x
The requested quantity exceeds the maximum quantity allowed in the shopping cart
1 of 5
Wyze Car Kit
It's time to shift into fun.
Includes: Wyze Car + Wyze Power Bank + Wyze Cam Black
TOTAL:
$69.99 $92.97 + Shipping
Cam Plus subscriber? Log in to check your special price. Learn more
Features
All-Wheel Drive
Your targets rarely operate out in the open - traversing all types of terrain is a requirement. Shock-absorbing suspension withstands vertical impact after flying through the air. And a high-density, all-plastic roll cage protects against nasty spills while you make your getaway.
LED Headlights for Night Driving
Parts of your mission will require clandestine operations at night. To safely navigate the dark and capture clear video, quickly activate and deactivate your headlights from the app. But be cautious! You need to remain undetected.
Battery Modes
We can’t have our highly classified apparatus captured by the target. When at risk of discovery or when you've successfully completed your mission, bolt back to base. Eco Mode lets you conserve battery life as you approach your target while Sport Mode kicks it into high gear so you make it back to HQ quickly.
2-Hour Operation on a Single Charge
Don’t worry about getting caught with low fuel during your escape. We’ve packed Wyze Car with a 10,000 mAh power bank that will keep you running throughout your entire mission.
Intuitive Control
We’ve enlisted our top engineers to discreetly hide Wyze Car’s remote directly in a classified app on your phone. With the app, you'll be able to live stream your mission through your phone while completing your mission objectives from a safe distance away from the action. It goes without saying, but we absolutely cannot have another cover blown like the Jimmy from Wyze incident last year when the joystick fell from his pocket during cocktail hour.
Realistic, First-Person Perspective
See exactly what Wyze Car sees with real-time video streaming to your phone. Wrapping around corners and losing sight of Wyze Car is not a problem with first-person perspective navigation.
Wifi Direct - Play Anywhere
Travel around anywhere inside or outside your home with no fear of losing signal. WiFi Direct connects Wyze Car directly to your phone so you’re not tethered to your home’s WiFi.
All-Terrain Wheels
Massive off-road tires climb over small rocks, carpets, twigs, and more with ease. For an extra boost, enable Sport Mode and dominate any terrain.
Tech Specs
Wyze Car Device Details
Color
Black
Materials
Car body: Polycarbonate
Weight
2.2 lbs
Dimensions
305 mm x 188 mm x 147 mm
LED Headlights
Color temperature: 6000 K
Brightness: 70 lumens
Max Speed
Eco Mode: 1.5 mph
Sport Mode: 2 mph
Phone Compatibility
Android 5.0+
iOS 9.0+
Battery Life
Standby: Up to 20 hours
Active: Up to 2 hours (driving)
Driving Controls
Forward, Reverse, Left and Right turning
Wyze Cam Features
Live Stream, 2-Way Audio, Record, and Take Photo
Power Bank Device Details
Color
Black
Weight
7.4 oz
Dimensions
106 mm x 51 mm x 25 mm
Rated Capacity
10,000 mAh
Input
5V2A, 9V2A
Output
5V3A
In the Box
  • Wyze Car x1
  • Wyze Car Power Bank x 1
  • Wyze Cam v2 Black x1
  • Rubber Band x2
  • Short Screw x8
  • Long Screw x4
  • Screwdriver x1
  • Anti-slip Tape x2
  • Guardrail x1
  • Quick Start Guide x1
  • Micro USB Cable x1
Connects to phone’s WiFi
LED headlight
10,000 mAh battery pack
Mobile app remote control
Control Wyze Car from the safety of your HQ
wyze car app
wyze car app
  • Record
    Capture, and save video of your mission for debriefing.
  • Retrieve
    Critical information about your targets by getting up close and personal.
  • Recover
    Wyze Car by navigating it home remotely with the app.
Get out of dodge when things get sticky
We can’t have our highly classified apparatus captured by the target. When at risk of discovery or when you've successfully completed your mission, bolt back to base. Eco mode lets you conserve battery life as you approach your target while Sports mode kicks it into high gear so you make it back to HQ quickly.
Eco-Mode
Conserve Battery
Sports Mode
Trade off battery for speed
wyze car light
wyze car light
Light up night missions with LED headlights
wyze car
wyze car
2 hours of nonstop action
wyze car
wyze car
All-wheel drive goes from hardwoods to backwoods
Your targets rarely operate out in the open - traversing all types of terrain is a requirement. Massive off-road tires climb over rocks, carpets, branches, and more with ease. Shock-absorbing suspension withstands vertical impact after flying through the air. And a high-density, all-plastic roll cage protects against nasty spills while you make your getaway.
wyze car on rocks
wyze car outside
wyze car outside
wyze car
