Note: Wyze Cam Floodlight v2 Color Filters are compatible with Wyze Cam Floodlight v2 and v1 only. This product is not compatible with Wyze Cam Floodlight Pro.
What's in the box:
- Wyze Cam Floodlight v2 Color Filters x 12 6 colors (3500K Warm White, Red, Blue, Green, Cyan, Purple) x 2
- Wet Cleaning Wipe x 2
- Dry Cleaning Wipe x 2
To install your floodlight color filters:
- Remove all contents from the box (filters and wipes). The installation instructions are printed on the back of the box.
- Turn off your Wyze Cam Floodlight v2/v1 via the Wyze app. Ensure the floodlight LEDs are turned off and cool to the touch before proceeding.
- Clean the LED lamps with the include wet wipe, then the dry wipe. Make sure the LEDs are completely dry.
- Remove the blue film from the filter. Peel the blue protective film from one side of the filter to expose the adhesive.
- Stick the filter to the LED lamp. Align the filter over the LED lamp and press firmly for 5-10 seconds.
- Remove the transparent film from the filter.
- Repeat for the second LED lamp. All done!
To change to a different color:
- Gently peel off the current filters using the small tab on the filter.
- Wipe the lamp surface clean with cleansing wipes or other soft cleaning cloths.
- Apply the new color filter following the installation steps above.
Note: Repeated removal and reapplication of the same color filters will reduce adhesive strength.
