarity. While it doesn't have a physical sliding door, it does have a built-in siren and a spotlight that makes its color night vision pop. It’s also only $35.98. If you're on a tighter budget, the Wyze Cam OG is priced as low at $29.98, offering 1080p HD and color night vision for $10 less than Arlo's entry-level unit.
Pan, Tilt, and Total Coverage
When it comes to covering an entire room, Arlo offers the Essential Indoor Pan Tilt 2K for about $60.
The Wyze Cam Pan v3 is $37 and provides 360-degree horizontal coverage and even includes a physical "Privacy Mode" where the lens points itself down into the base.
If you want the absolute best detail, the Wyze Cam Pan v4 jumps to 4K Ultra HD for $60. To get 4K from Arlo, you’d have to look at the Ultra series, which requires a SmartHub. That combo will put you back about $300 and it doesn’t even pan or tilt. The value difference here isn't just a few dollars; it's an entire property's worth of security.
Outdoor Monitoring: The Battery Battle
When you move outside, things get serious. You need weather resistance and a battery that doesn't quit when the weather gets interesting.
High-End Wireless
Arlo’s Pro 6 is their latest heavy hitter. It offers 2K HDR and a 160-degree field of view. It’s impressive, but the $125 starting price is a bit of a gut punch. If you want the XL version for longer battery life, you’re looking at nearly $200 for a single camera.
The Wyze Solar Cam Pan handles this scenario with a bit more common sense. You still get that crisp 2K resolution, but at $79.98 you could buy several cameras to cover your entire property over a few of the Arlo Pro 6. The Solar Cam Pan has significant advantages with full pan and tilt and solar power. With Solar power you never have to worry about recharging your cameras. Wyze also uses a combination of Radar and PIR motion detection to cut down on false alarms from swaying trees or rain, which is a feature usually reserved for much more expensive hardware.
If you want to avoid charging batteries with Arlo, they suggest their Essential XL and a separate solar panel add-on, which will run you a total of about $130. Arlo doesn't have a direct equivalent that combines 360-degree movement with integrated solar power in a single unit.
Lighting Up the Night: Floodlight Comparisons
Floodlight cameras are the heavy hitters of home security. They don't just record the intruder; they make sure the intruder knows they’ve been spotted.
The Arlo Pro 3 Floodlight is a wireless option that puts out about 2000 lumens, which is plenty to see what's happening in your driveway. However, at $250, it's a significant investment. Arlo also offers a wired version for $99, but its features are somewhat limited compared to their premium line.
Wyze counters with the Cam Floodlight v2, which pumps out 2800 lumens and offers 2K resolution for about $100. If you want to go even bigger, the Wyze Cam Floodlight Pro offers 3000 lumens and a 180-degree field of view. This wide-angle view means you can see your entire front yard with one camera instead of two. The Wyze floodlights offer significantly more features for a lower price.
The Front Door: Who’s There?
A video doorbell is your first line of defense. Arlo’s 2nd Gen Video Doorbell offers a 1:1 square aspect ratio so you can see packages on the ground. It’s a great feature, but the $130 price tag is steep for something that sits on your porch.
Wyze offers two ways to solve this. The Wyze Battery Video Doorbell also uses that 1:1 "head-to-toe" view for about $66. But if you are really worried about package thieves, the Wyze Duo Cam Battery Doorbell is the better tool. It has two separate lenses: one for faces and one angled specifically at the ground to watch your deliveries. Arlo’s single-lens design simply can’t compete with having a dedicated eye on your packages.
Subscriptions and Long-Term Value
This is where the math really stops making sense for Arlo. If you want to use the AI features you paid for, like person or package detection, Arlo Secure starts at $7.99 a month for a single camera. If you have a house full of cameras, you’re looking at $17.99 a month.
Wyze Cam Plus is much more reasonable. For $2.99 a month, you get unlimited clip length and all the AI detections you actually care about. If you want to unlock AI features on all your cameras with a single plan it starts at $9.99 a month, or $19.99 a month for all the crazy advanced AI like descriptive alerts. Wyze cameras support local storage via microSD cards. Arlo often requires a SmartHub for local storage, which is another $100-$150 expense you just don't need with Wyze.
The Verdict
Arlo makes good cameras, but they expect you to pay a "premium" tax for cameras that aren’t that premium. Wyze offers the same (and often better) resolution, better local storage options, and a much more friendly subscription model.
If you like overpaying for things because money means nothing to you, go with Arlo. If you prefer smart, clear, and affordable security that just works, Wyze is the obvious choice. It’s about getting the features you need without the price tag you don’t.
Frequently Asked Questions:
Q: I need outdoor security, but I refuse to climb a ladder to charge batteries. What are my options?
A: Taking down your outdoor camera every few months to charge it is a chore nobody wants to do—especially when it involves balancing on a rickety ladder. Enter the Wyze Solar Cam Pan. For about $80, you get full pan-and-tilt tracking, crisp 2K resolution, and integrated solar power. Let the sun do the heavy lifting so you can keep your feet firmly on the ground. Arlo’s battery-heavy Pro 6 XL, on the other hand, will run you nearly $200 for a single static camera.
Q: Which floodlight will actually scare away the neighborhood raccoons?
A: Arlo's $250 floodlight pumps out 2000 lumens, which is fine if you're trying to light up a small patio. But the Wyze Cam Floodlight v2 dominates the dark with 2800 Lumens LEDs, 2K video, and a much friendlier price tag of around $100. Need even more coverage? The Wyze Cam Floodlight Pro blasts 3000 lumens across a massive 180-degree field of view, letting you see your entire front yard with one device.
Q: Can these video doorbells actually stop package thieves?
A: Arlo's $130 doorbell gives you a 1:1 square view, which is cute. But if you want real protection, the Wyze Duo Cam Doorbell with TWO cameras and full porch coverage is the punch that'll send porch pirates packing! It packs two separate lenses. One camera sees people to clearly capture every visitor. Another camera looks directly down at your doorstep. Arlo's single-lens design simply can't compete with having a dedicated eye on your deliveries.
cameras
By Garrett Bogar
Best Video Doorbell for Renters - Wyze Labs, Inc.
guides
By Silas Phillips
Living in a rental property usually means living by someone else's rules, which is why the best video doorbells for renters are the Wyze Battery Video Doorbell or the Wyze Duo Cam...
Newsletter background
Be in the know
£0.00
