Skip to content
1 of 7
Wyze Cam Floodlight Color Filters
Transform your space with 6 pairs of color filters for every mood and occasion
$14.98
⚠️ Color Filters use adhesive. Repeated removal and reapplication may weaken adhesion over time.
  • 6 Vibrant Color Options
    Choose your colors to set the scene.
  • Transform Your Floodlight
    Your light, your vibe. Tone it down or jazz it up.
  • Compatible with Floodlight v1 & v2
    Use your existing Wyze Cam Floodlight v2/v1 (not compatible with Pro).
Wyze Cam Floodlight v2 Color Filter Tech Specs
Color
  • 3500K Warm White
  • Red
  • Blue
  • Green
  • Cyan
  • Purple
Material
  • High-transmittance plastic + adhesives
Dimensions
  • Width x Depth x Height (2.76 in x 0.79 in x 3.15 in / 7cm x 2cm x 8cm)
Weight
  • 0.16 lbs / 0.073kg
Compatible with
  • Wyze Cam Floodlight v1/v2
  • Color: White or Black
  • Finish: Matte
  • Mount: Wall/Ceiling
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • 2 dimmable LED light panels
  • 2800 total lumens of brightness
  • 5000K color temperature
  • Dimmable: Yes
  • 2K (2304 x 1296)
  • Night Vision
  • Color Night Vision
  • Hardwired 110 - 120V AC
  • -4°F - 140°F (-20°C - 60°C)
  • IP65 Water Resistance
  • Safe for outdoor use
Learn more
Connectivity & Compatibility
  • IEEE802.11 b/g/n. Wi-Fi 2.4 GHz b/g/n
Warranty
  • Floodlight v2: 18 months
  • Floodlight Color Filters: 12 months
12 x Color Filters (6 pairs total, 2 of each color)
  • 3500K Warm White
  • Red
  • Blue
  • Green
  • Cyan
  • Purple
2 x Cleaning Wipe Packets
  • Each packet includes 1 wet wipe + 1 dry wipe
(Camera not included)
Yes, you can gently peel off the current filter using the small tab on the bottom of the filter, then clean the LED lamp’s surface and apply a new color. Just keep in mind that repeated removal and reapplication will reduce the adhesive strength over time.
Absolutely! Each pack includes 6 colors (2 filters in each color) so you can mix and max – use one color on each lamp head to create your own custom combo.
Wyze Cam Floodlight v2 Color Filters are designed with high transmittance to help maintain light output. Some brightness reduction may occur, especially with colored filters, but they’re designed to provide warm or colorful lighting without significantly compromising your floodlight experience.
No, the filters are only compatible with Wyze Cam Floodlight v1/v2. They are not compatible with Wyze Cam Floodlight Pro.
They are built with durable material and adhesive designed to withstand outdoor conditions alongside your IP65-rated Wyze Cam Floodlight v2. Under regular use, the filters will last multiple seasons.
No, the color filters are applied to the LED lamp heads only and do not cover the camera lens. Your camera’s resolution and night vision should remain unaffected.
The filters are built with durable, weather-resistant material. Just be sure to clean and fully dry the LED light surface before applying the filters for the best adhesive bond.
We are unable to provide the color codes as the color may appear slightly different based on environmental factors and the floodlight’s brightness.
Store filters in a cool, dry place while ensuring the adhesive side isn’t exposed to dust.
Two small cleaning wipes are included in the package, but you can also use similar electronics cleansing wipes or a soft microfiber towel. No need for soapy water! Do not use abrasive materials, sharp objects, harsh chemicals, or rough cloths, as these may damage the lamp head surface.
No, the adhesive cannot be cleaned. Please ensure minimal to no dust is on them when applying to the lamp head.
While they can be reused multiple times if stored and cared for properly, we generally consider them one-time use, similar to phone screen protectors.
We do not recommend stacking or layering the filters.
Use the perfect color for your home
Choose from 6 color options to add a fun, welcoming glow to holidays, celebrations, and everyday moments.
Quick and easy installation.
Just peel the protective film from the plastic filter, stick it to the floodlight, and you’re good!
Softer warm white lighting
Transform your floodlight with a softer warm glow.
Elevate your lighting experience even if you have our older Floodlight v1.
Weather resistant
It can handle anything Mother Nature can throw at it.
