You're on the list!
You'll get an email at when is back in stock
Explore Similar Products
x
The requested quantity exceeds the maximum quantity allowed in the shopping cart
  • Wyze handheld vacuum
1 of 1
(Refurbished) Wyze Handheld Vacuum
The perfect spot cleaning companion from car to home.
TOTAL:
$29.99 + Shipping
Features
16,800 Pa Suction Power
The suction power of a tornado in a handheld, compact vacuum. Can absorb everything from fine dust mites to bread crumbs.
Brushless Digital Motor
Our 100,000 RPM motor is 3x better than motors with carbon brush loss.
Lightweight & Cordless
Use anywhere from the kitchen to your office to your car.
Attachments for Every Nook and Cranny
Included with your preorder, the flat nozzle, brush tool, crevice tool, and extension hose let you clean anywhere and everywhere.
Washable HEPA filter
Filters dirty or clogged? Simply rinse the HEPA filter and stainless steel prefilter screen with tap water and let dry.
30-min Cleaning Time
Clean for up to 30 minutes on a single charge.
Tech Specs
Wyze Handheld Vacuum Device Details
Color
Black
Weight
19.8 oz
Battery and Charging
Charging Method
Type-C power cable
Charging input
5V-2A
Charging time
About 3 hours to 100%
Battery capacity
6,000 mAh
Rated voltage
10.8 V
Rated power output
120 W
Vacuum Operation
Dust cup volume
0.2 L
Noise level
73.8 dB(A)
Running time
30 mins in default mode
10 mins in max power mode
Suction power
9,000 PA in default mode
16,800 PA in max power mode
Recommended Temperature
Operating: -4°F - 140°F (-20°C - 60°C)
Charging: 32°F - 113°F (0°C - 45°C)
Storage: -4°F - 104°F (-20°C - 40°C)
Weather Resistance
None. Do not use outdoors.
In the Box
  • Wyze Handheld Vacuum x1
  • USB Cable x1
  • Charger x1
  • Storage Bag x1
  • Extension Hose x1
  • Crevice Tool x1
  • Flat Nozzle x1
  • Attachment Adapter x1
  • Brush Tool x1
  • Quick Start Guide x1
Engineered for extreme portability.
Wyze Handheld Vacuum was designed to be luxuriously convenient to use for any task. At just 1.23lbs and under 3" thick, it's 50% lighter and 65% more compact than leading handheld vacuums.
Vacuum in Tesla Car
Vacuum in Tesla Car
"Fantastically portable."
-RTINGS.com
"A lot of vacuum for the price."
-ReviewGeek
"Perfect for keeping in your car full time."
-CNN
"Beats every handvac I have used."
-BB Product Reviews
Double the suction of other handheld vacs.
Most handheld vacuums (8kPa) can handle dust and small debris. Wyze Handheld Vacuum (16.8kPa) takes portable cleaning to a new level by pulling up even the deepest dirt, crumbs, and pet hair.
Vacuum picking up dog food
USB-C charging.
Charge your vacuum where you charge all your devices with the integrated USB-C port. View your battery life in bright LEDs with up to 30 minutes of run-time.
Vacuum charging with USB-C port in Tesla Model 3
True HEPA allergen filtration.
To empty, just press a single button located near the nossle. Inside are the dustbin, stainless steel filter, and true HEPA filter which traps 95% of allergens. Each part is easily removable and washable.
Easy empty into trash can with a button
Turbo / Eco Mode
Whether you're spot cleaning or rage cleaning, Wyze Handheld Vacuum has a mode for that. Even at its loudest setting, it's still 20% quieter than most handheld vacuums.
Wyze Hand Vac sitting upright in back seat of Tesla model 3
Attachments for every clean.
Impossible-to-reach places have finally met their match. Included are 4 unique tools to help you clean even the most awkward of spaces.
Hose Extension Tool on bookshelf
Extension Hose
Brush tool on MacBook pro
Brush Tool
TOOL ON COUCH
Flat Nozzle
TOOL ON CAR
Crevice Tool
