Ir directamente al contenido
1 de 7
Filtros de color para las luces de seguridad Wyze Cam
Transform your space with 6 pairs of color filters for every mood and occasion
$14.98
En existencias
En existencias
⚠️ Color Filters use adhesive. Repeated removal and reapplication may weaken adhesion over time.
Ver todos los detalles
  • 6 opciones de colores vibrantes
    Elige tus colores para ambientar la escena.
  • Transforma tu foco
    Transforma tu foco
    Tu luz, tu onda. Bájale el tono o súbele la intensidad.
  • Compatible con Floodlight v1 y v2
    Utiliza tu Wyze Cam Floodlight v2/v1 existente (no es compatible con Pro).
Wyze Cam Floodlight v2 Color Filter Tech Specs
Color
  • 3500K Warm White
  • Red
  • Blue
  • Green
  • Cyan
  • Purple
Material
  • High-transmittance plastic + adhesives
Dimensions
  • Width x Depth x Height (2.76 in x 0.79 in x 3.15 in / 7cm x 2cm x 8cm)
Weight
  • 0.16 lbs / 0.073kg
Compatible with
  • Wyze Cam Floodlight v1/v2
  • Color: White or Black
  • Finish: Matte
  • Mount: Wall/Ceiling
  • Body: Polycarbonate
  • Lens: Glass + Plastic
  • 2 dimmable LED light panels
  • 2800 total lumens of brightness
  • 5000K color temperature
  • Dimmable: Yes
  • 2K (2304 x 1296)
  • Night Vision
  • Color Night Vision
  • Hardwired 110 - 120V AC
  • -4°F - 140°F (-20°C - 60°C)
  • IP65 Water Resistance
  • Safe for outdoor use
Learn more
Connectivity & Compatibility
  • IEEE802.11 b/g/n. Wi-Fi 2.4 GHz b/g/n
Warranty
  • Floodlight v2: 18 months
  • Floodlight Color Filters: 12 months
12 x Color Filters (6 pairs total, 2 of each color)
  • 3500K Warm White
  • Red
  • Blue
  • Green
  • Cyan
  • Purple
2 x Cleaning Wipe Packets
  • Each packet includes 1 wet wipe + 1 dry wipe
(Camera not included)
Yes, you can gently peel off the current filter using the small tab on the bottom of the filter, then clean the LED lamp’s surface and apply a new color. Just keep in mind that repeated removal and reapplication will reduce the adhesive strength over time.
Absolutely! Each pack includes 6 colors (2 filters in each color) so you can mix and max – use one color on each lamp head to create your own custom combo.
Wyze Cam Floodlight v2 Color Filters are designed with high transmittance to help maintain light output. Some brightness reduction may occur, especially with colored filters, but they’re designed to provide warm or colorful lighting without significantly compromising your floodlight experience.
No, the filters are only compatible with Wyze Cam Floodlight v1/v2. They are not compatible with Wyze Cam Floodlight Pro.
They are built with durable material and adhesive designed to withstand outdoor conditions alongside your IP65-rated Wyze Cam Floodlight v2. Under regular use, the filters will last multiple seasons.
No, the color filters are applied to the LED lamp heads only and do not cover the camera lens. Your camera’s resolution and night vision should remain unaffected.
The filters are built with durable, weather-resistant material. Just be sure to clean and fully dry the LED light surface before applying the filters for the best adhesive bond.
We are unable to provide the color codes as the color may appear slightly different based on environmental factors and the floodlight’s brightness.
Store filters in a cool, dry place while ensuring the adhesive side isn’t exposed to dust.
Two small cleaning wipes are included in the package, but you can also use similar electronics cleansing wipes or a soft microfiber towel. No need for soapy water! Do not use abrasive materials, sharp objects, harsh chemicals, or rough cloths, as these may damage the lamp head surface.
No, the adhesive cannot be cleaned. Please ensure minimal to no dust is on them when applying to the lamp head.
While they can be reused multiple times if stored and cared for properly, we generally consider them one-time use, similar to phone screen protectors.
We do not recommend stacking or layering the filters.
Usa el color perfecto para tu hogar
Elija entre 6 opciones de color para añadir un brillo divertido y acogedor a las fiestas, celebraciones y momentos cotidianos.
Instalación rápida y sencilla.
Solo retira la película protectora del filtro de plástico, pégala al proyector, ¡y listo!
Iluminación blanca cálida más suave
Transforma tu proyector con un suave resplandor cálido.
Mejora tu experiencia de iluminación incluso si tienes nuestro Floodlight v1 anterior.
Resistente a la intemperie
Puede soportar cualquier cosa que la Madre Naturaleza le eche encima.
