Wyze Home Monitoring Core Starter Kit (+ 3-Months Professional Monitoring)
It's more than just a security system. It's complete home monitoring.
24/7 entire home professional monitoring at $10/month (first 3 months FREE)
TOTAL:
- 24/7 professional monitoring
- 24/7 emergency dispatch available
- New security-focused hardware
- Battery backup in hub
- Works with Wyze Cams
- Integrated video events
- Ever-growing cloud-based AI assisted alerts
- In-app arming panel
- Sensor status dashboard
- Monitoring events summary
- Critical Alerts (iOS only)
- Home and Away monitoring modes
- Test Mode
- Monitoring certificate for home insurance discounts
- Single-tap export of video events
Wyze Sense v2 Hub
- Color
White base with grey speaker top
- Finish
Matte
- Dimensions (H x W x D)
4.5” x 4” x 1” / 114.3 x 101.6 x 25.4 mm
- Battery
Built-in rechargeable battery
Battery backup life: 10 hours
Battery cell composition: 18650
Battery power: 3.7 V, 2600 mAh
Battery weight: 11.5 g
Number of battery Cells: 1
- Communication Method
Ethernet, WiFi 802.11 b/g/n, 2.4 GHz, Bluetooth 4.1+ BLE 5.1, 915MHz RF
- Range
500 ft / 152 m to sensors
- Operating Temperature
32°F - 104°F (0°C - 40°C)
- Operating Humidity
≤ 85% at 86°F (30°C)
- Weather Resistance
Indoor use only
- Sensors Supported
Up to 100
- Siren
88db @2 feet / 0.6 m
Wyze Sense Keypad
- Color
White
- Finish
Matte
4.0” x 2.4” x 1.0” / 100.7 x 62.1 x 24.5 mm
- Battery
AA batteries x 3
Battery life: 18 months
Battery cell composition: AA batteries x 3
Battery power: 1.5V x 3
Battery weight: 23.5 g
Number of battery cells: 3
- Mounting Method
Adhesive back, optional screws
915MHz RF
- Range
500 ft / 152 m
Indoor use only
Wyze Sense v2 Entry Sensor
- Color
White
- Finish
Matte
Sensor body: 2.1" x 1.7" x .7" / 53 x 43 x 18 mm
Magnet: 1.2” x 0.4” x 0.4” / 30 x 11 x 11 mm
- Battery
AAA x 1
- Battery Life
1.5 years based on normal usage
- Mounting Method
Adhesive back
915MHz RF
- Range
500 ft / 152 m
32°F – 104°F (0°C – 40°C)
Indoor use only
- Max Distance Between Components
0.8” / 20 mm
Wyze Sense v2 Motion Sensor
- Color
White
- Finish
Matte
2.0" x 2.0" x 1.1” / 51 x 51 x 25 mm
- Battery
AAA x 2
- Battery Life
- Mounting Method
Adhesive back with option to screw in place
915MHz RF
- Range
500 ft / 152 m
Indoor use only
- Detection Range
25 ft / 7.62 m
- Installation height
8.2 ft / 2.3 m
- FOV
Max 120°
- Wyze Sense Hub x1
- Power Adapter x1
- Ethernet Cable x1
- Keypad x1
- Entry Sensors x2
- Motion Sensor x1
- Window Decals x2
- Quick Start Guide x1
Wyze is trusted by over 5 million customers
And we’ve partnered with professional monitoring provider Noonlight to bring you the most affordable home security available.
Fast emergency dispatch
24/7 monitoring center routes to local 911 call center
Real people contact you in emergencies
Receive communication within 5 seconds* of an alarm
Easy DIY Installation
No screws, tools, or drilling required
Personalized for every sized home
Add sensors to protect every window, door, and corner
We protect your home around the clock, even when you’re unavailable
1. Alarm is triggered
Receive a text within 5 seconds* of an alarm to verify the emergency.
2. Emergency is confirmed
If you don't respond, get called by a friendly dispatcher within 30 seconds.
3. Help is quickly dispatched
If you confirm or can't respond, first responders are sent to your home.
Meet Your Core Starter Kit
Exactly what you need to get started. Not enough? No problem. You can add up to 100 sensors to a single Wyze Sense Hub.
All entry points monitored for any size home
Personalized kits make sure your home is covered from front door to back patio and everything between. Regardless of the kit you choose, you still only pay $9.99/month for monitoring.
Start with a Wyze Sense Hub and add the basics.
• One 3-pack of Wyze Entry
• One Wyze Sense Motion Sensor
• One Wyze Sense Keypad
Start with the Apartment and Condo basics and add a few extras.
• One 3-pack of Wyze Entry Sensors
• One additional Wyze Sense Keypad (for the back door)
• One Wyze Cam
Scale up to monitor your whole home:
• Two 3-packs of Wyze Entry Sensors
• Two additional Wyze Sense Keypads (for back and side doors)
• One Wyze CamOne Wyze Motion Sensor
• Wyze Sense Leak and Climate Sensors
Protect your peace of mind from water damage
Wyze Home Monitoring protects your home from more than just break-ins. Monitor your home for leaks and drastic changes in temperature.
Wyze Sense Leak Sensor
Wyze Sense Leak Sensor instantly alerts you about leaks in unwanted places. Learn More
• Instant leak notifications
• Optional extender probe
• Wireless, 500 ft range
Wyze Sense Climate Sensor
Wyze Sense Climate Sensor notifies you when temperature or humidity falls below or rises above your personalized limits. Learn More
• Notifications
• Temperature and humidity tracking
• Custom climate alerts
Want an extra set of eyes on the bad guys?
Wyze Home Monitoring becomes even better when you connect our award winning Wyze Cam (sold separately).
✓ See what caused an alarm if you’re away
✓ Collect video evidence to provide to police
✓ Check-in on your home at a moment’s notice
✓ Receive alerts when people are detected with Wyze A.I.
Even more reasons to love Wyze
Motion sensors are pet-friendly
Our motion sensors are designed to detect people and not pets to reduce false alarms. Sensitivity can be manually adjusted to dial-in the perfect setting.
Installation doesn’t require tools or professionals
Our sensors are battery-powered, wireless, and come with adhesives so all you have to do is peel and stick.
Save money on home insurance
Receive a certificate to send to your home insurance company for a discount on your policy.*
*Discount on home insurance policy is typically for those getting a home monitoring system for the first time. Offer and discount level may vary based on home insurance provider.
Meet the team on standby ready to help at a moment’s notice
Based in the U.S., professional security partner, Noonlight, supports Wyze customers with UL-listed professional monitoring centers.
This unique partnership enables us to provide exceptional service at a fraction of the cost of other systems on the market.
• 2 million people protected
• Five Diamond Certified
No long-term contracts
