iHealth COVID-19 Antigen Rapid Test
Test early and often.
- Nasal Swabs, individually packed x2
- Sample Preservation Solution Tubes, individually packed x2
- Test Reading Cards, individually packed x2
- Quick Start Guide x1
- Instructions for Use x1
Get instant COVID test results in 15 minutes
New variants have shown that anyone can be vulnerable to COVID-19, even kids or those that are vaccinated. With iHealth COVID-19 Antigen Rapid Test, you can instantly test yourself after being out in public. Early testing helps you better care for yourself and protects your friends, family, and community members from potential exposure.
*For more instructions on reading results, go to Ihealthlabs.com
4 Steps. 15 Minutes. Minimal Discomfort.
iHealth COVID-19 Antigen Rapid Test is the simplest way to find out if someone has COVID-19. It only takes 4 steps and 15 minutes to complete the test. The test is also non-invasive—you won’t need to collect a sample from deep in your nasal cavity to get accurate results.
01
Swab
Brush against inner wall of both nostrils 5 times in a circular motion with a non-invasive nasal swab. Our nasal swab is soft, highly absorbent, and only needs to be inserted ½ - ¾ inches so you can test yourself comfortably.
02
Dip
Insert the swab to the bottom of the tube and stir 15 times. Squeeze the sides of the tube around the swab as you pull it out.
03
Drip
Put 3 drops of the mixed solution onto the sample port of the COVID-19 test card.
04
Wait 15 minutes
Start the timer. Your results will be ready in 15 minutes.
Flu or COVID, 15 minutes to get peace of mind.
If you're experiencing symptoms like fever, sneezing, cough, or fatigue, you can quickly know if you have COVID-19 within 15 minutes by using iHealth COVID-19 Antigen Rapid Test.
Quick in-home testing takes away the worry of developing symptoms
Back to school, back to the office, or just back from travel or public gatherings, a rapid, 15-minute, self-test waiting at home when you get back.
Affordable per test price, so you can load up your first aid kit or travel bag
Each iHealth COVID-19 Antigen Rapid kit includes two tests. At this price, you can stock up your first aid kit and test yourself guilt-free when you experience symptoms or think you might be at risk. Its compact size makes it easy to keep stored away or take with you in a travel bag.
An in-home test designed to get accurate results
Not only is the iHealth COVID-19 Antigen Rapid Test easy and non-invasive, it’s a small engineering beauty. The test has a highly absorbent swab and individually sealed components to help prevent contamination, so you can view the results of your in-home test with confidence.
Highly Absorbent Swab
Made of PU foam, the absorbent tip of the swab makes sample collection more efficient than a regular swab.*
Double-Cap Security Design
The double-cap design allows you to safely store the liquid and then precisely drip the mixed sample to the test card.
Easy-to-understand Results
The unique test card shortens the time to get your results and makes the results easy to read. If only the C line shows up, the test is negative. If both C and T lines show up, the test is positive.
Group covid testing for schools, event planners, administrators, and organizers everywhere
Test and monitor results for large groups of people using iHealth in-home testing and the iHealth Test App.
Each individual added to the group can test themselves at home and upload their results confidentially to the group manager within a selected timeframe. At just $6.99/test, it is one of the most affordable COVID tests for sale, uniquely designed for group testing in the iHealth Test app.
Test results, once entered in the app, generate an iHealth Pass that can be used as digital proof of negative results for private events.
Users can store their vaccine record in the app for easy access.
Self-test at home. Results in 15 minutes.
Follow this easy-to-test video instruction guide.
• This product has not been FDA cleared or approved; but has been authorized by FDA under an EUA;
• This product has been authorized only for the detection of proteins from SARS- CoV-2, not for any other viruses or pathogens.
• The emergency use of this product is only authorized for the duration of the declaration that circumstances exist justifying the authorization of emergency use of in vitro diagnostics for detection and/or diagnosis of COVID-19 under Section 564(b)(1) of the Federal Food, Drug and Cosmetic Act, 21 U.S.C. § 360bbb-3(b)(1), unless the declaration is terminated or authorization is revoked sooner.
Disclaimer:If you’re currently experiencing COVID-19 symptoms, please contact your primary care physician (PCP) for immediate guidance. iHealth® COVID-19 Antigen Rapid Test may take several days to ship. This is not a PCR test and not valid for travel. The manufacturer of the iHealth® COVID-19 Antigen Rapid Test requires test kits be stored at temperatures between 2 and 30°C (36 - 86°F). Any extended exposure of the test kit to temperatures beyond this range may affect quality of test results. If you have ordered home delivery of the test kit and expect temperatures in your area to be outside of this range at time of delivery, it is recommended that you arrange for someone to be home at or near time of delivery to receive the test kit.
